Good Moring,
Looking for some advice regarding the variable downspring tension.   94 Bravo.   During annual I checked the tension per the service  manual and found it to be out of spec.   The SM list 14-16 and mine's at 24.   It seems a turnbuckle adjustment is the cure.  The challenge being it is not accessible via an inspection panel.
I would of expected it to have less tension as the AC is 26 years old and the cables certainly don't shrink.   Can someone offer advice on the best way to adjust?  Additionally, if it came from the factory this way, should it be adjusted?    Straying from the SM is not in my nature but a lot can be learned over 26 years.
The challenge is the location of the turnbuckle.  It's about midway between the depicted inspection panel and the large avionics/battery access panel.   Seems I'd have to crawl into the fuselage to adjust it.
