Jim Peace Posted January 17, 2021 Report Share Posted January 17, 2021 I have been flying in a friends J and the discussion came up... If the baggage door is locked with a key from the outside will the emergency door release from the inside work? Thank you in advance Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 17, 2021 Report Share Posted January 17, 2021 2 minutes ago, Jim Peace said: I have been flying in a friends J and the discussion came up... If the baggage door is locked with a key from the outside will the emergency door release from the inside work? Thank you in advance Yes, If you don’t have the emergency release... there is an option to add the bits of hardware required... Like anything else... Test it before needing it... PP thoughts only, not a mechanic... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted January 17, 2021 Report Share Posted January 17, 2021 Trivial. I just took some safety wire around the latch, ran it through the interior panel and put a ring on the end. Pull it and the door pops. Be careful when back seat pax reach yo grab stuff. 1 Quote Link to comment Share on other sites More sharing options...
201Steve Posted January 19, 2021 Report Share Posted January 19, 2021 On 1/17/2021 at 3:45 PM, RobertGary1 said: Trivial. I just took some safety wire around the latch, ran it through the interior panel and put a ring on the end. Pull it and the door pops. Be careful when back seat pax reach yo grab stuff. Interesting. Perhaps a strip of clear tape or adhesive vinylwith a removal tab could additionally eliminate bag snag mishaps. Quote Link to comment Share on other sites More sharing options...
47U Posted January 20, 2021 Report Share Posted January 20, 2021 21 hours ago, 201Steve said: Perhaps a strip of clear tape or adhesive vinylwith a removal tab could additionally eliminate bag snag mishaps. Someone affixed a red 1” lanyard to this baggage door egress release, then held the lanyard in place with a piece of scrap sheetmetal affixed with velcro to the door. It’s mounted to the aft side of the baggage door to (hopefully) prevent snags if pax are digging around in the baggage compartment during flight. 3 Quote Link to comment Share on other sites More sharing options...
