WTB: Hartzell phc-c3yf-2uf/fc7663d-2r Single or Pair
I am looking to buy a single used Hartzell phc-c3yf-2uf/fc7663d-2r propeller, or would consider a pair of propellers.
I prefer used but will consider a rebuilt prop.
Run out of time propeller is OK.
This prop is typically found on Cessna 310’s and Beech 55 Barons.
Thanks, Frank
Link to comment
Share on other sites
3 hours ago, Cody Stallings said:
I don’t have one of those.
FWI, that’s not. Mooney prop.
That’s a Multi-Feathering prop you would Find on a Baron or C310
C340 uses a little larger prop, an C421 uses Giant 90 inch props
Thanks for the info. I will correct my post. You were obviously my first call when I started shopping for the props.
Thanks, Frank
Link to comment
