Will I fit?
JimB58
Hello Fellow Vintage Mooney lovers...
I finally got my PPL, am tired of renting a/c, and would love to get a good ‘67 M20F w/ Johnson bar. But, never having sat in one or flown one yet, I have a simple question... will I fit and be comfortable when flying it. I’m 6’2”, and 205#. My knees are way to close to the dash in the C & E model; hence the desire for the longer F model. What say you, the experts?
Thanks, in advance...
Link to comment
Share on other sites
Just now, krkt58 said:
It must be that I have longer legs and a shorter torso...
There's a member here who is 6'9", but I don't recall what year his F is . . . . @Yetti  So no, you aren't too big, but remember, a Mooney isn't a Suburban and won't have that mind of space.
Link to comment
50 minutes ago, ArtVandelay said:
33” inseam, in last position I have to pronate my feet to use the brakes in a J.
My size, too. I fly my C in the middle of three holes. It boils down to personal preference.
Mynwife, 5'3", keeps the right seat in the last hole, and can't even bump the pedals when she kicks.
Link to comment
@krkt58 as mentioned, the extra room in the F only affects the leg room in the rear seat.
Your pilot seat position is limited by your ability to fully manipulate the brakes. i.e. if you have the seat too far back you will loose your ability to use them.
when you say "My knees are way to close to the dash in the C & E model" its not clear which hole in the seat rails your seat is in. If your seat is far forward in the first couple holes then you can have 3" brake pedal extensions added which allow you move your seat further back and still have access to the brake without being right against the panel.
Link to comment
Welcome!
6' 1" and 205# (with a Holiday belly and Winter clothes, of course) and I fit nicely in my E and love it.
However, I was also "bumping my knees on the dash"  when sizing the aircraft and wonder if any of these might be the issue:   (all now solved)
1.  Climbing in requires a bit of work and if the seat is still in the forward "flying" position, I can scrape my knees on the way in.  Simple solution was to slide it back for entry.
2.  Reaching the fuel selector required me to bend and move my legs and they interfered.
3.  I didn't have my complex rating so the current owner was flying and I was in the right seat.  He had me adjust the seat so that I could reach the pedals (to the stops).  During the flight I didn't want to interfere with his manipulation of the controls so I bent my legs so they weren't touching the pedals.   ...and there wasn't space to bend without hitting the dash.
4.  To make matters worse, the headphone jacks on the right side were here:
5.   Sight picture - It took me a bit to get used to the Mooney sight picture on landing.   I pulled my seat way too far forward in order to get the same view as I had in the trainer 152/172's and cramped myself up to the windscreen (bending my legs).   Mooney specific training (MAPA Pilot Proficiency Program for me), proper trim on landing and experience helped there.
Edited by Seymour
Added a fifth possible reason
Link to comment
3 minutes ago, carusoam said:
So many better places for head phone jacks...
So many planes have hidden them in goofier places...
Absolutely agree!!
Sounds like a subject for an interesting thread (but doing a search before I start a new one).
Link to comment
Want to sit one and find out for sure?
Who sits behind you?
If it’s your financial administrator... better get the Long Body.
Link to comment
I divide the issue into two —
one: entry/exit ease.  The Mooney is about like most small low wing planes in this area.  Piper, Cirrus, etc will be similar, except the vintage Mooney has just one door.
two: comfort in the seat for several hours.  Once in, can you get and stay comfortable?  You’re not going anywhere until you land. New seat foam and fabric can help.
Link to comment
True - all that.
-egress - I learned there is a really good way - which for me is to enter backwards.  One knee on the copilot seat,, left leg on the floor on the copilot side, hands on the door frame (not the door), lowering my butt down to a sort of kneeling before the king position with the knee on the copilot seat, and then from there lowering but down to the pilot seat.  Its smooth, easy and stable.
-I had my seats redone a few years ago, and with firm memory foam, lumbar support, sculpting, and also I specifically had the Lower cushion lengthened a bit several inches since with long legs on a short seat you sort of feel perched on the seat.  Now I feel the seat more fully supports my long thighs.
-I had Bruce Jaegers interior plastic added which does offer a bit more arm and shoulder room.
-and as I said, I added an extra pin hole on my seat rails.
All small things but they really do add up.
Link to comment
