mhrivnak Posted November 22, 2020 Report Share Posted November 22, 2020 I'm removing an Insight G2 engine monitor to make way for my new JPI EDM 900, but I can't figure out how to remove the two knobs on the G2 so that I can remove it from the panel. I don't see a set screw anywhere, I tried pulling hard without breaking it, and I don't see any mention of installing or removing the knobs in the manual. The stem for each knob extends through its own tiny hole in the panel, so the knobs must have been put on after the instrument was mounted. Any ideas? Thanks! Quote Link to comment Share on other sites More sharing options...
MikeOH Posted November 22, 2020 Report Share Posted November 22, 2020 I have G3 and I believe there is a special tool to remove the knobs. I found it in all the stuff the PO gave me when I bought the plane. Unfortunately, I have never put it to use, so I can't give you first hand advice. I wouldn't force anything, that's for sure; it all looks pretty fragile. Quote Link to comment Share on other sites More sharing options...
MikeOH Posted November 22, 2020 Report Share Posted November 22, 2020 Here's a photo of the tool: 1 Quote Link to comment Share on other sites More sharing options...
OR75 Posted November 22, 2020 Report Share Posted November 22, 2020 (edited) You need to pry out the caps (the caps that have SEL and PG on them. that cover the knobs. Use a blade or a tiny flat screwdriver for that . Make sure you don.t loose those caps . then use the tool pictured above to remove the knobs. Hold the knob and unscrew with the tool above (it will be straightforward once you uncap the knobs Edited November 22, 2020 by OR75 Corrected typo Quote Link to comment Share on other sites More sharing options...
OR75 Posted November 22, 2020 Report Share Posted November 22, 2020 The plastic that has PG and SEL on them are actually caps behind which the screw is Quote Link to comment Share on other sites More sharing options...
carusoam Posted November 22, 2020 Report Share Posted November 22, 2020 Now that MS has solved that mini mystery... Does the old engine monitor go up for sale? That is a nice one. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
mhrivnak Posted November 23, 2020 Author Report Share Posted November 23, 2020 Thank you all. I was able to get the knobs off and the instrument out. I don't have that little wrench, but I took and old 3/16" flat head screwdriver and cut a notch in the middle. It worked great. I had tried prying the caps off with my fingers previously, which didn't work. When I used a blade though, they came right off. Thanks! Yes, the Insight G2 will be for sale with the harness and 4 each CHT and EGT probes. It works great; I just wanted to upgrade to the JPI EDM 900 and replace all of my primary instruments. I'll have a bunch of stuff to post for sale when I'm done with this install, but if anyone is interested in this engine monitor in the meantime, get in touch. I haven't looked into what it's worth, but I'm sure we can figure it out. I'll even include my customized screwdriver for installing the knobs. 2 Quote Link to comment Share on other sites More sharing options...
