bbakerco Posted November 21, 2020 Report Share Posted November 21, 2020 Just got the governor back from rebuild. Seems like the prop governor control arm is 180 degrees off. Cable comes from pilot side of firewall and with control arm in down orientation, pushing cable in pushes against spring which is Low rpm when it should be high rpm???? Quote Link to comment Share on other sites More sharing options...
PT20J Posted November 21, 2020 Report Share Posted November 21, 2020 You can change the orientation of the control arm by loosening the six screws on the back and rotating the assembly to the desired orientation. Skip 1 Quote Link to comment Share on other sites More sharing options...
bbakerco Posted November 21, 2020 Author Report Share Posted November 21, 2020 9 minutes ago, PT20J said: You can change the orientation of the control arm by loosening the six screws on the back and rotating the assembly to the desired orientation. Skip Really, that’s it? Don’t have to disassemble the unit? Quote Link to comment Share on other sites More sharing options...
bbakerco Posted November 21, 2020 Author Report Share Posted November 21, 2020 17 minutes ago, bbakerco said: Really, that’s it? Don’t have to disassemble the unit? Ah ha. I understand. Rotating it inner assembly with the screws loosened. That was easy. THANK YOU!!!!! Quote Link to comment Share on other sites More sharing options...
