rainman Posted November 20, 2020 Report Share Posted November 20, 2020 The Airpath Compass on my 1979 231 was leaking fluid. So my local shop got a repair kit and replaced the gaskets and fluid. I can’t recall how accurate it was before, but as soon as I got it reinstalled I noticed a problem. When he placed the compass back in the plane it was 30 degrees off when facing north, and the adjustment screw would not compensate for it. The compass is relatively accurate outside the plane(when not installed). My portable compass also showed the same deviation when placed in position inside the plane. Moving the compass around the interior showed significant compass swings near the center windscreen mounting post and other places near the front seat side window frames. My local guy tried to degauss the metal windscreen frame post where the compass mounts. No help. My safety frame appears to be magnetized? I have a G500 and two 430 Ws in my panel. What am I to do? I called Dugosh and my two local avionics shops, Pippen-York and Crystal Avionics, and no one can help. I live near San Antonio. Can I install a G5 and get rid on this compass? Thanks, Ray Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 20, 2020 Report Share Posted November 20, 2020 You need to find where it is magnetized and degauss it. It may not be the post, BTW the post isn't steel. I think there is a Mooney service bulletin about the procedure. https://cdn2.hubspot.net/hubfs/4147179/technical_documents/service_bulletins/sbm20-150a.pdf 1 1 Quote Link to comment Share on other sites More sharing options...
testwest Posted November 28, 2020 Report Share Posted November 28, 2020 We had this issue. The center post is non magnetic stainless steel, but our compass mounting bracket was regular carbon steel and highly magnetized! Replaced it with an aluminum bracket and non magnetic fasteners and the problem was solved. 1 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted November 28, 2020 Report Share Posted November 28, 2020 Seeing if @rainman is coming by... Norman (above) has outlined an interesting detail that may cause mg compasses to have challenges... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
testwest Posted November 28, 2020 Report Share Posted November 28, 2020 How magnetic? This magnetic: Magnetic Bracket.mp4 1 Quote Link to comment Share on other sites More sharing options...
OR75 Posted November 28, 2020 Report Share Posted November 28, 2020 what is for sure is that you cannot install a G5 and get rid of the whiskey compass I would find it surprising that the post would have become magnetized all of a sudden after the repaired compass was reinstalled my suggestions would be: 1) make sure you don't have something like an iphone/ipad near the compass 2) see if you can borrow a compass known to work and test it (short of buying a new one) Quote Link to comment Share on other sites More sharing options...
Raptor05121 Posted November 30, 2020 Report Share Posted November 30, 2020 (edited) I thought I made a post on here about it, but I had the same issue and had to degauss my plane. Here is my post from the Mooney Pilots Facebook group Edited November 30, 2020 by Raptor05121 3 Quote Link to comment Share on other sites More sharing options...
