Mooney down near Newton, UT
7 minutes ago, TTaylor said:
A few more details.  I thought maybe they decided to land gear up, but report says gear collapsed.
http://www.kathrynsreport.com/2020/11/incident-occurred-november-15-2020-near.html
Link to comment
Share on other sites
57 minutes ago, TTaylor said:
According to Bartschi, the two occupants of the plane turned off one of the plane’s engines to simulate an engine failure, but the engine wouldn’t start back up when the simulation was completed.
Gotta love that twin-engine Mooney M20B.  (The B stands for 'both engines')
  • Haha 2
Link to comment
Does anyone really practice engine out in a piston single by pulling the mixture and/or turning off the ignition?   I'm hesitant to assume that's what actually happened, particularly given the people reporting the events also seem two think the M20B is a twin.
Link to comment
Just now, DXB said:
Does anyone really practice engine in a piston single out by pulling the mixture and/or turning off the ignition?   I'm hesitant to assume that's what actually happened, particularly given the people reporting the events also seem two think the M20B is a twin.
Yeah, I was thinking that may just be newspaper "lost in translation".  Hopefully they didn't actually shut off the engine..
Link to comment
27 minutes ago, steingar said:
Takes a Darwin level of stupidity to take a simulated emergency and turn it into a real one.
Training accidents caused by "simulated" circumstances were extremely common in both the airlines and the military way back when.  These accidents spurred the development of very sophisticated and expensive simulators.  The training accident rate since simulators is now barely noteworthy.
Too bad there are not realistic and affordable Mooney full motion simulators.
Edited by Mooneymite
Link to comment
This American Airlines 707 training flight immediately came to mind.
https://en.wikipedia.org/wiki/American_Airlines_Flight_514
Link to comment
Yeah, but at least they didn't perform any of those death-defying touch and goes!
Link to comment
Did I miss where it said that was how the plane was shut down? Either way, I can also envision plugs fouling from prolonged operations with the throttle closed, the mags on and mixture rich. Plugs could foul during a engine out simulation for all the same reasons they do during ground operations.
There could have been any number of other failures that caused this problem, all unlikely under most circumstances.
There are several posts in this thread suggesting that these guys pooched this (not suggesting that yours is one of them). Seems to me that minor aircraft damage and unscathed occupants is a pretty reasonable outcome given how little is known about the circumstances.
Edited by Shadrach
  • Like 5
Link to comment
There could have been any number of other failures that caused this problem. All unlikely under most circumstances.
Original article says " the two occupants of the plane turned off one of the plane’s engines to simulate an engine failure" which is obviously absurd.  Like you, I see little reason here to jump to the conclusion these guys did anything wrong.
  • Confused 1
Link to comment
We always needs to apply the media translator...After reducing throttle to idle, we were unable to regain power ="Occupants turned off one of the plane's engines but it wouldn't start back up"...
  • Confused 1
Link to comment
