InJuRo Posted November 15, 2020 Report Share Posted November 15, 2020 Does anybody know, where to get the castle nut for the swivel joint 660051-3 as shown on the picture? Searched the web for quite a while now and found some used swivel joints but actually I'd only need the nut as mine as some "lost teeth". Ingo Quote Link to comment Share on other sites More sharing options...
PT20J Posted November 15, 2020 Report Share Posted November 15, 2020 I seem to recall some saying that this joint can be failure prone. My 1994 M20J has heim bearings on both mixture and throttle. See Note 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted November 16, 2020 Report Share Posted November 16, 2020 Somebody may know the answer, but not recognize the overall part being described... What swivel joint is this? Engine controls on an M20J as Skip mentioned? Or go direct to Lasar to get the specific nut... Talk to Dan... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
InJuRo Posted November 16, 2020 Author Report Share Posted November 16, 2020 Thank you for your answers. It is the swivel joint of a M20E which ist used to connect Mixture and Power Lever to the fuel injection unit. Checkten the Lasar-Webpage but did not find that part. Will write to Dan and check the alternative. Ingo 1 Quote Link to comment Share on other sites More sharing options...
Rjfanjet Posted November 16, 2020 Report Share Posted November 16, 2020 I had to replace that on my throttle. LASAR has the replacement. Quote Link to comment Share on other sites More sharing options...
carusoam Posted November 17, 2020 Report Share Posted November 17, 2020 Ingo, When you get a chance... Update the data fields for your avatar... add a pic... There is a place for adding model of your plane and where you are located... it will help you out some.... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
