jaylw314 Posted October 24, 2020 Report Share Posted October 24, 2020 Why is it that Mooney's are at JUST the right height so that when you walk around the front, the spinner jams you right in the nipple. You think I'd learn. Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 24, 2020 Report Share Posted October 24, 2020 There is an STC for that... you buy it from the local surgeon... -a- 2 Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted October 24, 2020 Report Share Posted October 24, 2020 10 minutes ago, carusoam said: There is an STC for that... you buy it from the local surgeon... -a- Stc elevator shoes. 2 Quote Link to comment Share on other sites More sharing options...
MooneyMitch Posted October 24, 2020 Report Share Posted October 24, 2020 35 minutes ago, jaylw314 said: Why is it that Mooney's are at JUST the right height so that when you walk around the front, the spinner jams you right in the nipple. You think I'd learn. Could be worse........ you could run into the tow tug handle with another body part.... 1 1 Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted October 25, 2020 Report Share Posted October 25, 2020 On 10/23/2020 at 10:14 PM, MooneyMitch said: Could be worse........ you could run into the tow tug handle with another body part.... 6 foot 9 Lurch on the Addams Family could quickly be turned into Cousin It on the Addams Family.. 1 Quote Link to comment Share on other sites More sharing options...
Davidv Posted October 26, 2020 Report Share Posted October 26, 2020 (edited) When Mooney went from the TLS to the Ovation they moved the height of spinner tip down 1 inch. Apparently it was 1 inch too high to hit you in just the right spot . Say what you want, the dimension difference in the propeller or engine had nothing to do with it... Edited October 26, 2020 by Davidv Quote Link to comment Share on other sites More sharing options...
steingar Posted October 26, 2020 Report Share Posted October 26, 2020 The only Mooney design flaws I've seen are the fuel switch you have to pleasure yourself to use and the ten zillion screws holding on all the panels. 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted October 26, 2020 Report Share Posted October 26, 2020 Maybe the Mooney is perfect and you are flawed? 2 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted October 26, 2020 Report Share Posted October 26, 2020 On 10/23/2020 at 9:36 PM, jaylw314 said: Why is it that Mooney's are at JUST the right height so that when you walk around the front, the spinner jams you right in the nipple. You think I'd learn. Your the guy that bangs his shin on the trailer hitch aren’t you.... 2 Quote Link to comment Share on other sites More sharing options...
rbridges Posted October 26, 2020 Report Share Posted October 26, 2020 This one has the STC that lowers the height to avoid nipple impacts. The down side is that it requires a longer roll out. 2 Quote Link to comment Share on other sites More sharing options...
tmo Posted October 26, 2020 Report Share Posted October 26, 2020 49 minutes ago, rbridges said: The down side is that it requires a longer roll out. But shortens landing distance if performed correctly. 1 Quote Link to comment Share on other sites More sharing options...
MooneyMitch Posted October 26, 2020 Report Share Posted October 26, 2020 12 minutes ago, tmo said: But shortens landing distance if performed correctly. And no need for the step to exit aircraft. 2 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted October 26, 2020 Report Share Posted October 26, 2020 A guy on the field “had” that STC on his BO, requires a lot of Hp to taxi Quote Link to comment Share on other sites More sharing options...
