Mooney design flaw
jaylw314
35 minutes ago, jaylw314 said:
Why is it that Mooney's are at JUST the right height so that when you walk around the front, the spinner jams you right in the nipple.
You think I'd learn.
Could be worse........ you could run into the tow tug handle with another body part....:o
  • Confused 1
Link to comment
Share on other sites
When Mooney went from the TLS to the Ovation they moved the height of spinner tip down 1 inch.  Apparently it was 1 inch too high to hit you in just the right spot :) .  Say what you want, the dimension difference in the propeller or engine had nothing to do with it...
Edited by Davidv
Link to comment
Your the guy that bangs his shin on the trailer hitch aren’t you.... :D
  • Haha 2
Link to comment
