Rjfanjet Posted October 18, 2020 Report Share Posted October 18, 2020 Is there an easy way to get to this? I can't find any pictures. My mechanic and I got the flap pump out and sent to Dan at LASAR. My flaps were stuck in the down position. When we bled the lines, we found brass in the fluid. Is the slave just O rings do replace? Thanks 1968 M20C Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted October 18, 2020 Report Share Posted October 18, 2020 1 hour ago, Rjfanjet said: Is there an easy way to get to this? I can't find any pictures. My mechanic and I got the flap pump out and sent to Dan at LASAR. My flaps were stuck in the down position. When we bled the lines, we found brass in the fluid. Is the slave just O rings do replace? Thanks 1968 M20C If it was easy, it wouldn’t be a Mooney! 1 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted October 18, 2020 Report Share Posted October 18, 2020 I did mine a few years back, I don’t remember it being all that difficult 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted October 18, 2020 Report Share Posted October 18, 2020 Assuming that your maintainer doesn’t have manuals for your plane. Quote Link to comment Share on other sites More sharing options...
Rjfanjet Posted October 18, 2020 Author Report Share Posted October 18, 2020 Thanks! I have the parts manual, assume I just have to take off the belly panel to get to it. Quote Link to comment Share on other sites More sharing options...
47U Posted October 18, 2020 Report Share Posted October 18, 2020 (edited) 1 hour ago, Rjfanjet said: Thanks! I have the parts manual, assume I just have to take off the belly panel to get to it. These two panels, unless you have a one-piece belly panel and the original riveted panel was removed. Don’t loose any of the washers centering the forward end of the actuator in the mount. Sabermech posted a picture of the belly access with the one-piece belly panel. THAT’S the way to go. Edited October 18, 2020 by 47U Additional info. Quote Link to comment Share on other sites More sharing options...
Rjfanjet Posted October 18, 2020 Author Report Share Posted October 18, 2020 Thanks! Don’t have the one piece belly. Access panels look easy. Quote Link to comment Share on other sites More sharing options...
M20C Tommy Posted October 24, 2020 Report Share Posted October 24, 2020 On 10/17/2020 at 9:31 PM, Rjfanjet said: Is there an easy way to get to this? I can't find any pictures. My mechanic and I got the flap pump out and sent to Dan at LASAR. My flaps were stuck in the down position. When we bled the lines, we found brass in the fluid. Is the slave just O rings do replace? Thanks 1968 M20C On 10/18/2020 at 8:15 AM, M20Doc said: Assuming that your maintainer doesn’t have manuals for your plane. I have a 65 M20C and had a similar experience. Theres another schematic that shows all the access panels. (I dont have the drawing on hand but I could find it for the exact number panel) If you go under the plan on the passenger side right under the front passenger seat, thats the access panel for the flap pump. (On this drawing thats shared, part 1 located near "cabin tubular structure ref". Remember your oil for your flaps is also the oil for your brakes. Quote Link to comment Share on other sites More sharing options...
Rjfanjet Posted October 24, 2020 Author Report Share Posted October 24, 2020 Thanks for all the help! Didn't need to rebuild the slave cylinder, but did follow the procedure for bleeding the system. 1 Quote Link to comment Share on other sites More sharing options...
Nukemzzz Posted November 3, 2020 Report Share Posted November 3, 2020 On 10/17/2020 at 9:31 PM, Rjfanjet said: Is there an easy way to get to this? I can't find any pictures. My mechanic and I got the flap pump out and sent to Dan at LASAR. My flaps were stuck in the down position. When we bled the lines, we found brass in the fluid. Is the slave just O rings do replace? Thanks 1968 M20C Brass in the fluid? Any clue on where it came from? I don’t remember any brass anything in my system. Quote Link to comment Share on other sites More sharing options...
Rjfanjet Posted November 3, 2020 Author Report Share Posted November 3, 2020 It was a broken spring in the flap pump. LASAR found it when they rebuilt the pump. Quote Link to comment Share on other sites More sharing options...
