KAP 150 Altitude Preselect retrofit
flyboy0681
I'm having a GI-275 ADI installed in a few weeks and am wondering the following. I've always wanted the KAS-297 altitude preselect feature but knew that it required the King KEA-130A encoded altimeter, so I never pursued it.
So question, does the GI-275 emulate the same output as the KEA-130A, finally allowing me to purchase and have a KAS-297 installed? Better question, is retrofitting to an existing KAP 150 even possible or does the head unit itself require a certain built-in feature allowing the interface to take place?
Link to comment
Share on other sites
1 hour ago, Greg_D said:
I have wondered the same thing.  I don't think you'd need the KAS-297 with this setup though.  Isn't the altimeter and altitude pre-select built into the GI-275?
The only material that I can find on the subject states that the preselect only works with the Garmin GFC units.
Link to comment
I believe the numbers will show it makes zero sense to install the KAS-297 unit when it will greatly subsidize the cost the cost for a new GFC-500 AP.  Not only will you have the acquisition and install cost you'll have to maintain those parts going forward - just move to a modern digital AP and get VNAV too; especially with only the KAP-150 with out flight director.
Link to comment
There are two notes in the installation manual.
1. If the Altitude encoder is replaced by the GI 275 to provide a baro-corrected altitude, the autopilot needs to be recalibrated to the new source.
2.  If the encoding altimeter is removed, and blind encoder is required to create the gray code output for autopilot.
Link to comment
Your point is well taken, however, used KAS-297 units are dirt cheap now and can be had for less than $500. GFC-500's cost 10x that without installation. If a -297 could be installed then it would seem like a no brainer. The operative word being "if".
Link to comment
Are you referring to the section of the -297 manual "KEA 130A/KAS 297 ALIGNMENT"?
Link to comment
It is outlined in the install manual.  This process involves making a test harness for Autopilot and then making various adjustments to the potentiometers in the autopilot.  It is a bit of a process.
There is also a configuration table that outlines all the settings for the GI-275 based on the autopilot type.
Link to comment
Sounds like those upgrading to a GI-275 who already have a KAS-297 will need to go through these steps, no?
Link to comment
After the new device driving the autopilot is replaced pitch and roll centering will sometimes need a slight readjustment. Also the installation requires verification of proper functionality of the autopilot prior to doing the upgrade.
Link to comment
