prestonvanloon Posted October 3, 2020 Report Share Posted October 3, 2020 (edited) I'm looking to get a replacement door key for my M20J. The ignition key is different from the door lock and I do not have a copy of the original keys for the doors. The door lock has "LL328" written on it. I checked with a friend that also has a M20J with the same lock inscribed with "LL328" and their key did not turn the lock. I tried ordering a Herman Miller replacement key for LL328 since it uses the same IN8 key blank. This did not work either. (See attached photo with the Herman Miller key in the door) The lock does turn, I was able to pick the lock with basic lock picking tools. Without taking the lock out of the door(s) and disassembling the lock, is there another way to manufacture or order a replacement key? Edited October 3, 2020 by prestonvanloon Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 3, 2020 Report Share Posted October 3, 2020 Search on medeco lock keys... https://mooneyspace.com/search/?q=Medeco&quick=1 -a- Quote Link to comment Share on other sites More sharing options...
Hank Posted October 4, 2020 Report Share Posted October 4, 2020 (edited) That doesn't look like a Medeco key, more like the standard filing cabinet keys like on my C. Be happy if your J only has two keys--my C has three, which I color-code: Blue for bags (baggage door) Green for go (people door) Red for fire (ignition) I have copies made at the locksmith. Edited October 4, 2020 by Hank Quote Link to comment Share on other sites More sharing options...
buddy Posted October 4, 2020 Report Share Posted October 4, 2020 Medeco keys are usually just used as an ignition key (late models) which you would have to by from Mooney once you give them the number on the key. The key for the door and baggage is just a simple key the can be made by a locksmith. I would ask a locksmith if he can make you a replacement key if you give him the lock mechanism. Quote Link to comment Share on other sites More sharing options...
Hank Posted October 4, 2020 Report Share Posted October 4, 2020 22 minutes ago, buddy said: Medeco keys are usually just used as an ignition key (late models) which you would have to by from Mooney once you give them the number on the key. The key for the door and baggage is just a simple key the can be made by a locksmith. I would ask a locksmith if he can make you a replacement key if you give him the lock mechanism. That would be the time to make the door key match the ignition! Give him the door lock and the ignition key, and buy several keys. My sets: regular use; wife's set; mechanic's set; loaner set when I need work done elsewhere, tagged with my N number; spare set in the car; and two spare sets at home, just in case. Quote Link to comment Share on other sites More sharing options...
Davidv Posted October 4, 2020 Report Share Posted October 4, 2020 I bought a new set of Medeco locks to replace the traditional "filing cabinet" ones as @carusoamsays. Unlike Medeco, the traditional ones are incredibly easy for anyone to pick or even use an identical one (there are only so many patterns they used). I'm not replacing my ignition but rather the two locks on the outside. 2 Quote Link to comment Share on other sites More sharing options...
tmo Posted October 4, 2020 Report Share Posted October 4, 2020 3 hours ago, Hank said: My sets: regular use; wife's set; mechanic's set; loaner set when I need work done elsewhere, tagged with my N number; spare set in the car; and two spare sets at home, just in case. None hidden in the gear well or thereabouts? ;-) Quote Link to comment Share on other sites More sharing options...
Hank Posted October 4, 2020 Report Share Posted October 4, 2020 36 minutes ago, tmo said: None hidden in the gear well or thereabouts? ;-) Not on the plane. Maybe inside the hangar . . . And yes, I've had to use my wife's keys before, when I got to the airport without mine. 1 Quote Link to comment Share on other sites More sharing options...
prestonvanloon Posted October 4, 2020 Author Report Share Posted October 4, 2020 21 hours ago, Hank said: That doesn't look like a Medeco key, more like the standard filing cabinet keys like on my C. Be happy if your J only has two keys--my C has three, which I color-code: Blue for bags (baggage door) Green for go (people door) Red for fire (ignition) I have copies made at the locksmith. I was able to impression the lock and make a new key for the cargo door. It looks like I also have 3 different keys... I ran out of time to make a key for the main door but I was disappointed to learn the cargo door key did not turn the main door lock. Great idea on the color codes! Quote Link to comment Share on other sites More sharing options...
prestonvanloon Posted October 4, 2020 Author Report Share Posted October 4, 2020 9 hours ago, Hank said: That would be the time to make the door key match the ignition! Give him the door lock and the ignition key, and buy several keys. My sets: regular use; wife's set; mechanic's set; loaner set when I need work done elsewhere, tagged with my N number; spare set in the car; and two spare sets at home, just in case. I thought about re-pinning the door locks to match the ignition but I was having a hard time getting the lock off the cargo door and I didn’t try the main door yet. I suppose I can live with 3 different keys Quote Link to comment Share on other sites More sharing options...
prestonvanloon Posted October 4, 2020 Author Report Share Posted October 4, 2020 8 hours ago, Davidv said: I bought a new set of Medeco locks to replace the traditional "filing cabinet" ones as @carusoamsays. Unlike Medeco, the traditional ones are incredibly easy for anyone to pick or even use an identical one (there are only so many patterns they used). I'm not replacing my ignition but rather the two locks on the outside. I can confirm. It took me about 30 seconds to pick the lock with a rake pick lol I don’t park the plane outside often, but I’d like to at least deter a handle puller while on a short stop or overnight parking Quote Link to comment Share on other sites More sharing options...
KB4 Posted October 5, 2020 Report Share Posted October 5, 2020 22 hours ago, prestonvanloon said: I thought about re-pinning the door locks to match the ignition but I was having a hard time getting the lock off the cargo door and I didn’t try the main door yet. I suppose I can live with 3 different keys baggage door is easy just remove the trim on inside--10 or so little screws that's it. Quote Link to comment Share on other sites More sharing options...
kortopates Posted October 5, 2020 Report Share Posted October 5, 2020 22 hours ago, mike261 said: the factory has them. i called and they sent them in a few days. Mike Not for folks that have different keys on different locks - the factory will have the original key but the cheap Chicago locks get replaced all the time without re-pinning to the original key. Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted October 5, 2020 Report Share Posted October 5, 2020 I replaced both the baggage door and cabin door locks with a set of Medeco locks. It's nice having one key for both doors, and good quality locks. I'd like to replace the ignition key with a button. Quote Link to comment Share on other sites More sharing options...
Jerry Pressley Posted October 5, 2020 Report Share Posted October 5, 2020 if you don't have door or baggage door keys the cheapest thing is to run by Lowes and for a couple dollars you can pick up identical drawer locks with keys. 1 Quote Link to comment Share on other sites More sharing options...
hypertech Posted October 5, 2020 Report Share Posted October 5, 2020 Most any locksmith can make you one. Or, you can use the keycode in the picture you posted to order one from the internet. Where is that plane parked and do you keep anything good in it?...... 1 Quote Link to comment Share on other sites More sharing options...
