Martin S. Posted July 21, 2020 Report Share Posted July 21, 2020 Dear all. Anybody an idea whether the stains in the marked area also originate from the obviously leaky valve drain port or rather from a broken sealant inside the tank? Greets from Germany Martin Quote Link to comment Share on other sites More sharing options...
RLCarter Posted July 21, 2020 Report Share Posted July 21, 2020 Start with the easy one and replace the sump and/or o-ring, if leak continues it might be time for a tank seal 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted July 21, 2020 Report Share Posted July 21, 2020 Dear all. Anybody an idea whether the stains in the marked area also originate from the obviously leaky valve drain port or rather from a broken sealant inside the tank? Greets from Germany Martin I agree. Change out the fuel drain first. I saw a lot of fuel around mine and when I changed it out, it stopped the leak. The drains are not that expensive. Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted July 21, 2020 Report Share Posted July 21, 2020 I agree. Change out the fuel drain first. I saw a lot of fuel around mine and when I changed it out, it stopped the leak. The drains are not that expensive. Sent from my iPhone using Tapatalk Pro Is there suppose to be a rubber gasket on them? Quote Link to comment Share on other sites More sharing options...
StevenL757 Posted July 21, 2020 Report Share Posted July 21, 2020 Agree. The gaskets on those valves aren’t yet made of fluorosilicone, and leak frequently as the rubber breaks down. I bought about 5 or 6 valves a couple of years ago and change them out when I see leaks starting. Quote Link to comment Share on other sites More sharing options...
kortopates Posted July 22, 2020 Report Share Posted July 22, 2020 To me, looks like Fuel is or was coming from sump drain as well as the inspection panel screw. Just wipe off the fresh blue stain from the screw and see how long it takes to return. Still worst case fix isn't a reseal but just a re-seal of the leaky screw - but see how long it takes to stain - since it looks very minor. Personally I'd clean the area real well around the sump drain first and see how long it takes to blue stain as well. Its so dirty there you can't really tell if that is fresh stain or not. A bit of avgas on a towel will easily clean it up. If and when replacing a sump drain be very careful to not overly torque it, (follow your MM instructions) doing so will create a much worse leak 4 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 22, 2020 Report Share Posted July 22, 2020 Hey Martin! Looks like you have both solutions that you are asking about... 1) Inspection panel screw leaks are pretty common... easy to fix... might start with a new screw and clean threads to improve the ability to fix it once.... 2) Drain sumps don’t last forever... the rubber seal is often carved into the head of the drain device... a very light torque holds it in place... anything more snaps it off in the hole.... expect that there are two seals internal and external... Make sure you get the proper drain device for your plane... there are several versions... that look similar... As you can see in the pics by Marauder... there Can be a difference in height of the drain holes.... The height of theses holes from the sealing surface dictates how much water gets left in the tank, after draining... Some Mooneys have a different internal tank structure that these drain holes have to be above... the holes need to be above the structure to allow the Fuel/water out... This is a great first fuel leak project... high probability of quick success... Pp thoughts only, not a mechanic... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Missile=Awesome Posted July 22, 2020 Report Share Posted July 22, 2020 (edited) 15 hours ago, ArtVandelay said: Is there suppose to be a rubber gasket on them? Deleted because I am not Clarence. Great photo below with part number. My question is: Does the valve change for different vintage planes based on tank size/configuration? Is this the valve for WHAT models of Mooney’s or ALL Mooney’s? Edited July 22, 2020 by Missile=Awesome Quote Link to comment Share on other sites More sharing options...
Martin S. Posted July 22, 2020 Author Report Share Posted July 22, 2020 Thanks everybody for your comments, appreciate it! Quote Link to comment Share on other sites More sharing options...
Guest Posted July 22, 2020 Report Share Posted July 22, 2020 (edited) Martin, Clean the area with Acetone or some nail polish remover borrowed from your wife, it will remove the old stains. Roll some toilet tissue into a point and use it to dab around the area to find the source of the leak. Sometimes very small amounts of fuel are hard to see on white paint, tissue paper helps. The O ring under the valve is normally an MS29513-014, the valve is an F391-53S. Drain valve torque is 40-65 inch pounds, from SB M20-188 The valve on the left is the correct one, the Center is the nut which is in the wing tank, the valve on the right is the wrong one. Clarence Edited July 22, 2020 by M20Doc Quote Link to comment Share on other sites More sharing options...
mike_elliott Posted July 22, 2020 Report Share Posted July 22, 2020 The rivets that secure the nut shown in the center of Clarence's photo can leak when the quick drain is over torqued also. One's first tendency upon discovering a weep is to put that wrench on it and give it a tug...dont do it. 1 Quote Link to comment Share on other sites More sharing options...
tigers2007 Posted July 22, 2020 Report Share Posted July 22, 2020 If you ever want to “rebuild” one, the kit consists of two o rings and new clip. Like others mentioned, I do not think the o rings in the kit are even Viton which is mindblowing considering the price of the kit. Maybe our [mention]OSUAV8TER [/mention] friend can compete with a similar kit that uses Viton. 1 Quote Link to comment Share on other sites More sharing options...
Missile=Awesome Posted July 22, 2020 Report Share Posted July 22, 2020 (edited) 3 hours ago, M20Doc said: Martin, Clean the area with Acetone or some nail polish remover borrowed from your wife, it will remove the old stains. Roll some toilet tissue into a point and use it to dab around the area to find the source of the leak. Sometimes very small amounts of fuel are hard to see on white paint, tissue paper helps. The O ring under the valve is normally an MS29513-014, the valve is an F391-53S. Drain valve torque is 40-65 inch pounds, from SB M20-188 The valve on the left is the correct one, the Center is the nut which is in the wing tank, the valve on the right is the wrong one. Clarence O.K. What is the first valve that was shown Clarence? Is that a valve for a vintage Pre-J Mooney? I replaced valves on ‘66 and that valve did NOT have the rubber gasket as shown in these photos. This is great information. Thank you. Edited July 22, 2020 by Missile=Awesome Quote Link to comment Share on other sites More sharing options...
cliffy Posted July 22, 2020 Report Share Posted July 22, 2020 7 minutes ago, Missile=Awesome said: O.K. What is the first valve that was shown Clarence? Is that a valve for a vintage Pre-J Mooney? I replaced valves on ‘66 and that valve did NOT have the rubber gasket as shown in these photos. This is great information. Thank you. Check the IPC (parts catalog) It shows just what is pictured here- a drain valve and an O-ring just as he describes. Quote Link to comment Share on other sites More sharing options...
Marauder Posted July 22, 2020 Report Share Posted July 22, 2020 49 minutes ago, cliffy said: Check the IPC (parts catalog) It shows just what is pictured here- a drain valve and an O-ring just as he describes. Good point on checking the parts catalog. And for reference, the drain pictures I provided above are the aftermarket drains for the O&N bladder system. 2 Quote Link to comment Share on other sites More sharing options...
Missile=Awesome Posted July 22, 2020 Report Share Posted July 22, 2020 2 hours ago, cliffy said: Check the IPC (parts catalog) It shows just what is pictured here- a drain valve and an O-ring just as he describes. Cliffey, My question has NOT been answered. The original poster didn’t identify what model his plane was. NOT every owner has a parts catalog for their model...That’s why they come to Mooneyspace with a question. 1. The first valve (after later clarification) photo is for a bladder on ? Mooney models. 2. Second (Left valve) is for what Model and tank capacity? This stuff can make a huge difference when you are trying to get the “right” part. My take away is that parts diagrams on line often don’t have good detail and get me a clear “answer” to my question. Second take-away, Parts guys at Mooney Service Centers are invaluable. Thanks for your reply. Quote Link to comment Share on other sites More sharing options...
Missile=Awesome Posted July 22, 2020 Report Share Posted July 22, 2020 Anyone have a good copy of a 1980 J Parts Manual or suggestion on where to obtain said manual? Quote Link to comment Share on other sites More sharing options...
EricJ Posted July 22, 2020 Report Share Posted July 22, 2020 2 hours ago, Missile=Awesome said: Anyone have a good copy of a 1980 J Parts Manual or suggestion on where to obtain said manual? The very first google hit of "Mooney M20J IPC":http://mooney.free.fr/Manuels M20J/M20J/Mooney M20J Illustrated Parts Catalog.pdf 1 1 Quote Link to comment Share on other sites More sharing options...
David Lloyd Posted July 22, 2020 Report Share Posted July 22, 2020 I recently replaced a drain valve in my 1975 M20C with bladder tanks. I think the number was F391-18. Looks very similar to the left valve in the first picture. I asked Griggs for the number before finding it listed on the drawing. While talking with him, I looked the number up on the Aircraft Spruce site. Asked about the O-ring and he said it used no O-ring like the picture at Spruce. Then I realized the -18 was the 1/8" NPT that seals on the threads, not by O-ring. Not much taper on the 1/8", I didn't even notice. In the end, check you part numbers every time. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted July 22, 2020 Report Share Posted July 22, 2020 6 hours ago, Missile=Awesome said: O.K. What is the first valve that was shown Clarence? Is that a valve for a vintage Pre-J Mooney? I replaced valves on ‘66 and that valve did NOT have the rubber gasket as shown in these photos. This is great information. Thank you. The left valve is the standard valve used on all models, other than early one’s. Early models had riveted valves which are no longer available and are replaced with SB M20-188 kit, which are also getting harder to find. Clarence Quote Link to comment Share on other sites More sharing options...
Guest Posted July 22, 2020 Report Share Posted July 22, 2020 7 hours ago, tigers2007 said: If you ever want to “rebuild” one, the kit consists of two o rings and new clip. Like others mentioned, I do not think the o rings in the kit are even Viton which is mindblowing considering the price of the kit. Maybe our [mention]OSUAV8TER [/mention] friend can compete with a similar kit that uses Viton. There is no rebuilding of these valves, they were never meant to be repaired. Note that the upper end is pinched closed, if you try to un-pinch it, it will crack. Clarence Quote Link to comment Share on other sites More sharing options...
tigers2007 Posted July 23, 2020 Report Share Posted July 23, 2020 There is no rebuilding of these valves, they were never meant to be repaired. Note that the upper end is pinched closed, if you try to un-pinch it, it will crack. Clarence But there is a “seal kit” for $3. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 23, 2020 Report Share Posted July 23, 2020 I don’t see how you’d use that kit on an F391-53S as used in a Mooney? Clarence Quote Link to comment Share on other sites More sharing options...
tigers2007 Posted July 23, 2020 Report Share Posted July 23, 2020 Just now, M20Doc said: I don’t see how you’d use that kit on an F391-53S as used in a Mooney? Clarence That is correct. Its for a SA18 valve. I just read McFarlane's web site and the kit actually does come with a Viton o-ring. My bladders have the SA18 valve. Quote Link to comment Share on other sites More sharing options...
MB65E Posted July 23, 2020 Report Share Posted July 23, 2020 Wagaero sells a kit for the S53 valve. I just replaced mine. They come with 2 orings and the new c clip. When I disassembled mine I found the clip was not installed properly internally from safe-air. :-0 I just bought a few extra kits to have on hand. -Matt Quote Link to comment Share on other sites More sharing options...
