FastTex Posted July 21, 2020 Report Share Posted July 21, 2020 I remember some time ago I saw a Cessna 210 with a carbon fiber panel overlay which was very easy to install (according to the owner). Does anyone know of something similar for our Mooneys? I did some search but I didn't find much... Thanks. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted July 21, 2020 Report Share Posted July 21, 2020 1 hour ago, FastTex said: I remember some time ago I saw a Cessna 210 with a carbon fiber panel overlay which was very easy to install (according to the owner). Does anyone know of something similar for our Mooneys? I did some search but I didn't find much... Thanks. My hangar neighbor made one for his Comanche, he ordered the faux carbon fiber off the net. Quote Link to comment Share on other sites More sharing options...
FastTex Posted July 21, 2020 Author Report Share Posted July 21, 2020 How did it turn out? Does it look good? The one I saw was pretty cool with a very professional appearance... Quote Link to comment Share on other sites More sharing options...
RLCarter Posted July 21, 2020 Report Share Posted July 21, 2020 5 hours ago, FastTex said: How did it turn out? Does it look good? The one I saw was pretty cool with a very professional appearance... It looked good, it was a dark redish weave which went good with his interior, not sure on cost or time. I've also seen vinyl adhesive sheets used that turned out good, although it wasn't on an aircraft panel Quote Link to comment Share on other sites More sharing options...
RLCarter Posted July 21, 2020 Report Share Posted July 21, 2020 I will add that if you have multiple pieces/panels make sure that the weave orientation is the same when installed or it won’t look right Quote Link to comment Share on other sites More sharing options...
FastTex Posted July 21, 2020 Author Report Share Posted July 21, 2020 Thanks. It would be great to know if anyone else in this forum has tried similar experiments! Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 22, 2020 Report Share Posted July 22, 2020 Find the YouTube video... For the most part people use a decal material to put on the surface... The work is getting to the surface... Great if the panel is out on a bench... Not so good if the panel is in the plane full of instruments... For a real carbon fiber finish... the Draco guy (Mike Patey) just built a plane using carbon fiber covers... with clear finish... That would make a really nice instrument panel, and save weigh too... The plane is called Scrappy (it’s not technically done yet)... steel tube structure similar to a Mooney, getting carbon fiber covers and a parachute fully integrated into the build... Hmmmmmm...... PP thoughts only... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
kmyfm20s Posted July 23, 2020 Report Share Posted July 23, 2020 Seems like you could buy some of these panel and have it cut out. https://hillsidecomposites.com/products/standard-cf-plate?variant=31998689673298 Quote Link to comment Share on other sites More sharing options...
FastTex Posted July 23, 2020 Author Report Share Posted July 23, 2020 I was thinking something similar...get some panels and cut them out. Then overlay them on the panel. Quote Link to comment Share on other sites More sharing options...
wcb Posted July 23, 2020 Report Share Posted July 23, 2020 most people I think are not doing a actual carbon fiber. I think they are doing more of a vinyl covering. Basically remove all your old black vinyl and replace it with new vinyl of your choosing. 2 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted July 23, 2020 Report Share Posted July 23, 2020 Spoke to my neighbor and asked how he went about it, if was an original overlay he make a new one from the carbon fiber sheet, if it was a painted panel he wrapped it in vinyl with a carbon fiber print. He couldn’t remember where he got the materials but the fuax sheet and vinyl was from the same supplier so the color and patterns matched Quote Link to comment Share on other sites More sharing options...
Hank Posted July 23, 2020 Report Share Posted July 23, 2020 My plastic overlay broke into 3 pieces when it was removed. I'm slowly making a new one, but have been unable to find drawings showing hole locations. So it's a lot of trial and error. Since it's just a cosmetic cover, Owner Produced is the way to go. Use whatever you want, keeping in mind the CAR3 requirements. Quote Link to comment Share on other sites More sharing options...
FastTex Posted July 25, 2020 Author Report Share Posted July 25, 2020 On 7/23/2020 at 8:02 AM, wcb said: most people I think are not doing a actual carbon fiber. I think they are doing more of a vinyl covering. Basically remove all your old black vinyl and replace it with new vinyl of your choosing. Your panel is neat and clean (really cool, BTW), mine is very busy and it doesn't look like I have any plastic overlay. I'm not sure I want to undo all the screws. I was thinking to overlay a 1mm or 1.5mm of carbon fiber and fit it with trial and error drilling holes for the instruments and the screws. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted July 25, 2020 Report Share Posted July 25, 2020 Just now, FastTex said: Your panel is neat and clean (really cool, BTW), mine is very busy and it doesn't look like I have any plastic overlay. I'm not sure I want to undo all the screws. I was thinking to overlay a 1mm or 1.5mm of carbon fiber and fit it with trial and error drilling holes for the instruments and the screws. You can use plexiglass (so you can see where things) to make a template, much cheaper than carbon fiber. 2 Quote Link to comment Share on other sites More sharing options...
wcb Posted July 25, 2020 Report Share Posted July 25, 2020 2 hours ago, FastTex said: Your panel is neat and clean (really cool, BTW), mine is very busy and it doesn't look like I have any plastic overlay. I'm not sure I want to undo all the screws. I was thinking to overlay a 1mm or 1.5mm of carbon fiber and fit it with trial and error drilling holes for the instruments and the screws. And when I did mine I made sure to pre-plan for the new Garmin Autopilot to go in right above the audio panel. We put in the rack and simply made a cover for the hole. Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted July 25, 2020 Report Share Posted July 25, 2020 my opinion, of course....flat black looks much better.....the carbon fiber look is to busy looking.....especially when it is going in different directions.... Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted July 25, 2020 Report Share Posted July 25, 2020 I covered all the wood grain panels in my BMW in this wrap. It is very subtle and looks great. https://www.amazon.com/gp/product/B00YLFUFLY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Quote Link to comment Share on other sites More sharing options...
bradp Posted July 25, 2020 Report Share Posted July 25, 2020 I’d really like to see someone try the mike patey method for an instrument panel namely ... structure is just CF layers as a plate would need to CNC that plate Bodywork (ie sanding) and micro until voids are gone one last layer of “cosmetic” CF peel plied for a unidirectional weave. vinyl labeling goes over clear coated to “embed” the lettering in a smooth face. 1 Quote Link to comment Share on other sites More sharing options...
wcb Posted July 26, 2020 Report Share Posted July 26, 2020 12 hours ago, Jim Peace said: my opinion, of course....flat black looks much better.....the carbon fiber look is to busy looking.....especially when it is going in different directions.... I like the flat grey as well.... In my picture above the only reason that one section is going in the wrong direction is that is a plate cover for where we have already placed the rack for the Garmin GFC 500. Quote Link to comment Share on other sites More sharing options...
G Miller Posted July 27, 2020 Report Share Posted July 27, 2020 I wrote an article for the July 2016 issue of the Mooney Flyer describing my panel overlay upgrade. You may find the attached article of interest. article.pdf 2 Quote Link to comment Share on other sites More sharing options...
FastTex Posted July 27, 2020 Author Report Share Posted July 27, 2020 9 hours ago, G Miller said: I wrote an article for the July 2016 issue of the Mooney Flyer describing my panel overlay upgrade. You may find the attached article of interest. article.pdf 415.24 kB · 7 downloads That is great! Thanks for the info. It doesn't look like I have a plastic overlay plus my panel looks very busy with lots of screws (see pic, sorry for the bad light...). Do you guys think I can add an aluminum overlay like Gary did? On a separate note, maybe we should write an article on how to cover the yokes with about $20! Not perfect, but it looks clean and it will be better next time. Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 27, 2020 Report Share Posted July 27, 2020 For next time... Find where Peter Garmin put his own leather on his yokes... Not a lot of Money, but a good bit of skill has to be there... Peter must have good fine motor skills, and strong cognitive abilities, to see what needsEd to be done, and then got it done... As for adding aluminum overlay...? There is a sheet of aluminum that is the panel... That sheet gets finished any way you like... Or refinished anyway you like... Remove old finish, apply new... Lots of work involved... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
