201Steve Posted July 16, 2020 Report Share Posted July 16, 2020 Can anyone advise what the static RPM should be for a 77j with IO360-A1B6D ? Or where one would find the data? Thanks Quote Link to comment Share on other sites More sharing options...
EricJ Posted July 16, 2020 Report Share Posted July 16, 2020 Chapter 61 in the SMM (Propellers) sez takeoff RPM is 2700 and static can be 50 below that (61-20-20). Depending on who you talk to, 70-100 rpm less than redline is not unusual for static runup. 3 Quote Link to comment Share on other sites More sharing options...
corn_flake Posted July 17, 2020 Report Share Posted July 17, 2020 If you have Mccauley prop. Static run should be 100 rpm within redline, or above 2600. 1 1 Quote Link to comment Share on other sites More sharing options...
201Steve Posted July 17, 2020 Author Report Share Posted July 17, 2020 Thanks fellas! Quote Link to comment Share on other sites More sharing options...
corn_flake Posted July 17, 2020 Report Share Posted July 17, 2020 Are you able to get to 2600 rpm on static run? There are few others here that can't get to 2600. I was able to get to 2578 after aggressive leaning of mixture. Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 18, 2020 Report Share Posted July 18, 2020 Reference of the day award goes to... Flake! That’s a good one. Thanks for posting it. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
J0nathan225 Posted October 2, 2020 Report Share Posted October 2, 2020 What about or where do I look for the static rpm for a 64mooney m29e with a 2 blade scimitar? Just had an IRAN on the prop and it seems alittle off I don’t make 2700 until I’m 100’ in the air. Quote Link to comment Share on other sites More sharing options...
PT20J Posted October 2, 2020 Report Share Posted October 2, 2020 Here' a good explanation from McCauley: Static Run-Up - What is Normal? There has been some confusion in the field concerning propeller low blade angle setting, the governor setting and how it relates to static run-up and take-off RPM. As a general rule, engine redline RPM cannot be reached during a full power static run-up. Contrary to popular belief, the governor is not controlling the propeller at this time, the propeller is against its low pitch stop. Attempting to increase propeller static run-up RPM by adjusting the governor high RPM screw will have no effect and will probably result in a propeller overspeed during the take-off roll. On a single engine aircraft several considerations determine both the low and high blade angle settings. Normally 25 to 100 RPM below rated take-off RPM is desirable and acceptable during a static run-up. McCauley's practice is to set the low blade angle so that rated take-off RPM is not reached until the aircraft has reached some significant groundspeed during roll out. At this time, and only this time, the propeller is controlled by the governor. There are two advantages to this practice. First, the maximum static RPM can be used as a check on developed horsepower as with a fixed pitch propeller. Any loss of maximum power over time is readily apparent during a preflight check. Second, if the propeller remains in a flat pitch after take-off due to some malfunction, the higher angle low pitch setting will permit more thrust to be developed to fly the aircraft without overspeeding the engine. 2 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted October 2, 2020 Report Share Posted October 2, 2020 9 hours ago, J0nathan225 said: What about or where do I look for the static rpm for a 64mooney m29e with a 2 blade scimitar? Just had an IRAN on the prop and it seems alittle off I don’t make 2700 until I’m 100’ in the air. Hartzell Manual 115N has procedures for adjusting the prop and governor. Clarence Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted October 2, 2020 Report Share Posted October 2, 2020 6 hours ago, PT20J said: Here' a good explanation from McCauley: Static Run-Up - What is Normal? There has been some confusion in the field concerning propeller low blade angle setting, the governor setting and how it relates to static run-up and take-off RPM. As a general rule, engine redline RPM cannot be reached during a full power static run-up. Contrary to popular belief, the governor is not controlling the propeller at this time, the propeller is against its low pitch stop. Attempting to increase propeller static run-up RPM by adjusting the governor high RPM screw will have no effect and will probably result in a propeller overspeed during the take-off roll. On a single engine aircraft several considerations determine both the low and high blade angle settings. Normally 25 to 100 RPM below rated take-off RPM is desirable and acceptable during a static run-up. McCauley's practice is to set the low blade angle so that rated take-off RPM is not reached until the aircraft has reached some significant groundspeed during roll out. At this time, and only this time, the propeller is controlled by the governor. There are two advantages to this practice. First, the maximum static RPM can be used as a check on developed horsepower as with a fixed pitch propeller. Any loss of maximum power over time is readily apparent during a preflight check. Second, if the propeller remains in a flat pitch after take-off due to some malfunction, the higher angle low pitch setting will permit more thrust to be developed to fly the aircraft without overspeeding the engine. I have always contended that I can feel my prop governor kicking in on take off....it keeps the prop from over speeding. Typically my rpms will go up to 2690 (sometimes 2700) then drop down to 2650 and you can hear and feel the change Quote Link to comment Share on other sites More sharing options...
Ragsf15e Posted October 2, 2020 Report Share Posted October 2, 2020 9 hours ago, larrynimmo said: I have always contended that I can feel my prop governor kicking in on take off....it keeps the prop from over speeding. Typically my rpms will go up to 2690 (sometimes 2700) then drop down to 2650 and you can hear and feel the change Me too. I’ve wondered if that was just some sort of “rpm overshoot” as the engine accelerated or really the gov. I push it up smoothly/slowly but still see what you described. Also, my jpi930 doesn’t help because I have exact instantaneous readout of rpm vs the traditional gage where you probably wouldn’t notice it. Quote Link to comment Share on other sites More sharing options...
