RLCarter Posted July 8, 2020 Report Share Posted July 8, 2020 Not real sure if this is right place, but here goes. A buddy just got an Optical Center Punch which is awesome for those that have trouble center punching on the layout lines. There are several brands available and get pricey but if your holes aren’t coming out where you want them it’s worth the money 2 Quote Link to comment Share on other sites More sharing options...
MBDiagMan Posted July 9, 2020 Report Share Posted July 9, 2020 Outstanding! I’m anxious to see one of them! Quote Link to comment Share on other sites More sharing options...
Yetti Posted July 17, 2020 Report Share Posted July 17, 2020 It's art form and technique. You can also scribe your layout lines and that helps. Same with layout fluid. you can feel the line with the tip of the punch. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted July 21, 2020 Author Report Share Posted July 21, 2020 On 7/16/2020 at 8:54 PM, Yetti said: It's art form and technique. You can also scribe your layout lines and that helps. Same with layout fluid. you can feel the line with the tip of the punch. I’ve seen stuff laid out with a sharpie, the intersecting lines are larger than the hole needed to be drilled. I use a sharpie as dye on most things, then an Exacto for the scribe, quick and easy. Quote Link to comment Share on other sites More sharing options...
Yetti Posted July 21, 2020 Report Share Posted July 21, 2020 3 hours ago, RLCarter said: I’ve seen stuff laid out with a sharpie, the intersecting lines are larger than the hole needed to be drilled. I use a sharpie as dye on most things, then an Exacto for the scribe, quick and easy. The blue layout fluid has more thickness. And if you use a real scribe it creates a line that you can feel with the end of the punch. With or without the fluid. The fluid makes the feel more noticeable. Drag the punch across the line at a 30 degree angle, feel the bump bump at the x. Stand the punch up and hit it. It's a feel and sight thing. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted July 21, 2020 Author Report Share Posted July 21, 2020 I do use the dye on bigger projects, but for just a couple holes the sharpie does the trick. I always tell who is going to drill or cut “those lines are not suggestions, please use them” Quote Link to comment Share on other sites More sharing options...
Yetti Posted July 21, 2020 Report Share Posted July 21, 2020 2 hours ago, RLCarter said: I do use the dye on bigger projects, but for just a couple holes the sharpie does the trick. I always tell who is going to drill or cut “those lines are not suggestions, please use them” The it is just trying to remember if you cut inside the line, on the line, outside the line. Then dremel tool :-) Hammer to fit paint to match. 1 Quote Link to comment Share on other sites More sharing options...
Mark89114 Posted July 25, 2020 Report Share Posted July 25, 2020 On 7/21/2020 at 4:43 PM, Yetti said: The it is just trying to remember if you cut inside the line, on the line, outside the line. Then dremel tool :-) Hammer to fit paint to match. And putty is your buddy. Quote Link to comment Share on other sites More sharing options...
Hector Posted July 26, 2020 Report Share Posted July 26, 2020 As I have told my wife many, many times, NO, you can’t ever have too many tools.Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
