Mooney-Shiner Posted July 6, 2020 Report Share Posted July 6, 2020 (edited) Dear esteemed board, I would like to seek your opinion on something. During my engine inspection, I noticed the rear of generator is attached to the prop governor oil line. Additionally, there is no rubber sleeve and its a metal on metal contact. I looked through the IPC for IO-360A1A and didn't see this kind of attachment. Has anyone seen this kind of set up before? Edited July 6, 2020 by ukrsindicat@yahoo.com rearrangement Quote Link to comment Share on other sites More sharing options...
RLCarter Posted July 6, 2020 Report Share Posted July 6, 2020 I think it’s more of the Generator being a support rather than the Oil Line being the support But either way my E didn’t have anything off the generator to hold the oil line 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 6, 2020 Report Share Posted July 6, 2020 While looking for that solution... Also keep in mind that a fire sleeve on the oil line is probably a standard of today... PP thoughts only, not a mechanic... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted July 6, 2020 Report Share Posted July 6, 2020 40 minutes ago, carusoam said: While looking for that solution... Also keep in mind that a fire sleeve on the oil line is probably a standard of today... PP thoughts only, not a mechanic... Best regards, -a- No fire sleeve but I seem to remember an AD to replace the original steel line to Stainless Steel 4 Quote Link to comment Share on other sites More sharing options...
cliffy Posted July 7, 2020 Report Share Posted July 7, 2020 https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgad.nsf/AOCADSearch/D17C07A9D76E6AAA8625684F006E5ADC?OpenDocument Here is the AD (90-04-06) Change from aluminum B nuts to steel and to steel crank case AN fittings OR Type D flexible line with steel fittings and steel crank case fittings 1 Quote Link to comment Share on other sites More sharing options...
EricJ Posted July 7, 2020 Report Share Posted July 7, 2020 I don't think there'd be an issue putting a cushion on that adel clamp. 1 Quote Link to comment Share on other sites More sharing options...
Mooney-Shiner Posted July 8, 2020 Author Report Share Posted July 8, 2020 (edited) 20 hours ago, EricJ said: I don't think there'd be an issue putting a cushion on that adel clamp. This is my concern as well. There is a metal-on-metal contact between vibrating part (generator) and oil-line. I'm worrying that there is a potential for rupture and fire in-flight. Plus, I would like to confirm that this is a correct set up, as Lycoming IPC is showing something way different. Edited July 8, 2020 by ukrsindicat@yahoo.com Quote Link to comment Share on other sites More sharing options...
Igor_U Posted July 8, 2020 Report Share Posted July 8, 2020 I am really not sure what you are referring to... Is there additional bracket attached to Item 1 of the IPC (aft bracket) holding the oil tube? I can confirm that my 67F has same setup as shown on Lycoming IPC. Quote Link to comment Share on other sites More sharing options...
Mooney-Shiner Posted July 8, 2020 Author Report Share Posted July 8, 2020 (edited) 2 minutes ago, Igor_U said: I am really not sure what you are referring to... Is there additional bracket attached to Item 1 of the IPC (aft bracket) holding the oil tube? I can confirm that my 67F has same setup as shown on On mine, it seems that the rear of generator attached to the prop oil line vs engine block. Edited July 8, 2020 by ukrsindicat@yahoo.com Quote Link to comment Share on other sites More sharing options...
