Jim Peace Posted June 28, 2020 Report Share Posted June 28, 2020 I am thousands of miles from home....can someone look up a part number for me please in the parts manual I have a !964 M20c # 2799 and I want to change the battery contactor or relay or coil or whatever you call it. I will enclose what I currently have. I am not sure of what I should buy and will take recommendations with a link... I have an alternator but I have had it for about 4 years,,,not sure if that makes a difference...also when I look up what I currently have on the plane the closest I can get to the same says its for experimental. I do have the new skytech starter relay and I know they make one for the battery but they show two different part numbers for the C and I am not sure why Thank you Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 28, 2020 Report Share Posted June 28, 2020 Expect that we are talking about the Master relay/solenoid/contactor... The think that acts like a fast acting switch when we turn on the master switch... Essentially, it connects the battery to the main bus. Hope that may help... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted June 28, 2020 Author Report Share Posted June 28, 2020 Just now, carusoam said: Expect that we are talking about the Master relay/solenoid/contactor... Yes....that it I am being my own mechanic and avionics guy now....10k is not enough to make things happen at a MSC And we cannot call it a master anymore... 1 Quote Link to comment Share on other sites More sharing options...
Ross Taylor Posted June 28, 2020 Report Share Posted June 28, 2020 Hi Jim, I just went through this for my E, so had the info handy. This STS-M12 is an option: https://www.aircraftspruce.com/catalog/eppages/skytec07-03565.php Here's a screenshot from the PMA doc. This doc also shows a part number of STS-S12 for the starter solenoid, so that may be what you saw? I guess the M is for M****** 1 Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted June 28, 2020 Author Report Share Posted June 28, 2020 4 minutes ago, Ross Taylor said: Hi Jim, I just went through this for my E, so had the info handy. This STS-M12 is an option: https://www.aircraftspruce.com/catalog/eppages/skytec07-03565.php Here's a screenshot from the PMA doc. This doc also shows a part number of STS-S12 for the starter solenoid, so that may be what you saw? I guess the M is for M****** Got it arigato from osaka. 1 Quote Link to comment Share on other sites More sharing options...
Ross Taylor Posted June 28, 2020 Report Share Posted June 28, 2020 What a beautiful place, Jim. I spent several years working in Japan every month, all over that country. I do miss that a bit... Glad I could help - it's rare I'm not asking the question! 1 Quote Link to comment Share on other sites More sharing options...
MooneyMitch Posted June 28, 2020 Report Share Posted June 28, 2020 4 minutes ago, Ross Taylor said: What a beautiful place, Jim. I spent several years working in Japan every month, all over that country. I do miss that a bit... Glad I could help - it's rare I'm not asking the question! Ah...... the beauty of MSers! 1 Quote Link to comment Share on other sites More sharing options...
SheryLoewen Posted June 29, 2020 Report Share Posted June 29, 2020 Cutler-Hammer Solenoid Relay 12v PN 6041H34B Paul Loewen 1 1 Quote Link to comment Share on other sites More sharing options...
Ross Taylor Posted June 29, 2020 Report Share Posted June 29, 2020 3 minutes ago, SheryLoewen said: Cutler-Hammer Solenoid Relay 12v PN 6041H34B Paul Loewen I tried to find one of those not long ago, when I was on this same hunt, since that's the original part number. It seems that particular part is no longer readily available and I could only find $250 NOS instances of it on eBay or Skygeek (with a 6 week lead time). I ended up going with the one I linked to from AS for about $80. But Cutler-Hammer/Eaton stuff is top notch if you can find it. Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted June 29, 2020 Author Report Share Posted June 29, 2020 1 hour ago, Ross Taylor said: I tried to find one of those not long ago, when I was on this same hunt, since that's the original part number. It seems that particular part is no longer readily available and I could only find $250 NOS instances of it on eBay or Skygeek (with a 6 week lead time). I ended up going with the one I linked to from AS for about $80. But Cutler-Hammer/Eaton stuff is top notch if you can find it. thank you Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted July 2, 2020 Author Report Share Posted July 2, 2020 On 6/28/2020 at 5:50 PM, Ross Taylor said: Hi Jim, I just went through this for my E, so had the info handy. This STS-M12 is an option: https://www.aircraftspruce.com/catalog/eppages/skytec07-03565.php Here's a screenshot from the PMA doc. This doc also shows a part number of STS-S12 for the starter solenoid, so that may be what you saw? I guess the M is for M****** I have a three post on the plane.....can I get a 4 post like you suggest and make it work? Quote Link to comment Share on other sites More sharing options...
Andy95W Posted July 2, 2020 Report Share Posted July 2, 2020 8 hours ago, Jim Peace said: I have a three post on the plane.....can I get a 4 post like you suggest and make it work? Yes. Depending on the application, one of the small terminals is either connected to ground or power. https://www.aircraftspruce.com/catalog/pdf/Lamar Starter Overview.pdf Quote Link to comment Share on other sites More sharing options...
Ross Taylor Posted July 2, 2020 Report Share Posted July 2, 2020 8 hours ago, Jim Peace said: I have a three post on the plane.....can I get a 4 post like you suggest and make it work? Yes - this one has a floating ground, instead of the case being grounded. So the extra terminal is for a ground wire. It comes with a jumper from the in/hot side to one of the coil terminals, with the plan that a ground can be run through a switch to activate it. With a switched hot (positive), just remove the jumper and ground the other small terminal. EDIT to add...I must have been typing when @Andy95W was posting. Thanks Andy...nice pics and everything! 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted July 2, 2020 Report Share Posted July 2, 2020 I found the cutler and hammar one at McMaster carr a while back. Metal can solenoids are doomed to fail. The difference between solenoids is constant(Master) and intermittent (starter). That and price. Quote Link to comment Share on other sites More sharing options...
Yetti Posted July 2, 2020 Report Share Posted July 2, 2020 Not all 4 post Solenoids are the same. For instance the Ford Tractor one in the belly on my F for the gear actuator the Third terminal is hot to hold the brake on the motor off while the motor is running. Quote Link to comment Share on other sites More sharing options...
Ross Taylor Posted July 2, 2020 Report Share Posted July 2, 2020 I don't think Jim was asking about "just any" 4-terminal relay/solenoid/contactor. I believe he wondered if this particular 4-terminal relay would work, when he's got a 3-terminal relay. The 3-terminal relay is different in the sense that the missing 4th terminal is the case ground...but from a wiring diagram perspective, it's the same either way (the difference being that a grounded case solenoid could not be easily actuated with a switched ground wire). So I wanted to assure him that this particular solenoid would work in his case. There is a starter version of this, but the part linked to above is the master (continuous duty) version. This isn't just a Napa starter solenoid, which isn't rated for continuous duty. As I mentioned, I did try to find the original part just a few months ago. A search for the part number 6041H34B on either Grainger or McMaster-Carr will yield no current results. The only place I can find the original part is on eBay, so I went with this legal replacement. On your "tractor relay", that may be a normally closed solenoid where energizing the coil opens the brake circuit...or it's a normally open solenoid, but closing that circuit does something to hold the brakes off. I know nothing about how that's set up on the J. No telling...but a different beast than this. Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted July 2, 2020 Author Report Share Posted July 2, 2020 On 6/28/2020 at 9:05 PM, Ross Taylor said: I ended up going with the one I linked to from AS for about $80. But Cutler-Hammer/Eaton stuff is top notch if you can find it. how is it doing....some of the reviews on that are so hit and miss....high failure rate after not that long in service....you would think these would work for years and years just like the older stuff that you cant find anymore.... Quote Link to comment Share on other sites More sharing options...
Ross Taylor Posted July 2, 2020 Report Share Posted July 2, 2020 1 hour ago, Jim Peace said: how is it doing....some of the reviews on that are so hit and miss....high failure rate after not that long in service....you would think these would work for years and years just like the older stuff that you cant find anymore.... So far, just fine...but I admit that I have not flown much in the four and a half or five months since I got it. However it's probably been on more than if I had been flying. While I'm doing some avionics and audio panel upgrades, I've had the master on regularly for testing. But I certainly can't speak to longevity yet. Quote Link to comment Share on other sites More sharing options...
Seymour Posted June 26, 2022 Report Share Posted June 26, 2022 Reviving this thread as I'm AOG on an island in Canada off the coast of Maine that has a 3+ day "Express" delivery time, so I need to get it right (this time). I'll provide more details on my maiden cross-border flight and the ensuing adventures in aircraft repair, but for now I'd simply like to confirm that the correct part is ordered. Luckily, I'm solo so that no passengers need to be someplace soon so I'm putting Buffet's Margaritaville on infinite loop and enjoying the great (flying) weather. 1965 M20E Diagnosed Failure: Starter Solenoid - Part number DR1464 (mounted to the firewall) Specific questions: 1. Is anyone able to confirm that this is the correct replacement part? (Certainly, google thinks so.) https://www.aircraftspruce.com/catalog/eppages/sts-12s24s.php I ordered the 12V option from Aircraft Spruce in Brantford Ontario yesterday; it is expected to begin it's long journey on Monday night. 2. The part is mounted directly to the firewall with two screws. Are there nuts on the inside of the firewall that I need to find as I back out the mounting screws or are they tinnerman (or some other type of captured) nuts? 3. For information only, I'm looking for the best old thread on hand-propping an IO-360-AIA. Savvy's AOG service says "Not Recommended". Local aviation folks say "Good luck finding someone to do it". ...and I've heard enough horror stories to avoid it but I'm looking for good reading material while I wait for another part. Reaching out to @M20Doc because he might know the answer without having to research and may have Canadian sources that I'm not familiar with. Quote Link to comment Share on other sites More sharing options...
Seymour Posted June 26, 2022 Report Share Posted June 26, 2022 Might already have an answer from the comments on Aircraft Spruce: Quote Link to comment Share on other sites More sharing options...
Guest Posted June 26, 2022 Report Share Posted June 26, 2022 57 minutes ago, Seymour said: Reviving this thread as I'm AOG on an island in Canada off the coast of Maine that has a 3+ day "Express" delivery time, so I need to get it right (this time). I'll provide more details on my maiden cross-border flight and the ensuing adventures in aircraft repair, but for now I'd simply like to confirm that the correct part is ordered. Luckily, I'm solo so that no passengers need to be someplace soon so I'm putting Buffet's Margaritaville on infinite loop and enjoying the great (flying) weather. 1965 M20E Diagnosed Failure: Starter Solenoid - Part number DR1464 (mounted to the firewall) Specific questions: 1. Is anyone able to confirm that this is the correct replacement part? (Certainly, google thinks so.) https://www.aircraftspruce.com/catalog/eppages/sts-12s24s.php I ordered the 12V option from Aircraft Spruce in Brantford Ontario yesterday; it is expected to begin it's long journey on Monday night. 2. The part is mounted directly to the firewall with two screws. Are there nuts on the inside of the firewall that I need to find as I back out the mounting screws or are they tinnerman (or some other type of captured) nuts? 3. For information only, I'm looking for the best old thread on hand-propping an IO-360-AIA. Savvy's AOG service says "Not Recommended". Local aviation folks say "Good luck finding someone to do it". ...and I've heard enough horror stories to avoid it but I'm looking for good reading material while I wait for another part. Reaching out to @M20Doc because he might know the answer without having to research and may have Canadian sources that I'm not familiar with. Spruce would be your best bet. The current Mooney version is $900. It should be attached to the firewall with anchor nuts. Clarence Quote Link to comment Share on other sites More sharing options...
Seymour Posted June 26, 2022 Report Share Posted June 26, 2022 Thanks for the quick response, Clarence! Now let's see if I can find lodging on the island for the mechanic again once the part arrives... on Canada Day. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 26, 2022 Report Share Posted June 26, 2022 Where are you stranded? Clarence Quote Link to comment Share on other sites More sharing options...
Seymour Posted June 26, 2022 Report Share Posted June 26, 2022 Grand Manan - CCN2 If you have to be stuck on an island, this is the place! Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 26, 2022 Report Share Posted June 26, 2022 4 hours ago, Seymour said: Grand Manan - CCN2 If you have to be stuck on an island, this is the place! Send pics! One of the relay… And about a dozen of the isle…. Some relays break parts and jam inside… others just get dirty and stick… Helps to have a volt meter to do some problem solving…. Or a volleyball named Wilson… -a- Quote Link to comment Share on other sites More sharing options...
