Schinderhannes Posted June 17, 2020 Report Share Posted June 17, 2020 I am in the process of installing a Garmin GTX330 and was wondering if there is still value in wiring the ARINC connection to the GPS for TIS-A. Does TIS-A broadcast any information not covered by TIS-B and are there areas with TIS-A, but no TIS-B coverage. Are there plans to shut down TIS-A in the near future? Thank you, Frank Quote Link to comment Share on other sites More sharing options...
OR75 Posted June 17, 2020 Report Share Posted June 17, 2020 TIS-A will stay where traffic matters most : in and near class B airspace Quote Link to comment Share on other sites More sharing options...
Gary0747 Posted June 22, 2020 Report Share Posted June 22, 2020 As far as I know, There is no way of knowing what you are seeing on your screen is TISA or TISB? Quote Link to comment Share on other sites More sharing options...
Marauder Posted June 22, 2020 Report Share Posted June 22, 2020 As far as I know, There is no way of knowing what you are seeing on your screen is TISA or TISB? I always thought TIS-A was limited to ES type transponders. If your using a 978 device, I think you’ll only get TIS-B. I fly in a Class B area served by TIS-A and have an ES transponder. I can’t tell if I can receiving TIS-A or B. I can tell when I get TAS from my active traffic unit. Think I need to pull up the “this is TIS” for a refresher. Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
