nels Posted June 11, 2020 Report Share Posted June 11, 2020 I’d like to install a German GNX375 in my 201 and looking for a shop that is competent, reliable and can do the job for $10k. Need it integrated to the autopilot and and existing heading indicator. Looking for a shop within reasonable flying distance from Cincinnati. Panel is pretty clean with few upgrades or mods in its life so not a rat nest of wiring behind the panel. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Niko182 Posted June 11, 2020 Report Share Posted June 11, 2020 5 minutes ago, nels said: I’d like to install a German GNX375 in my 201 and looking for a shop that is competent, reliable and can do the job for $10k. Need it integrated to the autopilot and and existing heading indicator. Looking for a shop within reasonable flying distance from Cincinnati. Panel is pretty clean with few upgrades or mods in its life so not a rat nest of wiring behind the panel. Any suggestions? I'd plan for in-between 10 and 12k. Under 10K might be a stretch. I personally love the unit. Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 11, 2020 Report Share Posted June 11, 2020 Nels, Siri thinks Olathe Kansas is in Germany... She confused Garmin for German... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
Rmag Posted June 11, 2020 Report Share Posted June 11, 2020 3 minutes ago, Niko182 said: I'd plan for in-between 10 and 12k. Under 10K might be a stretch. I personally love the unit. @nels Our shop falls within the range Niko provided. We are not below 10K. KMQS airport in SE Pennsylvania. Don’t know if that qualifies as reasonable flying distance from Cincinnati. 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 11, 2020 Report Share Posted June 11, 2020 Interesting question for Rmag... The Garmin site mentions easy upgrade for a KLN90... (I just happen to have one) I hadn’t thought about that... Got any details on what work would need to be done to swap in the new GNX375? For Nels... https://www.airnav.com/airport/KMQS Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Rmag Posted June 11, 2020 Report Share Posted June 11, 2020 @carusoam They say easy upgrade because it fits in the same two inch space, so not much panel work, however needs new antenna installed and new wire harness, plus some panel work due to the transponder removal. 2 Quote Link to comment Share on other sites More sharing options...
nels Posted June 12, 2020 Author Report Share Posted June 12, 2020 On 6/10/2020 at 10:14 PM, Rmag said: @nels Our shop falls within the range Niko provided. We are not below 10K. KMQS airport in SE Pennsylvania. Don’t know if that qualifies as reasonable flying distance from Cincinnati. Rmag, You are probably too far. I’d get there quick in the plane but a long hike home and back. Radius of about 200 miles from Cincinnati would work. A shop near by wants to talk me into a Garmin 275 in conjunction with another separate Adsb in/out. I think an Appareo. He says I can save money and have the equivalent of the 375. Anyone familiar enough with all three to comment. He is supposed to be sending a quote. Quote Link to comment Share on other sites More sharing options...
MIm20c Posted June 12, 2020 Report Share Posted June 12, 2020 The only reason I’d go for a Garmin 175 vs the all in one is if a adsb in/out or at least out was already installed. 1 Quote Link to comment Share on other sites More sharing options...
Davidv Posted June 12, 2020 Report Share Posted June 12, 2020 I like mine a lot and it does everything as advertised. The install price was $8,500 at the shop I went to in FL. Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted June 13, 2020 Report Share Posted June 13, 2020 3 hours ago, nels said: Rmag, You are probably too far. I’d get there quick in the plane but a long hike home and back. Radius of about 200 miles from Cincinnati would work. A shop near by wants to talk me into a Garmin 275 in conjunction with another separate Adsb in/out. I think an Appareo. He says I can save money and have the equivalent of the 375. Anyone familiar enough with all three to comment. He is supposed to be sending a quote. Don’t skimp and get the Appareo, You’ll later wish you bought the 375. The bitterness of poor quality is remembered long after the sweetness of low price is forgotten. An extra couple thousand isn’t going to change your lifestyle. Do it once, and do it right. 2 Quote Link to comment Share on other sites More sharing options...
nels Posted June 13, 2020 Author Report Share Posted June 13, 2020 (edited) 5 hours ago, Davidv said: I like mine a lot and it does everything as advertised. The install price was $8,500 at the shop I went to in FL. David. Are you talking about the 375, 175 or Appareo? Edited June 13, 2020 by nels Quote Link to comment Share on other sites More sharing options...
Davidv Posted June 13, 2020 Report Share Posted June 13, 2020 375 8 hours ago, nels said: David. Are you talking about the 375, 175 or Appareo? Quote Link to comment Share on other sites More sharing options...
nels Posted June 14, 2020 Author Report Share Posted June 14, 2020 On 6/13/2020 at 7:55 AM, Davidv said: 375 Dave. $8500 sounds real reasonable for a 375 install. Did you have a autopilot to integrate with and a heading indicator? I’d be interested in your shops contact info if you would share it. PM me if you would. Quote Link to comment Share on other sites More sharing options...
Davidv Posted June 14, 2020 Report Share Posted June 14, 2020 Yes that includes the integration. I will PM you. 1 Quote Link to comment Share on other sites More sharing options...
