DEGWS Posted June 10, 2020 Report Posted June 10, 2020 Hi, Have a Fuel leak on LH Tank running into leading edge near fuselage. Only with nearly Full Fuel. Today I removed the lower inner panel and identify the leak. Two small holes in the sealer. What is the best way to fix it. I have both sealers for the Tank/panel at home and plan to start work tomorrow. Thanks! Quote
Andy95W Posted June 10, 2020 Report Posted June 10, 2020 While I agree that is probably the source of your leak, I would double check before you mix the sealant. Nothing sucks more than going to all that trouble, resealing the access panel, and then finding out there was another leak. I suggest reading the article below, Don Maxwell describes a great method for finding leaks, and you're already halfway there. http://donmaxwell.com/fuel-tank-repairs-how-we-fix-them/ Good luck, keep us posted. Quote
N201MKTurbo Posted June 10, 2020 Report Posted June 10, 2020 Do you want the easy answer, or the correct answer? First, I would leak check it as @Andy95W said above. If that is in fact your leak, the easy fix is to clean the top coat off with MEK and dab some new sealant on, let it cure and re-leak check it. The correct way is to clean that corner down to bare metal, back about 2 inches in all directions and reseal according to the maintenance manual. 3 Quote
carusoam Posted June 10, 2020 Report Posted June 10, 2020 Great question with pic! Great answers with reference! Can it get any better than that? Go MS! -a- Quote
DEGWS Posted June 11, 2020 Author Report Posted June 11, 2020 Today I confirmed the location with soap and blowing some air near the area leaking into the leading edge. Leak is exactly as you see on the picture. I cleaned this area with MEK and resealed with ppg sealer. Also sealed the lower access panel with the specific sealer. How long should I wait until adding fuel again? 1 Quote
hammdo Posted June 11, 2020 Report Posted June 11, 2020 I’d give it 48 hrs to fully cure. I believe that is the ‘max’ time. Then retest to confirm no other leaks pop up after you’ve sealed that one - there could be others that show up... -Don Quote
jetdriven Posted June 12, 2020 Report Posted June 12, 2020 Follow the service manual on this. Scarf back the sealant in the area. Wipe with MeK to clean. Apply adhesion promoter pr-142. Apply pr1422b for fillet. Let dry. Then wipe and apply 1422a. Then top coat with buna-n. I just Did this and I fixed it. 2 Quote
EricJ Posted June 12, 2020 Report Posted June 12, 2020 (edited) 19 hours ago, DEGWS said: Today I confirmed the location with soap and blowing some air near the area leaking into the leading edge. Leak is exactly as you see on the picture. I cleaned this area with MEK and resealed with ppg sealer. Also sealed the lower access panel with the specific sealer. How long should I wait until adding fuel again? It should say on the documentation for the sealant you used how long it needs to cure. There are different sealants with different cure times. Edited June 12, 2020 by EricJ Quote
DEGWS Posted June 15, 2020 Author Report Posted June 15, 2020 Today I add fuel again. Leak is fixed! I like moneyspace.com. Thank you all! 5 Quote
carusoam Posted June 16, 2020 Report Posted June 16, 2020 Great follow-up DEGWS! The Clanging of glasses can be heard all around the internet this evening.... Cheers! That was the fastest leak detected, found, repaired, and tested, ever! Congrats. Go MS Support Team! Best regards, -a- Quote
