Matt Ward Posted May 1, 2020 Report Share Posted May 1, 2020 In the picture below, you can see what appear to be “smudges” on the glass screen of the 430. These are unfortunately on the backside of the glass so I can’t wipe them off. As I understand it, these smudges represent a wearing off of a coating Garmin used to use. Other than sending this in to Garmin, along with $1300, is there anything I can do to clear it up? Quote Link to comment Share on other sites More sharing options...
StevenL757 Posted May 1, 2020 Report Share Posted May 1, 2020 Unless it’s the quality of the photo, this looks suspiciously like moisture on the inside of the lens. Your shop could try detaching the faceplate and cleaning the inside to see if that removes what you’re seeing, as well as look around in the unit to see if there are other signs of water intrusion. Taking it even further, your A&P could look around the airframe to see if water is getting in anywhere in general. Short of this, you may have no choice but to send it to Garmin if you plan on keeping the unit for awhile. Check with @Alan Fox on here for a possible solution, as he works frequently with airframe and avionics parts. Steve 1 Quote Link to comment Share on other sites More sharing options...
Alan Fox Posted May 1, 2020 Report Share Posted May 1, 2020 2 hours ago, StevenL757 said: Unless it’s the quality of the photo, this looks suspiciously like moisture on the inside of the lens. Your shop could try detaching the faceplate and cleaning the inside to see if that removes what you’re seeing, as well as look around in the unit to see if there are other signs of water intrusion. Taking it even further, your A&P could look around the airframe to see if water is getting in anywhere in general. Short of this, you may have no choice but to send it to Garmin if you plan on keeping the unit for awhile. Check with @Alan Fox on here for a possible solution, as he works frequently with airframe and avionics parts. Steve I have seen these delaminate , I don't believe its water , due to the condition of all the radios around it, Unfortunately its a flat rate to repair it.. They usually look good powered up , if this is the case , let it be.. 1 Quote Link to comment Share on other sites More sharing options...
Matt Ward Posted May 2, 2020 Author Report Share Posted May 2, 2020 Thank you very much, @Alan Fox. I'm not expecting it is moisture but I'll check on that at annual for sure. It's a little tough to read in flight if the light hits it at the right angle, but nothing I can't deal with. With the ones you've seen in the past, is there anything functional or is it just cosmetic? The buttons are generally pretty good. They stick a little as one would expect from a +12 year old install. Quote Link to comment Share on other sites More sharing options...
Alan Fox Posted May 2, 2020 Report Share Posted May 2, 2020 Cosmetic , It is not the screen , It is a protective lens Quote Link to comment Share on other sites More sharing options...
bradp Posted May 2, 2020 Report Share Posted May 2, 2020 You can remove the protective coating. Quote Link to comment Share on other sites More sharing options...
Matt Ward Posted May 2, 2020 Author Report Share Posted May 2, 2020 28 minutes ago, bradp said: You can remove the protective coating. That’s great! Any pointers on how? Quote Link to comment Share on other sites More sharing options...
Alan Fox Posted May 2, 2020 Report Share Posted May 2, 2020 8 hours ago, bradp said: You can remove the protective coating. No you cant , Its not the anti glare , it is delaminating Quote Link to comment Share on other sites More sharing options...
bradp Posted May 2, 2020 Report Share Posted May 2, 2020 Alan’s right I thought it was the anti glare. Can’t remove this problem. Quote Link to comment Share on other sites More sharing options...
tmo Posted May 10, 2020 Report Share Posted May 10, 2020 Alan is of course correct, but for those with a moisture problem - I've found that putting a box with silica gel (or any other similar desiccant) in the foot well will significantly improve things. I use kitty litter (make sure it is silica gel, they come in different forms) and change the "load" every 2 weeks or so; I just dry the wet one in an oven (2h at 120C/250F). One of the cheap things that won't hurt anything, even if they do nothing except make me feel good. I've alsoread about people leaving properly protected low power incandescent (traditional) light bulbs on as little space heaters in cockpits and up cowl flaps... Haven't gone there (yet?). Quote Link to comment Share on other sites More sharing options...
