Candy man Posted February 29, 2020 Report Share Posted February 29, 2020 What pattern speeds is everybody using? I have a 1970 C. I use 100 mph on downwind 90 on base 80 on final and 70 across the numbers. I add about 10 degrees of flaps on downwind and dump the rest on final. 2 Quote Link to comment Share on other sites More sharing options...
PJClark Posted February 29, 2020 Report Share Posted February 29, 2020 Rocket: Downwind and base turn minimum with gear and 50% flaps: 100 KIAS Base: 90 KIAS Final: 85 KIAS (flaps full) slow from 85---75 KIAS approx 1000-1500' before the runway threshold (with no gusts--with gust add 1/2 the gust factor) 1 Quote Link to comment Share on other sites More sharing options...
Hank Posted February 29, 2020 Report Share Posted February 29, 2020 1970 electric C: Downwind, slow to 90 mph, add Takeoff Flaps (preferably by downwind entry) Abeam intended point of landing, drop gear to start descent, nudge throttle back slightly Base, 90 mph Final, roll wings level at 85 mph. Adjust yoke, throttle, trim and flaps as needed to maintain glideslope When I know I have the field made, throttle to idle. Slow to 75 mph minus 5 mph fpr every 300 lb below gross at that time as I cross the fence / clearing Once down and under control, reach out a finger and raise flaps then lean mixture to ground ops position 4 Quote Link to comment Share on other sites More sharing options...
FloridaMan Posted February 29, 2020 Report Share Posted February 29, 2020 (edited) 67F enter pattern at whatever speed, slow to 120 gear speed 2 miles out. 100mph on final and slow to cross numbers at 75-80mph unless attempting to be stopped within 500ft; in that case carry slow flight at 70mph across the numbers. Rocket: same as above, but in knots and gear speed is 130kias. Getting rid of 20-25mph on final is easy and keeps you at best glide until you really need to be slower and allows for pull power off final approaches. I operate out of a 2800ft field On ILS approaches, I maintain gear speed until visual. No airport in the country with an ILS has a runway so short that you can’t bleed off the extra speed after descending past decision height. Edited February 29, 2020 by FloridaMan 1 Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted February 29, 2020 Report Share Posted February 29, 2020 For me and my 252, all speeds are in knots. Downwind - 90 to 120 knots Base - 80 to 90 knots Final - 70 to 90 knots @Denver98 and I were out doing touch and goes this morning. Scott was doing the flying and did several with no flaps and several with full flaps. All accept the last were touch and goes. We're in Denver so the runway is long and sitting at 5700 ft MSL. In these conditions, no flap landings, are just easier and smoother. 4 Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 29, 2020 Report Share Posted February 29, 2020 Caution on the terminology part... Dumping flaps... is that taking them out or putting them in? O is very similar to short bodies... accept our numbers are kias not mias... 90/80/7X depending on environment and GW... Full flaps, MGToW, stall speed, straight and level... 58 My preference is the continual U-turn to final, over the boxy turns... PP thoughts only, not a CFI... Best regards, -a- 4 1 Quote Link to comment Share on other sites More sharing options...
pwnel Posted February 29, 2020 Report Share Posted February 29, 2020 2 hours ago, carusoam said: Caution on the terminology part... Dumping flaps... is that taking them out or putting them in? Thank you for pointing that out. My instructor and I kept misunderstanding each other on this during my Commercial training. 1 Quote Link to comment Share on other sites More sharing options...
FloridaMan Posted March 1, 2020 Report Share Posted March 1, 2020 Also wanted to mention to be sure your idle is set to where it runs at very low RPM, but doesn’t quit with the power out. 200RPM difference in idle RPM can be 2000+ft difference in landing distance depending on when you chop power and dramatically affect how quickly you drop airspeed. Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 1, 2020 Report Share Posted March 1, 2020 When we want to dump the lift that is generated by flaps... we raise them... Using the words to dump the flaps... when we might want to be dumping the lift... Gives a great reason to formalize the words used.... Pulling the flaps up on short final when somebody is expecting you to add more... would be bad... Having your CFI think you are going to raise the flaps on short final... may lessen his opinion of your skills... Interesting things we learn about language skills while we type out our entire conversations... Go MS! Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
bradp Posted March 1, 2020 Report Share Posted March 1, 2020 MPH on a J. I now use no lower than 1.404 Vs during downwind (I round to100 mph which is roughly Vg at max gross which is convenient to remember) . Gear down flaps set takeoff, min speed 100 downwind, (I’m keeping 100 base to final now). Final -> 90, Tch ->75-80 mph (Vref). It’s not hard to slow down and go down. Quote Link to comment Share on other sites More sharing options...
jlunseth Posted March 1, 2020 Report Share Posted March 1, 2020 23 hours ago, gsxrpilot said: For me and my 252, all speeds are in knots. Downwind - 90 to 120 knots Base - 80 to 90 knots Final - 70 to 90 knots @Denver98 and I were out doing touch and goes this morning. Scott was doing the flying and did several with no flaps and several with full flaps. All accept the last were touch and goes. We're in Denver so the runway is long and sitting at 5700 ft MSL. In these conditions, no flap landings, are just easier and smoother. I do the same, except I am a little more finicky on base to final. 85 KIAS. I vary the final depending on the conditions. It lands nicely at 70-75 in calm winds with half flaps, but more speed, up to 90, and no flaps may be needed in gusty and/or crosswind conditions. Sometimes the speedbrakes help anchor the plane to the runway when there is a need to keep the speed up for rudder authority. 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted March 1, 2020 Report Share Posted March 1, 2020 Usually if there is no one in the pattern, I pull back to 15mp about a mile from the downwind threshold. By the threshold I am just above white arc. pull up a tad to get under white arc. Deploy bottom speed brake err um put the gear down. do a descending U turn to the field. It's about energy management If it is blowing you need more energy to get to the runway. Per the manual no turns in the pattern under 90mph without flaps deployed. put half flaps out in the U part of the turn. If High gonna need full flaps. You can watch the speeds on the videos. I find it entertaining to learn what speed I am where, but during landing I only look at the ASI once or twice. 1 Quote Link to comment Share on other sites More sharing options...
donkaye Posted March 1, 2020 Report Share Posted March 1, 2020 On 2/29/2020 at 6:32 AM, PJClark said: Rocket: Downwind and base turn minimum with gear and 50% flaps: 100 KIAS Base: 90 KIAS Final: 85 KIAS (flaps full) slow from 85---75 KIAS approx 1000-1500' before the runway threshold (with no gusts--with gust add 1/2 the gust factor) The FAA suggests a stabilized approach. Changing airspeeds along final doesn't make for a stabilized approach. My recommendation for all mid and long body Mooneys is 90 KTS on downwind with gear down and approach flaps, turn base at the 3° slope with the aim point while simultaneously reducing power to 15" nominally and adding full flaps. TRIM FOR HANDS OFF. DON"T let the nose go down below 3° which it will try to do before trim has reached the hands off position. If the slope remains at 3°, the plane will slow to 80 KTS with the additional drag created by the addition of full flaps. Adjust final approach speed to 75 KTS (70KTS if light) as you roll level on final. Use Pitch for airspeed and Power for ROD on final and begin the flare about 5 feet off the ground. The flare and reducing the power to idle should be done simultaneous and at the same rate for a smooth touchdown on the mains. I have found that in most cases, depending on the wind, power can be gradually reduced near the touch down point as long as the nose is likewise lowered to keep the speed constant. This keeps the aim point from moving towards you and results in a more accurate touch down near the aim point. For the short body Mooneys whose airspeed is labeled in MPH, everything is the same except it's 100 MPH on downwind, 90 MPH on base and 80 MPH on final. 9 2 Quote Link to comment Share on other sites More sharing options...
Ibra Posted March 1, 2020 Report Share Posted March 1, 2020 (edited) 5 hours ago, bradp said: I now use no lower than 1.404 Vs during downwind (I round to100 mph which is roughly Vg at max gross which is convenient to remember) You mean 1.414213*Vs (1G*square-root of 2 to make 45deg level without stall ), I use the same 1.4*Vs with decisive bank angles (less than 40deg and keep 1G) Once wings level on final, I fly 1.3*Vs for all approaches but aim for threshold ref speed that is slightly adjusted for wind/weight/runway conditions Edited March 1, 2020 by Ibra 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted March 1, 2020 Report Share Posted March 1, 2020 15 inches on down wind. On base turn, power as low as you can get it and stay out of the yellow arc. Might have to add some for a headwind. Airspeed needle pointing to the right. I usually fly my patterns kind of tight. 1/2 mile base and 1/2 mile final. When I did my commercial, the power off landing was just a normal landing. 2 Quote Link to comment Share on other sites More sharing options...
Gary0747 Posted March 1, 2020 Report Share Posted March 1, 2020 Does anybody have any data on stall and maneuvering speeds for Mooneys with the wing root faring and or any of the F models with a twist wing creating wash out? I know the factory said not much difference with the twist but some have said that reducing complexity of manufacture may have driven the elimination of the twist. I think the Mooney Mustang was also made with a twist wing. Quote Link to comment Share on other sites More sharing options...
Denver98 Posted March 2, 2020 Report Share Posted March 2, 2020 On 2/29/2020 at 1:31 PM, gsxrpilot said: For me and my 252, all speeds are in knots. Downwind - 90 to 120 knots Base - 80 to 90 knots Final - 70 to 90 knots @Denver98 and I were out doing touch and goes this morning. Scott was doing the flying and did several with no flaps and several with full flaps. All accept the last were touch and goes. We're in Denver so the runway is long and sitting at 5700 ft MSL. In these conditions, no flap landings, are just easier and smoother. I’ll confirm that the no flap landings were easier and MUCH smoother. I really liked the feel of the airplane in ground effect with no flaps better than with full flaps. I will definitely practice with different flap settings but given a long runway, no flap will probably be my preferred flap setting. 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted March 2, 2020 Report Share Posted March 2, 2020 5 hours ago, Gary0747 said: Does anybody have any data on stall and maneuvering speeds for Mooneys with the wing root faring and or any of the F models with a twist wing creating wash out? I know the factory said not much difference with the twist but some have said that reducing complexity of manufacture may have driven the elimination of the twist. I think the Mooney Mustang was also made with a twist wing. Go get some altitude and find out. 2 Quote Link to comment Share on other sites More sharing options...
donkaye Posted March 2, 2020 Report Share Posted March 2, 2020 1 hour ago, Denver98 said: I’ll confirm that the no flap landings were easier and MUCH smoother. I really liked the feel of the airplane in ground effect with no flaps better than with full flaps. I will definitely practice with different flap settings but given a long runway, no flap will probably be my preferred flap setting. 2 hours ago, Denver98 said: I’ll confirm that the no flap landings were easier and MUCH smoother. I really liked the feel of the airplane in ground effect with no flaps better than with full flaps. I will definitely practice with different flap settings but given a long runway, no flap will probably be my preferred flap setting. There are many ways to land an airplane depending on the circumstances. For normal landings, however, full flap landings should be the norm--especially at high DA. At the slower speed there is much less energy to be dissipated and much shorter landings can be made. In my opinion all landings should assume a short field. so when you actually want to land on a short field, plenty of experience has already been gained. If done correctly, with practice, you can roll the mains onto the runway without even a chirp. 8 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted March 2, 2020 Report Share Posted March 2, 2020 5 minutes ago, donkaye said: There are many ways to land an airplane depending on the circumstances. For normal landings, however, full flap landings should be the norm--especially at high DA. At the slower speed there is much less energy to be dissipated and much shorter landings can be made. In my opinion all landings should assume a short field. so when you actually want to land on a short field, plenty of experience has already been gained. If done correctly, with practice, you can roll the mains onto the runway without even a chirp. I’ve told a few people that a squeaker is a bad landing. You need to just brush the wheels on the runway and gently spin them up. It’s nice to hear it from someone else. Quote Link to comment Share on other sites More sharing options...
bradp Posted March 2, 2020 Report Share Posted March 2, 2020 Better to land where you want with a thump than to grease it on beyond. 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted March 2, 2020 Report Share Posted March 2, 2020 23 minutes ago, bradp said: Better to land where you want with a thump than to grease it on beyond. It is not an ether/or thing, you can grease it on where you want. 1 Quote Link to comment Share on other sites More sharing options...
brndiar Posted March 2, 2020 Report Share Posted March 2, 2020 Hi, Colud someone here describe "Step by step" GO- AROUND PROCEDURES (Eventuell procedere for "balked landing") for Mooneys (vintage Models, J+Models)? Of course as a recommendation. There is no such a Procedure in Mooney operators manuals. Incorrectly performed Go around is often cause of accidents (read some "go around mooney accident reports"). P.s. sorry for my englisch. Hopefully not of topic. Lg, Milos Austria 1 Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted March 2, 2020 Report Share Posted March 2, 2020 I’ve told a few people that a squeaker is a bad landing. You need to just brush the wheels on the runway and gently spin them up. It’s nice to hear it from someone else. A bad landing? Really?Maybe not perfect, but all hard surface landings squeak the tires somewhat, it’s sometimes it’s not loud enough to hear it. 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted March 2, 2020 Report Share Posted March 2, 2020 2 hours ago, brndiar said: Hi, Colud someone here describe "Step by step" GO- AROUND PROCEDURES (Eventuell procedere for "balked landing") for Mooneys (vintage Models, J+Models)? Of course as a recommendation. There is no such a Procedure in Mooney operators manuals. Incorrectly performed Go around is often cause of accidents (read some "go around mooney accident reports"). P.s. sorry for my englisch. Hopefully not of topic. Lg, Milos Austria Advance the three knobs to the firewall smoothly(high DA you might not want to firewall the mixture). level the plane. pull up the gear. sidestep the runway while trimming. get the wing flying up the flaps a notch. trim some more. once the speed is up, start climb, take all the flaps out, trim for climb out. If you firewall the plane and you were at full flaps with lots of nose up trim because you were at half flaps you are going to have to push down alot on the yoke, till you get the trim in order. This is a benefit of landing half flaps the majority of the time. Half flaps will have your trim set pretty much right on take off trim. 1 Quote Link to comment Share on other sites More sharing options...
