RDuplechin Posted February 26, 2020 Report Share Posted February 26, 2020 Hi Everyone, I have the plastic housing that holds the trim and flap indicators that I need to replace. It had several fairly minor cracks that I repaired and repainted. I looked great but was obviously very brittle. My mechanic somehow bumped it and it exploded into shards. I suppose I could use it as a pattern and make something out of fiberglass but that sounds like such a beat down. I looked at the Vantage Plane Plastics website and did an internet search for what I think is the correct part number 130103-9 ( or possibly 740020-501) but I’m not coming up with anything. Has anyone had this issue and what is the best solution? Thanks, Rick Quote Link to comment Share on other sites More sharing options...
Bob R Posted February 26, 2020 Report Share Posted February 26, 2020 Try here. https://www.loewensmooneysalvage.com Bob Quote Link to comment Share on other sites More sharing options...
Immelman Posted February 26, 2020 Report Share Posted February 26, 2020 Do you have all the pieces? Or most of them? Can you roughly figure out where they were? Mine was cracked pretty bad, some small chunks missing, and getting worse. When I had an interior shop do my seats and carpets, I said 'enough' and got out my surfboard supplies and started messing with it. It took a couple applications of fiberglass and resin, and masking tape trying to hold it in position... and of course sanding, but it was repairable and you can't really tell with a nice coat of paint on the outside. Re-installing it with the trim and flap indicators wasn't as easy as the other interior parts, PITA, 3/10 on the Mooney PITA scale. Quote Link to comment Share on other sites More sharing options...
Igor_U Posted February 26, 2020 Report Share Posted February 26, 2020 In the past I've ordered interior pieces from Vantage plane plastics. They used to have more friendly website in the past but this might be what you are looking for: https://vantageassoc.com/airplane/mooney/m20/1966m20e832thru1308/trim-control-system-581.html I found their parts being good quality and last over 10 years now. Quote Link to comment Share on other sites More sharing options...
RDuplechin Posted February 27, 2020 Author Report Share Posted February 27, 2020 Thanks everyone. I called Vantage Plane Plastics. They have this part number but it seems to be from a different model aircraft. It covers the entire end of the wheel housing instead of just the corner. For those of you that need this part I think it would work if you are willing to cut away the excess you don’t need. That was my plan B. I then called LASAR and they had the smaller one I needed for my airplane...the last one they say. It wasn’t cheap but it is brand new and I’ll be happy if I can just move the indicators over, attach the cable, and screw it in. I’ve had very good luck doing MEK repairs on the other plastic parts in the airplane but this piece was just too brittle and in too much of a high traffic area to last. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted February 27, 2020 Report Share Posted February 27, 2020 I went with Vantage route, it's 3 pieces that hides the ugly Quote Link to comment Share on other sites More sharing options...
