spleecho Posted February 12, 2020 Author Report Share Posted February 12, 2020 Yeah: new Garmin sl30 navcom (not being installed) newish Garmin xponder king kma 20 audio panel kt76 transponder flightcom 403 intercom with soft tone mooney engine gauge cluster-the small six pack fuel pressure/manifold gauge voltmeter shunt electronics international EGT with probe electronics international FP-5 Fuel flow with totalizer and fuel metering block and oil temp module rpm gauge Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 12, 2020 Author Report Share Posted February 12, 2020 4 minutes ago, TexMooney said: You can see how sparse my panel is. KX170B and KI208 are not even hooked up (no harness yet). And no I haven’t flown it yet. Close after one year of work but not there yet. I had no idea how much damage he did robbing all sorts of small and not so small things to put on his RV he’s building. I’m going to lose money on this but I have a thing for saving planes that are destined for the scrapper. Oh that nav-com and transponder begging for upgrade! Quote Link to comment Share on other sites More sharing options...
TexMooney Posted February 12, 2020 Report Share Posted February 12, 2020 You said it. Has something from almost every mfg, King, Narco, Collins. He took the 430 and HSI of course (I would have too). Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 12, 2020 Author Report Share Posted February 12, 2020 Panel is on the CNC machine! 3 Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 13, 2020 Author Report Share Posted February 13, 2020 I hired a voice actor to do the audio files for the MVP-50P voice annunciator files. You may download and use it for your own just chop the pieces you need. Not for re-sale. Zipped folder is already chopped down to 8-bit WAV files, I think you can go up as much as 22KHz for better sound quality. Voice.mp3 Annunciator Files.zip 1 1 Quote Link to comment Share on other sites More sharing options...
bonal Posted February 14, 2020 Report Share Posted February 14, 2020 Mooney space win win. I noticed in the first post that the Sky beacon was being replaced so I reached out and we struck a good deal for the purchase of the unit which I installed today. So how about that now I'm compliant and can fly into the Charlie and Bravo. Truth is we only needed it for KLVK as its one we need to access for family and it is just a mile or two into the SFO veil. Thanks again Spleecho and good luck with all your upgrades Quote Link to comment Share on other sites More sharing options...
ZuluZulu Posted February 14, 2020 Report Share Posted February 14, 2020 10 hours ago, spleecho said: I hired a voice actor to do the audio files for the MVP-50P voice annunciator files. You may download and use it for your own just chop the pieces you need. Not for re-sale. Zipped folder is already chopped down to 8-bit WAV files, I think you can go up as much as 22KHz for better sound quality. Voice.mp3 1.57 MB · 18 downloads Annunciator Files.zip 3.01 MB · 2 downloads Anyone have the number for Gilbert Gottfried’s agent? 1 6 Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 14, 2020 Author Report Share Posted February 14, 2020 Pulled out so much old wire! To say scat tubing needed replacement is an understatement, Mose nose is full of it. Spent hours cleaning the engine and firewall, was awful, years of grime. He put in the avionics as mock up just to show me the light at the end of the tunnel. Wiring harness for transponder is done and was extremely easy, especially with Garmin’s altitude encoder. Hope audio panel goes the same way. Here’s some pics. Anybody got advice on how to paint the aluminum instrument panel? I want to do flat black. 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted February 14, 2020 Report Share Posted February 14, 2020 Nice work! Note that the pushrod tube lock springs on cylinder 4 are not locked yet. Clarence Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 16, 2020 Author Report Share Posted February 16, 2020 Engine is complete, now hooking up sensors to it. Instrument panel is cut and coming in on Tuesday. Guy that cut it for me was beyond cheap and extremely easy to work with. Once I confirm fit I’ll share contact info if you guys need help with your panel. 3 Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 17, 2020 Report Share Posted February 17, 2020 Wow, that was... -a- 1 Quote Link to comment Share on other sites More sharing options...
Nukemzzz Posted February 17, 2020 Report Share Posted February 17, 2020 On 2/14/2020 at 3:54 AM, spleecho said: "Anybody got advice on how to paint the aluminum instrument panel? I want to do flat black. " I think I would black anodize the part. You have a tub capped in the picture below. Mine is open to the engine compartment. Any idea what this tube is for and why yours is capped and mine is not? My best guess was this is for warmish air vs hot air so you could adjust the temps but I'm not sure. On 2/14/2020 at 3:54 AM, spleecho said: Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 17, 2020 Author Report Share Posted February 17, 2020 16 minutes ago, Nukemzzz said: I think I would black anodize the part. You have a tub capped in the picture below. Mine is open to the engine compartment. Any idea what this tube is for and why yours is capped and mine is not? My best guess was this is for warmish air vs hot air so you could adjust the temps but I'm not sure. I looked inside before and it is just a bare box with no valve so if I were to remove this I would just be sucking in cold air instead of warm from the engine. No clue where this was supposed to go Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 18, 2020 Report Share Posted February 18, 2020 That is the area where (I believe) the hot and cold air go to before going into the cabin... On my 65C, that was a mixing box with two slide gates... one to control the hot air, the other cold... After 65.... slide gates got replaced with butterfly type valves... Be on the look-out for your heater / cabin air system... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Guest Posted February 18, 2020 Report Share Posted February 18, 2020 18 hours ago, Nukemzzz said: I think I would black anodize the part. You have a tub capped in the picture below. Mine is open to the engine compartment. Any idea what this tube is for and why yours is capped and mine is not? My best guess was this is for warmish air vs hot air so you could adjust the temps but I'm not sure. That is meant to open and in some cases has a Scat duct which runs down to the cowl flap opening. It is open to allow a constant flow of air around the muffler to help cool it when the heater valve to the cabin is closed. Clarence Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 18, 2020 Author Report Share Posted February 18, 2020 6 hours ago, M20Doc said: That is meant to open and in some cases has a Scat duct which runs down to the cowl flap opening. It is open to allow a constant flow of air around the muffler to help cool it when the heater valve to the cabin is closed. Clarence Oh wow good to know! So I should probably uncap this then huh Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 18, 2020 Author Report Share Posted February 18, 2020 Finally some shinny stuff on the plane! 2 Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 19, 2020 Report Share Posted February 19, 2020 Does the shunt get a roof over it to keep things from falling on it? Often, they get left open... anything that falls against and grounds a high current can get quite sparky... The install looks great! Best regards, -a- Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 19, 2020 Author Report Share Posted February 19, 2020 9 hours ago, carusoam said: Does the shunt get a roof over it to keep things from falling on it? Often, they get left open... anything that falls against and grounds a high current can get quite sparky... The install looks great! Best regards, -a- Yes it does, got those boots to put on once they wire it up. @m20doc you were right about the vent on the heating scat hose, it is supposed to go down to be vented out, I am not sure why the last guy just capped it off but there is a butterfly valve inside the box that vents the heat out so I ordered 4 feet of 1 1/4 scat hose to route down towards exhaust to get the airflow back thru it once the heat is shut off inside the cabin. Thanks for this! 2 Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 19, 2020 Author Report Share Posted February 19, 2020 It was a perfect fit! If you guys need help with CNC-ing your stuff his name is Hector Franco in California, his email is jrframer1@gmail.com He was really helpful extremely reasonable with price and time. 3 Quote Link to comment Share on other sites More sharing options...
Raptor05121 Posted February 19, 2020 Report Share Posted February 19, 2020 Wow that is gorgeous. Are you going to paint and silkscreen it too? Quote Link to comment Share on other sites More sharing options...
spleecho Posted February 19, 2020 Author Report Share Posted February 19, 2020 17 minutes ago, Raptor05121 said: Wow that is gorgeous. Are you going to paint and silkscreen it too? Yeah I am very happy how it turned out! So my original plan for this was to be flat black powder coated then silkscreen the info but now it's a no go as I spoke to a shop and they say it would go up to 400F in cooking up the powder coat and looking at the 6061 T-6 aluminum data sheet that would actually soften and weaken the panel. Now the plan is to etch prime and paint, hopefully comes out good. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 19, 2020 Report Share Posted February 19, 2020 5 hours ago, spleecho said: It was a perfect fit! If you guys need help with CNC-ing your stuff his name is Hector Franco in California, his email is jrframer1@gmail.com He was really helpful extremely reasonable with price and time. It looks really good! What are you going to do with all of that empty space? Clarence Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted February 19, 2020 Report Share Posted February 19, 2020 12 minutes ago, M20Doc said: What are you going to do with all of that empty space? Use it as a whiteboard to write down clearances and other notes. Kids can doodle on it on long flights... 1 3 Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 20, 2020 Report Share Posted February 20, 2020 I know the EI guy is looking forward to the finished pic.. they like to post actual pics Of their products on their website... @ Oregon87 if you want to show it... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
