Nukemzzz Posted January 31, 2020 Report Share Posted January 31, 2020 66’ M20e. Just below the power boost mounting bracket I have a threaded hole that is clearly missing a bolt. See the attached pic. Any idea what goes here? Do I have a part laying in a cornfield somewhere? Quote Link to comment Share on other sites More sharing options...
kpaul Posted January 31, 2020 Report Share Posted January 31, 2020 @M20Docsomeone needs your expert photograph dialogistic skills. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 31, 2020 Report Share Posted January 31, 2020 Usually the ram air door cable that is secured to that steel bracket with the clamp in the picture goes there. Clarence Quote Link to comment Share on other sites More sharing options...
Hank Posted February 1, 2020 Report Share Posted February 1, 2020 3 hours ago, M20Doc said: Usually the ram air door cable that is secured to that steel bracket with the clamp in the picture goes there. Clarence Absolutely amazing! Quote Link to comment Share on other sites More sharing options...
Nukemzzz Posted February 1, 2020 Author Report Share Posted February 1, 2020 I see, so someone relocated the power boost door cable mount bracket and so there really isn’t anything missing. Thanks! Quote Link to comment Share on other sites More sharing options...
Guest Posted February 1, 2020 Report Share Posted February 1, 2020 I couldn’t find a picture of the correct installation, but item 10 is the cable, and all of the parts are listed under that number. Clarence Quote Link to comment Share on other sites More sharing options...
Igor_U Posted February 4, 2020 Report Share Posted February 4, 2020 (edited) On 2/1/2020 at 1:00 PM, M20Doc said: I couldn’t find a picture of the correct installation, but item 10 is the cable, and all of the parts are listed under that number. Clarence Clarence, I have a question about this P/L and I hope you have answer (1967 M20F): PL calls item 8 an MS2191904G4 Adel clamp but it should be a bracket. Would you know the p/n for it; is it Lycoming part or Mooney? Mine has a worn hole as cable is passing trough and would like to replace it. Does it have a grommet? Thank you. Edited February 4, 2020 by Igor_U Quote Link to comment Share on other sites More sharing options...
Guest Posted February 4, 2020 Report Share Posted February 4, 2020 43 minutes ago, Igor_U said: Clarence, I have a question about this P/L and I hope you have answer (1967 M20F): PL calls item 8 an MS2191904G4 Adel clamp but it should be a bracket. Would you know the p/n for it; is it Lycoming part or Mooney? Mine has a worn hole as cable is passing trough and would like to replace it. Does it have a grommet? Thank you. The earlier IPC doesn’t show it, but from the J model IPC item 87 is what you’re looking for. Clarence Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 5, 2020 Report Share Posted February 5, 2020 Clarence is awesome! Thank you for being you... -a- Quote Link to comment Share on other sites More sharing options...
