ltdoyle Posted January 25, 2020 Report Share Posted January 25, 2020 I have just under 100 SMOH on a Lycoming IO-360 installed in my J. The other day I went out and found a puddle of oil that had dripped down on the nose tire. After cleaning the engine and flying, I looked it over. What I discovered is a small oil puddle on the oil pan, directly above the intake tube. I would wipe it off, then watch it reform. Apparently there is a pin hole or very small crack at that location. Has any had this issue before and how was it corrected? Quote Link to comment Share on other sites More sharing options...
takair Posted January 25, 2020 Report Share Posted January 25, 2020 It almost looks like a crack or manufacturing flaw in that flange area. Wonder if they bead blasted and thinned it just enough to start leaking. Kind of strange, but the castings are rather crude to begin with. Quote Link to comment Share on other sites More sharing options...
Yetti Posted January 25, 2020 Report Share Posted January 25, 2020 (edited) is it painted? It looks like it has been JB welded (poorly) or some other sealant. What shop did your OH? Edited January 25, 2020 by Yetti Quote Link to comment Share on other sites More sharing options...
ltdoyle Posted January 25, 2020 Author Report Share Posted January 25, 2020 (edited) It is painted, overhaul was done by Jewell last April. I don't think it is patched, but maybe got thinned during inspection, bead blasting? I am thinking about draining the oil and cleaning it real good and trying a little JB Weld hi heat. If that did not work, then remove the pan and send it to someone like divco. Edited January 25, 2020 by ltdoyle Spelling Quote Link to comment Share on other sites More sharing options...
larryb Posted January 25, 2020 Report Share Posted January 25, 2020 What’s up with that hose glued to the intake tube? My J didn’t have anything like that. Quote Link to comment Share on other sites More sharing options...
ltdoyle Posted January 25, 2020 Author Report Share Posted January 25, 2020 Standby vacuum Quote Link to comment Share on other sites More sharing options...
MATTS875 Posted January 25, 2020 Report Share Posted January 25, 2020 Unusual. Hopefully an easy repair. My plane is in annual at Jewell now Quote Link to comment Share on other sites More sharing options...
ltdoyle Posted January 25, 2020 Author Report Share Posted January 25, 2020 I was really happy with the oh done by Jewel, I think this is just one f those things that happens. Quote Link to comment Share on other sites More sharing options...
MATTS875 Posted January 25, 2020 Report Share Posted January 25, 2020 13 minutes ago, ltdoyle said: I was really happy with the oh done by Jewel, I think this is just one f those things that happens. Great to hear. I only have around 1400 hours on my engine but when the time comes Jewell will probably be my choice. Quote Link to comment Share on other sites More sharing options...
Yetti Posted January 25, 2020 Report Share Posted January 25, 2020 i'd pick at the paint just below the leak and see what is there. Kind of looks like orange RTV Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted January 25, 2020 Report Share Posted January 25, 2020 What’s up with that hose glued to the intake tube? My J didn’t have anything like that. I can’t believe that’s certified technique, especially adding in hose clamps because they know the glue eventually will fail.Tom Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted January 25, 2020 Report Share Posted January 25, 2020 Just for what it’s worth...when I ordered a factory rebuilt engine from Lycomming, they delayed shipment to me because the needed a shipment of oil pans/ intake to arrive. That shocked me, as I would have thought they were near bulletproof and would never fail... Quote Link to comment Share on other sites More sharing options...
Guest Posted January 25, 2020 Report Share Posted January 25, 2020 1 hour ago, ArtVandelay said: I can’t believe that’s certified technique, especially adding in hose clamps because they know the glue eventually will fail. Tom That’s the way every standby vacuum fitting is done in my experience, other than engines with an intake coupling hose. On those, a clean hole is cut through the rubber and is aligned with the gap between the intake tube and the stub in the oil sump. The nipple on the saddle fitting enters the hole and is held on with hose clamps. Clarence Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted January 25, 2020 Report Share Posted January 25, 2020 That’s the way every standby vacuum fitting is done in my experience, other than engines with an intake coupling hose. On those, a clean hole is cut through the rubber and is aligned with the gap between the intake tube and the stub in the oil sump. The nipple on the saddle fitting enters the hole and is held on with hose clamps. Clarence Why not have a tee fitting?Tom Quote Link to comment Share on other sites More sharing options...
Gagarin Posted January 25, 2020 Report Share Posted January 25, 2020 I had a similar problem and found two pin holes at the oil sump causing the leak. Sealed the holes with Marine Tek and problem solved. It is not unusual for a casting to loose some of the grain over time 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 25, 2020 Report Share Posted January 25, 2020 19 hours ago, ltdoyle said: It is painted, overhaul was done by Jewell last April. I don't think it is patched, but maybe got thinned during inspection, bead blasting? I am thinking about draining the oil and cleaning it real good and trying a little JB Weld hi heat. If that did not work, then remove the pan and send it to someone like divco. Looks like it is in the area of a weld or mold mark... Good that you have clear pics... Send the pic to Jewell and see what they say... Divco is probably a great resource as well... especially on how to fix it properly... The problem with a leak at the bottom of the oil pan... how far down is it? If the method of fixing it doesn’t hold... will you run out of oil? How easy is an oil pan replacement? A few AMUs? Best regards, -a- Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted January 28, 2020 Report Share Posted January 28, 2020 You could email mike busch...he answered my questions Quote Link to comment Share on other sites More sharing options...
