Not having luck with surefly magneto. Suggestions?
ragedracer1977
Set timing exactly to TDC.  Set dip switches correctly.  Ran a manifold pressure line.
Engine seems to start pretty good, at least as good as it used to.  Runs good at idle, mag drop check is good at 1800 RPM.
At full power, its missing a little when on only the surefly mag.  I called them, they said check the timing.  I triple checked.  It's right.
I pulled the plugs, checked gap, cleaned, etc.
No change.  Still just not quite right.
They're closed now, so I thought I'd reach out here.  Any ideas what the heck I'm doing wrong?
Link to comment
Share on other sites
Might be worth swapping plugs top to bottom to see if problem moves to the mag....rule out the plugs that way.  Could be the harness too.  To check the timing, are you looking at the light flash sequence?  I had a bad dip switch.  Switch was set correct, but the sequence was not correct.  Had to check it three times before I believed my eyes.
Link to comment
Brand new harness.
Light flash sequence is correct
Link to comment
I came back to the hangar. Just couldn't take it.  I spent 30 minutes checking for TDC. I used a digital dial indicator to verify.  It sure looks like it was off by 2 degrees.  2.  I'm wondering if in the final torquing of the nuts, it slightly shifted?  This time, I left battery timing power hooked up all through the process.  The light never came on while torquing and no matter how many times I spin the prop, it goes out exactly at what I'm indicating is TDC.  So... Here's hoping.  Gotta put it back together and see.
Oh, and I had to take the battery box out by myself.  Not an easy proposition on an old C model.  Bolts in the box, nuts in the cockpit.  But, American ingenuity got it done.
Link to comment
Great follow-up, Brice.
Thanks for sharing the details...
Keep an eye on CHTs if they are hotter than normal... timing may have advanced...
If colder... timing may have decreased closer to a TDC...
Not sure if only 2° would make the difference that you initially saw...
Link to comment
Honestly, it probably would have been fine.  When I said missing, it wasn't like shake the cowl off missing, it just wasn't quite right.  You get to know your engine, and what it sounds and feels like.  And it was a little off what it was like on a fresh magneto.
Now it runs like a sewing machine!
Link to comment
11 minutes ago, Browncbr1 said:
Someone here was burning up BY plugs with the surefly and had to switch to finewire.  Keep eye on your plugs
YUP! All is well now with fine wires on the surefly side. I think factory gap is less than ideal for the surefly side, it produces alot stronger spark gapped wider you may have 0 issues with massives.
Link to comment
16 hours ago, carusoam said:
See if Bob has anything to add from his experience... @Bob_Belville (sure-fly Mag question)
Jon beat me to it. Lynn @AGL Aviation, as of the last I heard, had had only one plane with issues with Surefly - the one with massive plugs. Secondly, I believe he was told by SF that the EI worked better with wider gap than spec'd.
Link to comment
Supposedly they used to recommend a .036 gap, but could not for certified planes, because that's so far out of "spec".  I gapped mine to .025.  I'm due for an oil change in about 20 hours (which will be before the end of this month - Yuma formation clinic will put a lot of hours on!).  I'll pull them at oil change and see how they look
Link to comment
