Steve65E-NC Posted January 8, 2020 Report Share Posted January 8, 2020 (edited) My KR85 audio is strong but the needle wanders and will just not settle down. Any suggestions on cause or reasonable repair facility? Edited January 8, 2020 by Steve65E-NC better description of problem Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted January 8, 2020 Report Share Posted January 8, 2020 What's an ADF? j/k 1 1 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 8, 2020 Report Share Posted January 8, 2020 (956) 423-5770 Gulf Avionics, Harlingen TX...talk to Don Wiles Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted January 9, 2020 Report Share Posted January 9, 2020 The real reason to remove an ADF is that if you ever take a checkride with one installed, the examiner might make you try to navigate with it. 1 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 9, 2020 Report Share Posted January 9, 2020 6 hours ago, LANCECASPER said: The real reason to remove an ADF is that if you ever take a checkride with one installed, the examiner might make you try to navigate with it. Still on the written for Private, Instrument and Commercial. Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted January 9, 2020 Report Share Posted January 9, 2020 3 hours ago, RLCarter said: Still on the written for Private, Instrument and Commercial. I was mainly joking. I did an NDB approach for my IFR check ride in 1995 and later flew a few NDB approaches, but GPS makes it so much easier. They still use ADFs frequently in other parts of the world. I mainly used mine to listen to a baseball game on a long flight. 2 Quote Link to comment Share on other sites More sharing options...
tmo Posted January 9, 2020 Report Share Posted January 9, 2020 12 hours ago, LANCECASPER said: The real reason to remove an ADF is that if you ever take a checkride with one installed, the examiner might make you try to navigate with it. Isn't an INOP label meant to prevent this from happening? 3 Quote Link to comment Share on other sites More sharing options...
steingar Posted January 9, 2020 Report Share Posted January 9, 2020 I deep sixed mine after I read how to do an ADF approach. I have no regrets. 1 Quote Link to comment Share on other sites More sharing options...
kortopates Posted January 9, 2020 Report Share Posted January 9, 2020 Unless you fly in Alaska, why would you want to keep an ADF? Is there even a remaining field in the Continental US only served by ADF approach - I doubt it, but interested to know.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 9, 2020 Report Share Posted January 9, 2020 2 hours ago, kortopates said: Is there even a remaining field in the Continental US only served by ADF approach - I doubt it, but interested to know There are a few in S Texas, and KMFE use to have an ILS that required ADF for the Outer Marker, would have to look and see Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 9, 2020 Report Share Posted January 9, 2020 One of the approaches into Morristown, NJ still uses an ADF as part of the Missed approach... So essentially, it is a waypoint in the GPS’ database... +1 for inflight entertainment... but, realistically a BT connection into the audio panel isn’t that hard to come by... For Steve’s wandering needle... start with cleaning connections, see what has come loose, or corroded.... PP thoughts only, not an instrument guru... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
Steve65E-NC Posted January 9, 2020 Author Report Share Posted January 9, 2020 Robert, Thanks: Don, at Gulf Avionics, was very helpful. He suggested a careful cleaning on antenna connector as a start. Also, said that would look at unit and give me a repair quote. They did have the harnesses on hand. 1 Quote Link to comment Share on other sites More sharing options...
kortopates Posted January 9, 2020 Report Share Posted January 9, 2020 There are a few in S Texas, and KMFE use to have an ILS that required ADF for the Outer Marker, would have to look and see But unless any of those fields are ONLY served by an ADF approach then they have lost their utility IMO since there are better options. Like Anthony said, that "required" ADF for the middle marker identification is just a (FAF) Gps waypoint with any IFR GPS.The irony of the lack of utility of ADF is that it's only "real" utility is that you need the ADF operational in the plane just to be "legal" to fly the ADF approach with an IFR GPS; since legally the raw ADF signal needs to be monitored while flying it with your GPS.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 10, 2020 Report Share Posted January 10, 2020 Just checked, VOR RWY 14 at KMFE requires ADF or DME, KHBV has an NDB RWY 13, there are a few more but I can barely spell ADF let alone shoot an approach with one Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 10, 2020 Report Share Posted January 10, 2020 2 hours ago, Steve65E-NC said: Robert, Thanks: Don, at Gulf Avionics, was very helpful. He suggested a careful cleaning on antenna connector as a start. Also, said that would look at unit and give me a repair quote. They did have the harnesses on hand. No problem, Don is the go to guy in this area to get the older boxes repaired Quote Link to comment Share on other sites More sharing options...
jlunseth Posted January 10, 2020 Report Share Posted January 10, 2020 15 hours ago, RLCarter said: Still on the written for Private, Instrument and Commercial. Its a wonder the FAA doesn’t still have range navigation on the written. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 10, 2020 Report Share Posted January 10, 2020 The USCG had a LORAN station down here until 2010ish, might have to fly around and see if the facility is still there Quote Link to comment Share on other sites More sharing options...
kortopates Posted January 10, 2020 Report Share Posted January 10, 2020 Just checked, VOR RWY 14 at KMFE requires ADF or DME, KHBV has an NDB RWY 13, there are a few more but I can barely spell ADF let alone shoot an approach with one Sure there are uses of ADF in many places. But none of them are truly required anymore. Take your KHBV NDB approach example, yet we find there is a GPS LPV approach to the same runway. Why would anyone fly an NDB approach anymore when we have much better options? I don’t even know of any instrument students that have even been trained in NDB approaches in last couple decades - not when a GNS430 is common on most trainers including C150s. But obviously there are still many Mooney’s without an IFR GPS and I’ve trained in many that way.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 10, 2020 Report Share Posted January 10, 2020 9 minutes ago, kortopates said: Why would anyone fly an NDB approach anymore when we have much better options?................ But obviously there are still many Mooney’s without an IFR GPS and I’ve trained in many that way. answered your own question.... and Mooney's aren't alone, but I did see a Cherokee 140 about 10yrs ago with dual 430's in it for sale, basically buying the panel and you got a tired 140 for free 1 Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted January 10, 2020 Report Share Posted January 10, 2020 I certainly have been known to go out in the middle of the night and put an INOP sticker on the ADF receiver before a student's checkride. -Robert Quote Link to comment Share on other sites More sharing options...
markgrue Posted January 11, 2020 Report Share Posted January 11, 2020 I am in the process of installing an adf in my M20D. I don't like having to update the gps database every few months and I got the ADF for $100. I can pick up KMOX in st louis anywhere east of the rockies at 10k ft. I am sure there are lots of other am stations out there also that work. Is it as good as a GPS? No it is not. It is a lot easier to use and cheaper to install and maintain though. Mark 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted January 11, 2020 Report Share Posted January 11, 2020 55 minutes ago, markgrue said: I am in the process of installing an adf in my M20D. I don't like having to update the gps database every few months and I got the ADF for $100. I can pick up KMOX in st louis anywhere east of the rockies at 10k ft. I am sure there are lots of other am stations out there also that work. Is it as good as a GPS? No it is not. It is a lot easier to use and cheaper to install and maintain though. Mark Subscription free nav data, don’t tell Jeppesen or Garmin. Clarence Quote Link to comment Share on other sites More sharing options...
philiplane Posted January 11, 2020 Report Share Posted January 11, 2020 In the southeast US along the coast, there are many times per year when GPS isn't available, sometimes for days. Due to military operations around Savannah, or off the Space Coast of Florida, so you need VOR navigation, or the ADF. Not to mention solar flare activity that degrades it with no warning. I'm hanging onto some old school nav devices alongside my wiz-bang state of the art Garmin goodies because I've found I've needed it more than once a year. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 11, 2020 Report Share Posted January 11, 2020 5 hours ago, RobertGary1 said: I certainly have been known to go out in the middle of the night and put an INOP sticker on the ADF receiver before a student's checkride. -Robert doesnt it need a logbook entry as well? Quote Link to comment Share on other sites More sharing options...
tmo Posted January 11, 2020 Report Share Posted January 11, 2020 6 hours ago, philiplane said: In the southeast US along the coast, there are many times per year when GPS isn't available, sometimes for days. Wouldn't VOR and DME be preferable to ADF? I'm actually planning on removing an ADF to make room for an EDM... Quote Link to comment Share on other sites More sharing options...
