Stephen Posted January 8, 2020 Report Share Posted January 8, 2020 http://www.kathrynsreport.com/search?updated-max=2020-01-08T12:52:00-05:00&max-results=5 1 1 Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted January 8, 2020 Report Share Posted January 8, 2020 1 hour ago, Stephen said: http://www.kathrynsreport.com/search?updated-max=2020-01-08T12:52:00-05:00&max-results=5 Does that count as a prop strike? Next time I guess it was not such a money saver not to pay the line guy after all to pull that gpu for him. Quote Link to comment Share on other sites More sharing options...
Stephen Posted January 8, 2020 Author Report Share Posted January 8, 2020 42 minutes ago, aviatoreb said: Does that count as a prop strike? Next time I guess it was not such a money saver not to pay the line guy after all to pull that gpu for him. Also, is he still PIC if he is technically in the baggage compartment when it taxi's into the tree? Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted January 8, 2020 Report Share Posted January 8, 2020 59 minutes ago, Stephen said: Also, is he still PIC if he is technically in the baggage compartment when it taxi's into the tree? That is a good question. I think this is one for the aviation lawyer specialists. Ever seen one of those videos of a hand-propped piper cub getting away from the pilot and actually taking off and flying away? Imagine that happening with a Pt6 powered 206 with an ATP rated pilot in the baggage compartment?! Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted January 8, 2020 Report Share Posted January 8, 2020 2 hours ago, Stephen said: http://www.kathrynsreport.com/search?updated-max=2020-01-08T12:52:00-05:00&max-results=5 This is a pilot who has 8500 hours .. wow Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted January 9, 2020 Report Share Posted January 9, 2020 2 hours ago, LANCECASPER said: This is a pilot who has 8500 hours .. wow Does he get to log the time riding in the baggage compartment? Pic? Sic? Nic? (Not in command). Quote Link to comment Share on other sites More sharing options...
Stephen Posted January 9, 2020 Author Report Share Posted January 9, 2020 36 minutes ago, aviatoreb said: Does he get to log the time riding in the baggage compartment? Pic? Sic? Nic? (Not in command). Good questions. Because there was no crew whatsoever when he was outside the plane and it taxi'd away.... then he ran down the plane and jumped in the back... So, does exiting the plane terminate his status as PIC at that point? And what is his status if he re-boards the aircraft as PAX or baggage? @carusoam .... like to get an engineering opinion here....probably need an attorney to weigh in as well @DonMuncy 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 9, 2020 Report Share Posted January 9, 2020 3 hours ago, Stephen said: Good questions. Because there was no crew whatsoever when he was outside the plane and it taxi'd away.... then he ran down the plane and jumped in the back... So, does exiting the plane terminate his status as PIC at that point? And what is his status if he re-boards the aircraft as PAX or baggage? @carusoam .... like to get an engineering opinion here....probably need an attorney to weigh in as well @DonMuncy This goes into the engineering category of.... If anything can go wrong, it will go wrong... Most of us don’t have turbines in our Mooneys yet... The closest we can come to replicating this wonderful piece of wackiness... Improper hand propping... Somebody has to be behind the controls... A good quality rope might work... not a piece of rope that is sun drenched... we know how well that works too... Basic rule of thumb... don’t let your airplane embarrass you... it will when given the opportunity... then your friends will remind you about how much you raised their insurance... Best regards, -a- 2 Quote Link to comment Share on other sites More sharing options...
tmo Posted January 9, 2020 Report Share Posted January 9, 2020 Those who don't know history are doomed to repeat it, eh? 2 Quote Link to comment Share on other sites More sharing options...
Austintatious Posted February 13, 2020 Report Share Posted February 13, 2020 you would think with a PT6 if he was going to do this, he would have left the prop in feather (maybe this aircraft cannot do this) Quote Link to comment Share on other sites More sharing options...
bradp Posted February 14, 2020 Report Share Posted February 14, 2020 He’s still the PIC: Pilot in cargo. 2 1 Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted February 16, 2020 Report Share Posted February 16, 2020 Pilot InCognito Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted February 16, 2020 Report Share Posted February 16, 2020 On 1/9/2020 at 3:36 AM, Hyett6420 said: get back in, leave engine running for 20 mins or so to charge/warm battery and then shutdown, remove chocks, do pre-flight and restart and go Sounds reasonable: The PT-6A-20 in this plane burns only about 16 GPH in ground idle. Maybe the pilot didn’t want to “waste” 5-6 gallons of JetA. Quote Link to comment Share on other sites More sharing options...
xcrmckenna Posted February 17, 2020 Report Share Posted February 17, 2020 Sounds reasonable: The PT-6A-20 in this plane burns only about 16 GPH in ground idle. Maybe the pilot didn’t want to “waste” 5-6 gallons of JetA. I bet if you ask him now he would be okay with that....Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
irishpilot Posted February 17, 2020 Report Share Posted February 17, 2020 I have PT6 time and he probably used the GPU because of low battery volts for start. I don't have 206 time, so maybe there is another reason to use the GPU. However, this accident is attributed to complacency and decision making. There were several ways he could have solved the lack of crew problem. Bummer because accidents like this are preventable and raise insurance rates.Sent from my Pixel 3a using Tapatalk Quote Link to comment Share on other sites More sharing options...
Mooneymuscle56m Posted March 22, 2020 Report Share Posted March 22, 2020 (edited) On 1/8/2020 at 3:37 PM, Stephen said: Also, is he still PIC if he is technically in the baggage compartment when it taxi's into the tree? Still logging the turbine PIC time? 1/10th Edited March 22, 2020 by Mooneymuscle56m 1 Quote Link to comment Share on other sites More sharing options...
