1961 Mooney M20B -- Mods Begin!
hammdo
Rest of the avionics are paid and on their way! Found this deal on the Stratus TSO USB ports (don't have a lighter socket):
https://sarasotaavionics.com/avionics/stratus-power?pvari3053-0-302-3799=9692
Buy one get one...
Not bad. One for the pilot and co-pilot...
-Don
Link to comment
Share on other sites
I was looking for the details on the buy one get one...   :)
Like the rest of the sentence... buy one get one... free?
Thus actually ending up with two units, for the price of one...
I might be thinking too much on this one... :)
Get one for the back seaters?
Link to comment
Well got a surprise today — dead battery cell. Been on the charger too. Luckily , there is a local aviation supply shop in Addison (Falcon Crest Aviation) that had a Concord in stock. I was going to do my Mooney training today but the weather didn’t cooperate— good thing it didn’t.
New battery goes in. My plane was moved due to the storms last Friday (shared hanger) so not sure if the power was off on the charger or something else. Gonna seal up the dog house as there are areas air can escape while I’m in there.
My 2fers USBs came in — nice to have for each side of the panel...
-Don
Edited by hammdo
Link to comment
14 hours ago, hammdo said:
Yes Addison TX.
Forgot to mention that...
-Don
One of my favorite hangouts while learning to fly...mid 90s or so...
I lived up by where the Cowboys’ practice field was at.
Worked down by RedBird /Dallas exec...
Link to comment
Some days it’s not meant to be. Brian came up yesterday after the weather finally cleared. We tried several times and finally schedules and weather worked out. We did a briefing, pre-flight, and when we were all set - intercom and audio panel quit working. I have a flightcom and a Bendix audio panel but when that happened, we scrubbed it. Was a nice day too — windy but nice.
So, I’ll get all the new equipment installed and try again in February.
Ugh, really want to fly this baby ;o)...
BTW, Brian is awesome. We spent time going over the Mooney, speeds, things to look for, etc. Was a great experience - outside of the avionics...
-Don
Link to comment
  • 2 weeks later...
  • 2 weeks later...
Received word that the PAR is finally shipping! 6 week backlog due to the remote radio.  Also found out my Cardiac MRI  came back > 40% EF — which means I can apply for a third class medical!  Very excited about that. Now, if the rental plane would just stop having squaws, I could get my transition done... Got the intercom fixed in mine and the radio is receiving but, mike-jack is bad. Portable works though. Ah, the little things...
-Don
Link to comment
  • 2 weeks later...
Did my medxpress and finally applied for my 3rd class. AME said 3 to 4 months and I may need to do more ‘tests’ if they need them. Now it’s in the FAA’s hands... did all they asked so fingers crossed.
-Don
Link to comment
Fantastic!
Once you get one ClassIII... Then the option for basic med and the easier process that goes along with it...
Good luck with the paper chase... insure every document you send using the mail system...
They somehow know how important your docs are to you...
Learn the phone numbers for the FAA medical group... you may have to call them up to find out what desk it is sitting on...
These are typical challenges of a pilot going through the Special Issuance program...
Hopefully you can avoid this small pain...
Link to comment
Mooney is now at the shop for avionics and annual!
Great day to fly. Man, big differences between the F and B. You wouldn’t think 20 hp would make that much difference but, it does. B is much lighter and I could tell. Suttle differences yet still enough to feel. Overall fun day of ‘rehab’ for me. Was awesome to fly her vs the F.
Cant wait to fly her once everything is finished. Did notice a difference in the Johnson bar vs the F. Need to see how the down block lock looks..
-Don
Link to comment
Don,
Its an interesting 10% more...
So much HP is used to fly the plane...
It is the excess HP that allows us to really enjoy the plane...
The excess HP allows for shorter T/O runs, and awesome climb rates...
Use caution on really cold days... This gives us excess HP too, except it may also generate very high ICPs as well...
In this case keep an eye on DA and MP when pushing the throttle in...
These are things that can separate the cylinder heads from the cylinder... not common, unless you are unfamiliar...
Link to comment
It’s funny, the B is 9% lighter but has 10% less power. You’d think they’d even out a bit.
my B weight/HP ratio is 13.61 lbs to hp (2450/180)
the F is 13.75 lbs to hp (2750/200)
@ max weight ;o)
I’m sure the B is closer to max weight than the F when flying (I believe the F was 300 lbs light so it would be 2450/200 so 12.25 lbs to hp)
may be I need to fly the B more ;o)
-Don
Link to comment
  • 2 weeks later...
Panel is Done!  Simple and clean. Co-pilot headphone jacks are right where you want them. The USB charger is left and above the jacks. As you can see, very clean look.
 We added an Avionics master switch and circuit breakers for each new avionics -- you'll see those on the right side:
Avionics install by Edge Aviation in Commerce Texas (yes, the do know about Mooneys!):
I'll get a better pic later -- was out of the plane when I took this one.  IFD440 and AV30-C will be upgrades in the future. Looks like I'll have room for the IFD for sure:
Did gear retraction a few times while I was there. Got a good shot of the Down Lock Block -- yeah, it needs to be replaced for sure:
Annual has gone well and is almost done -- needed 2 new main tires -- got those done.   They did find a surprise though:
Rat's nest with a dead rat -- They gave me enough graphic detail so I'm glad no pics.  This plane was in a hanger @ Caddo Mills where the fields were real close.  Its now in the main hanger were they do the unmanned drones so, less likely but, I know how they got in and where to look.  Until I get a hanger where its not out in the boonies, I'll check this very often for sure.  Luckily, no 'damage' from the usual stuff.  Gonna look for a CorrosionX treatment next.  For a plane that is really 60 years old (built in 1960) very clean.
There will be some items we'll address as time goes on (mags when they get near 500 hrs, that kind of thing).  Overall, not bad for this old of a plane.  I should be able to get it next week and do a maintenance flight before getting her back to Caddo.  I have a habit of doing a flight local to the AP shop (pattern work, etc.) just to make sure nothing is amiss before I head out. I usually get a hanger near my AP but, not this time so its going to be a safety flight then, ground check afterwards to make sure before going back.
With all this CorVid 19 going on, wonder if the insurance co's will be able to re-coop $ since 'less' is going on in the Aviation world -- may make a difference in premiums.
-Don
Link to comment
