Seth Posted December 28, 2019 Report Share Posted December 28, 2019 Not good for the SF50. Curious as to what started the fire on a chocked and parked SF50. Anyone know anything yet? Curious. Glad no one was injured. Also curious as to the insurance claims for the aircraft parked near it (heat). -Seth Quote Link to comment Share on other sites More sharing options...
Seth Posted December 28, 2019 Author Report Share Posted December 28, 2019 https://aviation-safety.net/wikibase/231740 Quote Link to comment Share on other sites More sharing options...
Seth Posted December 28, 2019 Author Report Share Posted December 28, 2019 Parked due to electrical problems Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted December 28, 2019 Report Share Posted December 28, 2019 It will buff out. 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted December 28, 2019 Report Share Posted December 28, 2019 Where do they put the fancy batteries in that plane? What fancy battery do they use? Is there a Lithium based battery to go with that? If the battery is up front for balance... and it is a lithium ion battery... the big fire may not have reached any other fuel source like jet fuel in the wings.... unless the cockpit fuel valve got heated up enough... (all speculation, just guesses) PP thinking out loud, no knowledge of any batteries in a Brand C plane... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
MooneyMitch Posted December 28, 2019 Report Share Posted December 28, 2019 So fortunate no fuel explosion ! 1 Quote Link to comment Share on other sites More sharing options...
EricJ Posted December 28, 2019 Report Share Posted December 28, 2019 Glad nobody was hurt. Another Cirrus parachute success story. 1 4 Quote Link to comment Share on other sites More sharing options...
carusoam Posted December 28, 2019 Report Share Posted December 28, 2019 Is there a firewall behind the passenger seats? Other things that can burn in an airplane.... TKS anti ice liquid... similar to alcohol in the way it burns... https://www.fire.tc.faa.gov/pdf/TN08-9.pdf Anything left behind in the passenger compartment... battery operated devices...? How many batteries support the instrument panel devices...? Post crash fires have been known to ignite the rocket motor launching the parachute.... PP thoughts only, not a fire resistance expert... Best regards, -a- Picture borrowed from Max Trescott.... the SF50 opened up... Quote Link to comment Share on other sites More sharing options...
DXB Posted December 28, 2019 Report Share Posted December 28, 2019 2 hours ago, carusoam said: Where do they put the fancy batteries in that plane? What fancy battery do they use? Is there a Lithium based battery to go with that? If the battery is up front for balance... and it is a lithium ion battery... the big fire may not have reached any other fuel source like jet fuel in the wings.... unless the cockpit fuel valve got heated up enough... (all speculation, just guesses) PP thinking out loud, no knowledge of any batteries in a Brand C plane... Best regards, -a- My first thought as well - but this appears to be a gen 1 aircraft with only 28V lead acid batteries. Turns out only the gen 2 uses lithium ion. https://aviationweek.com/business-aviation/cirrus-sf50-vision-jet-operators-survey 1 Quote Link to comment Share on other sites More sharing options...
jetdriven Posted December 29, 2019 Report Share Posted December 29, 2019 1 Quote Link to comment Share on other sites More sharing options...
thinwing Posted January 1, 2020 Report Share Posted January 1, 2020 Owner gonna get a big “you caused so much air pollution “fine from Santa Monica city council. 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted January 3, 2020 Report Share Posted January 3, 2020 On 12/28/2019 at 11:13 AM, MooneyMitch said: So fortunate no fuel explosion ! Does Jet A explode? Quote Link to comment Share on other sites More sharing options...
MooneyMitch Posted January 3, 2020 Report Share Posted January 3, 2020 3 hours ago, Yetti said: Does Jet A explode? Thank you for your input. I used incorrect terminology. Better words would have been no fire, or no explosion from fuel vapor. Quote Link to comment Share on other sites More sharing options...
Hank Posted January 3, 2020 Report Share Posted January 3, 2020 3 hours ago, Yetti said: Does Jet A explode? Ever seen the large fireball when a military jet impacts the ground (even when unarmed)? That's close enough to an explosion for me . . . 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted January 3, 2020 Report Share Posted January 3, 2020 4 minutes ago, Hank said: Ever seen the large fireball when a military jet impacts the ground (even when unarmed)? That's close enough to an explosion for me . . . Is a fireball the same as an explosion? I feel like I am going to be sending my friend at Shell who blows stuff up for his job an email soon. Quote Link to comment Share on other sites More sharing options...
MooneyMitch Posted January 3, 2020 Report Share Posted January 3, 2020 Regardless of the correct scientific description or terminology (which is interesting at this point ), the results can be horrific! Are results from impact or static fuel fires, or fuel vapor fires different? Remember the intentional remotely controlled crash of the 707 (I believe) at Edwards AFB years ago? That was an experiment attempting to discover Jet fuel that would not create a fireball upon impact. Unsuccessful it was! Fireball or explosion......it was one huge catastrophic event!! Edit: fuel that would minimize the fireball. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted January 3, 2020 Report Share Posted January 3, 2020 https://en.m.wikipedia.org/wiki/Controlled_Impact_Demonstration Quote Link to comment Share on other sites More sharing options...
Yetti Posted January 3, 2020 Report Share Posted January 3, 2020 We have moved a bit from a static plane catching fire to impacts. Moving back to static planes. It has always interested me that we stick electrical current into gasoline and Jet A tanks in the form of fuel pumps and repressive fuel gauges and more things don't go boom. On the Cirrus jet it looks like all the fire was up high. Engine was not really involved, fuel tanks in the wings not involved. I am going to vote ELT battery or laptop battery or stratus battery went uncontrolled. Quote Link to comment Share on other sites More sharing options...
Urs_Wildermuth Posted January 3, 2020 Report Share Posted January 3, 2020 This is quite a significant event for the SF50. Hopefully they will find out fast what caused this and take corrective action if necessary. 1 hour ago, Yetti said: I am going to vote ELT battery or laptop battery or stratus battery went uncontrolled. Seeing how Ethiopian almost lost a 787 to a ELT Battery run away, I think you may well have a good theory here. https://aviation-safety.net/database/record.php?id=20130712-0&lang=en 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted January 3, 2020 Report Share Posted January 3, 2020 1 minute ago, Urs_Wildermuth said: This is quite a significant event for the SF50. Hopefully they will find out fast what caused this and take corrective action if necessary. Seeing how Ethiopian almost lost a 787 to a ELT Battery run away, I think you may well have a good theory here. https://aviation-safety.net/database/record.php?id=20130712-0&lang=en Um Hey Dad, I think I left my vape pen in the Cirrus Jet on the charger....... Quote Link to comment Share on other sites More sharing options...
Jourdan Urbach Posted January 5, 2020 Report Share Posted January 5, 2020 For those still curious, it was a short in the entertainment system. The SF50 has quite a large fold-down screen which is attached to the midships ceiling. Preliminary reports implicate a high-voltage USB outlet in that device, which is not required to be manufactured to "aviation standards," whatever those might be. 1 1 Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted January 5, 2020 Report Share Posted January 5, 2020 For those still curious, it was a short in the entertainment system. The SF50 has quite a large fold-down screen which is attached to the midships ceiling. Preliminary reports implicate a high-voltage USB outlet in that device, which is not required to be manufactured to "aviation standards," whatever those might be. High voltage USB? I think USB is 5V unless one of the newer versions changed that.Tom Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted January 5, 2020 Report Share Posted January 5, 2020 USB power ports do provide 5 volts DC. None are higher voltage. USB ports built to newer standards such as 3.0 will provide higher current than the early versions. No USB port will provide a lot of power — the maximum 1.5 amps output at 5 volts is (let me get my slide rule) only 7.5 watts. Quote Link to comment Share on other sites More sharing options...
EricJ Posted January 5, 2020 Report Share Posted January 5, 2020 8 hours ago, Jourdan Urbach said: For those still curious, it was a short in the entertainment system. The SF50 has quite a large fold-down screen which is attached to the midships ceiling. Preliminary reports implicate a high-voltage USB outlet in that device, which is not required to be manufactured to "aviation standards," whatever those might be. Sounds to me like somebody is making an excuse. Quote Link to comment Share on other sites More sharing options...
Hank Posted January 5, 2020 Report Share Posted January 5, 2020 5 hours ago, Jerry 5TJ said: USB power ports do provide 5 volts DC. None are higher voltage. USB ports built to newer standards such as 3.0 will provide higher current than the early versions. No USB port will provide a lot of power — the maximum 1.5 amps output at 5 volts is (let me get my slide rule) only 7.5 watts. I have one plugged in in my car that's labeled 2.4A . . . Some plugins advertise higher amperage for quicker charging. Quote Link to comment Share on other sites More sharing options...
