Cyril Gibb Posted November 14, 2019 Report Share Posted November 14, 2019 I have a GNS430W and currently use Jepp nav data. For the last 2 updates, the update has failed if I use the latest Jepp JDM application. After doing some problem determination, I can successfully load the navdata using an old version of the JDM. I think it's because I have the silver (old) navdata card as opposed to the orange label (new) data card. It's going to cost me a couple hundred bucks just to buy an orange label card. Additionally, the obstacle db is outdated. It might be time to move to Garmin... less expensive too Speculation abounds on Al Gores interweb, so I'm asking if anyone has personal experience with the same setup as I have, and moved to the Garmin nav package. Specifically, can I use my existing nav and terrain data cards moving to Garmin, and does the single programmer work for both navdata and terrain? Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted November 14, 2019 Report Share Posted November 14, 2019 I used Garmin last year for my dual WAAS subscription with silver label cards. It works fine, but you need to buy the Garmin programmer hardware as the Jepp version does not work. Their programmer handles the terrain card too.I switched back to Jepp this year at OSH to get a show discount.Both are far overpriced for simply passing along government data IMO...Sent from my LG-US996 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
rbridges Posted November 14, 2019 Report Share Posted November 14, 2019 I went ahead and bought the garmin programmer. For whatever reason, it's cheaper going through them than jeppesen for my 430. Quote Link to comment Share on other sites More sharing options...
Rwsavory Posted November 14, 2019 Report Share Posted November 14, 2019 45 minutes ago, Cyril Gibb said: Specifically, can I use my existing nav and terrain data cards moving to Garmin, and does the single programmer work for both navdata and terrain? Yes and Yes. I just moved from Jepp to Garmin. Everything works fine. 1 Quote Link to comment Share on other sites More sharing options...
StevenL757 Posted November 14, 2019 Report Share Posted November 14, 2019 50 minutes ago, Cyril Gibb said: I have a GNS430W and currently use Jepp nav data. For the last 2 updates, the update has failed if I use the latest Jepp JDM application. After doing some problem determination, I can successfully load the navdata using an old version of the JDM. I think it's because I have the silver (old) navdata card as opposed to the orange label (new) data card. It's going to cost me a couple hundred bucks just to buy an orange label card. Additionally, the obstacle db is outdated. It might be time to move to Garmin... less expensive too Speculation abounds on Al Gores interweb, so I'm asking if anyone has personal experience with the same setup as I have, and moved to the Garmin nav package. Specifically, can I use my existing nav and terrain data cards moving to Garmin, and does the single programmer work for both navdata and terrain? I've been using JDM for a few years now with multiple cards on different versions of JDM and never had an issue. Quote Link to comment Share on other sites More sharing options...
toto Posted November 14, 2019 Report Share Posted November 14, 2019 I only have the green label cards, but switched from the Jeppesen writer to the Garmin writer with no problems. I'm not a fan of the Garmin software or the weird loose integration between the software and fly.garmin.com, but it works just fine. Quote Link to comment Share on other sites More sharing options...
