Cruiser Posted October 21, 2019 Report Share Posted October 21, 2019 Looks like I might need the inboard fuel sender replaced/repaired. Any ideas on availability, costs. sources......... thanks Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 21, 2019 Report Share Posted October 21, 2019 There must be a few around here somewhere... Unless you want to go Cies... as there have been a few people that have gone Cies already... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Oscar Avalle Posted October 22, 2019 Report Share Posted October 22, 2019 Looks like I might need the inboard fuel sender replaced/repaired. Any ideas on availability, costs. sources......... thanks I just replaced mine with CIES senders. There are digital and extremely precise. About 400 each. Oscar Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted October 22, 2019 Report Share Posted October 22, 2019 If my memory is correct, the old mechanical ones are about $250. Quote Link to comment Share on other sites More sharing options...
NicoN Posted October 22, 2019 Report Share Posted October 22, 2019 Are you sure, you need replacement? Our LH fuel gauge was showing max half of the capacity. It turned out, that there was one! of the 4 or five screws NOT fitted with a shoulder washer. That was enough to kick the inboard sensor out of the game. Repair was easy. Re-assembling the plastic-panels not ..... Quote Link to comment Share on other sites More sharing options...
Cruiser Posted October 22, 2019 Author Report Share Posted October 22, 2019 It looks like this ^^ is what is happening. Installed resistance was 5.7 K ohm. Bench resistance of the sender is 0 - 30 Ohms. Fuel sender checks good. 1 Quote Link to comment Share on other sites More sharing options...
M20F-1968 Posted November 16, 2019 Report Share Posted November 16, 2019 These can be easily rebuilt. Contact Air Parts of Lockhaven. Keep a back-up set so when one needs replacing, you can immediately replace it and send the removed one for overhaul. John Breda Quote Link to comment Share on other sites More sharing options...
FloridaMan Posted November 17, 2019 Report Share Posted November 17, 2019 On 10/22/2019 at 6:55 PM, Cruiser said: It looks like this ^^ is what is happening. Installed resistance was 5.7 K ohm. Bench resistance of the sender is 0 - 30 Ohms. Fuel sender checks good. Had the same issue with my Rocket. The wire between the two senders was broken. Quote Link to comment Share on other sites More sharing options...
