RobertGary1 Posted October 19, 2019 Report Share Posted October 19, 2019 (edited) Best method? Rubbing compound??-Robert -Robert Edited October 19, 2019 by RobertGary1 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted October 19, 2019 Report Share Posted October 19, 2019 I would start with polishing compound, rubbing compound might be too aggressive 1 Quote Link to comment Share on other sites More sharing options...
Andy95W Posted October 19, 2019 Report Share Posted October 19, 2019 See below, about $10 from Walmart. Very gentle, yet surprisingly effective. Easy to use. 1 Quote Link to comment Share on other sites More sharing options...
Hector Posted October 19, 2019 Report Share Posted October 19, 2019 Wash airplane. Use Meguires 105 ultra cut compound with a variable speed polisher (porter cable 6-inch 7424xp). After you do the entire airplane, repeat with Meguires 205 polishing compound. Repeat a final time with good quality wax. It will be a lot of work but it will look damn good. This will remove the oxidation and restore the finish. If the paint is just too far gone then there may not be much you can do. Try the above in a small section. I think you will be surprised how well it works. Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
EricJ Posted October 19, 2019 Report Share Posted October 19, 2019 There's a quite a bit of stuff from the automotive world that works well. I've used some of the 3M stuff as well as Meguiars with good results. Always do a test patch first, and on an airplane it's not a bad idea to wash stuff with water every once in a while between polishes. Testing a small patch first is always a good idea, too. Quote Link to comment Share on other sites More sharing options...
WilliamR Posted October 21, 2019 Report Share Posted October 21, 2019 I would do what Hector and Eric wrote with an add or two. First, I would use a microfiber pad with the 105 then switch over to a fine foam pad with the 205 will likely be your course. Note, the pads will load up very quickly and will loose their effectiveness quickly. Use compressed air (even bottled air for cleaning keyboards work) to clear the pads. Go as light as possible while testing (try a fine cut pad with 205 first and see if you like the results). Goal is to remove as little paint as possible. You will likely find the white paint harder than the colored paint. Adjust polishing accordingly. Best, I am starting on paint correcting my plane this week. Lots of work, but immediately rewarding. William Quote Link to comment Share on other sites More sharing options...
Rwsavory Posted October 21, 2019 Report Share Posted October 21, 2019 I recently used Griot's Complete Compound on a foam polishing pad and a 6 inch random orbital polisher from Harbor Freight. The compound, pad and polisher cost about $100 altogether. This combo, or something similar, will improve your paint. The compound is fairly mild and is designed to use with a machine. There are good videos on Youtube demonstrating how to use a polisher. Here are some before and after pictures. 1 Quote Link to comment Share on other sites More sharing options...
FloridaMan Posted October 21, 2019 Report Share Posted October 21, 2019 Aeroglaze Quote Link to comment Share on other sites More sharing options...
Guitarmaster Posted October 22, 2019 Report Share Posted October 22, 2019 I've heard tiger piss and kerosene in a 50-50 mix is the best thing to use.Sent from my Pixel 2 XL using Tapatalk 1 1 Quote Link to comment Share on other sites More sharing options...
MikeOH Posted October 22, 2019 Report Share Posted October 22, 2019 2 hours ago, Guitarmaster said: I've heard tiger piss and kerosene in a 50-50 mix is the best thing to use. Sent from my Pixel 2 XL using Tapatalk Is that available in the aviation aisle at Wal-Mart? 1 Quote Link to comment Share on other sites More sharing options...
INA201 Posted October 22, 2019 Report Share Posted October 22, 2019 I was planning on painting my plane and a pilot ,who also restores cars, gave me some advice. He said to give buffing a try. My paint was not quite as chalky as yours but is mostly white so it is possible. I borrowed a Flex rotary polisher with some 3m pads and started with the 3M Perfect it Rubbing Compound #1. It worked great but you could tell it was removing some paint, which might be a good thing. Nonetheless it looks great. Instead of using the #2, and #3 3m products I used the Mcguiers Ultimate to fix some small faded areas after the 3M #1. After all of this I waxed the plane with Rejex which is what many of the turbine guys and boat folks use on Imron paint. I have just been following up with Rejex when it stops beading the past couple of years and more often on the leading edges. Bottom line is start with the mildest compound like the Mcguires and move up to more extreme if needed. Be patient as it is time consuming but I having had to buff in three years now so I’m pleased. Quote Link to comment Share on other sites More sharing options...
cujet Posted October 22, 2019 Report Share Posted October 22, 2019 Flitz metal polish used with a 1300 RPM buffer is also a very good way to restore paint. It's aggressive as hell at first, then as you continue the abrasives break down to smaller and smaller bits, leaving a very smooth finish. While at the Gulfstream Savannah service center, I watched the paint pro's do miracles with Flitz. So I tried it and had equally good success. 1 Quote Link to comment Share on other sites More sharing options...
EricJ Posted October 22, 2019 Report Share Posted October 22, 2019 I used the 3M perfect-it stuff, too, but I used the 2 and 3 compounds. This was on 20+ year-old non-factory paint, and it worked very well on the white and blue but the red has resisted most of my efforts. I've use Meguiar's on touch-ups and deeper work where needed, and it also worked very well. I did also use the Turtle Wax premium rubbing compound, like what you can get at Wal-Mart, which also worked well. There are a lot of effective options these days, it seems. Quote Link to comment Share on other sites More sharing options...
Danb Posted October 23, 2019 Report Share Posted October 23, 2019 Griots garage has everything needed including ‘how to’ great tools, pads, waxes polish and finishing materials. I usually do the plane in the spring and fall. Keeps it like new, the bugs almost fall off with minimal effort with there wax on the surface. Once done every time you do it, it gets easier to do. I’ll do mine in a few weeks. Quote Link to comment Share on other sites More sharing options...
Danb Posted October 23, 2019 Report Share Posted October 23, 2019 Griots and McGuire Quote Link to comment Share on other sites More sharing options...
INA201 Posted October 23, 2019 Report Share Posted October 23, 2019 1 hour ago, Danb said: Griots and McGuire Failed to mention. I bought that same Griots polisher and use it on my vehicles but haven't tried it on the plane just yet. Quote Link to comment Share on other sites More sharing options...
larryb Posted October 25, 2019 Report Share Posted October 25, 2019 I have heard you can cause problems magnetizing your plane with a big powered buffer. Not sure if this an OWT or not. Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 25, 2019 Report Share Posted October 25, 2019 Big electric motors can give off some interesting magnetic impulses... similar to using a vacuum cleaner in the plane... Be ready to degauss... if the compass shows any sticking mis-behavior, or is off by more than usual... My M20C used a lot of Maguire’s cleaner polish... use sparingly... it cleans the oxidation off... if the oxidation is deep... it removes a lot of color molecules... It made the 40 year old paint look really good... living outdoors, it got this treatment every year... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
