brad Posted October 2, 2019 Report Posted October 2, 2019 My fuel pressure gauge is stuck at 25. It does go up 3 when the boost pump is turned on, but goes back to 25 when turned off. Any ideas? Thanks. Quote
carusoam Posted October 2, 2019 Report Posted October 2, 2019 Sounds like removal and cleaning might be the order of the day... Similar to FF gauges... they get gummed up... PP thoughts only, not a mechanic... Best regards, -a- Quote
brad Posted October 8, 2019 Author Report Posted October 8, 2019 At some point in time, the fitting had been glued in place. Small piece plugged line. Go figure. 1 Quote
carusoam Posted October 8, 2019 Report Posted October 8, 2019 Great pirep, Brad. I would never have guessed ‘look for loose glue bits’ as the answer... Thanks for sharing the detail. Best regards, -a- Quote
