N201MKTurbo Posted September 29, 2019 Report Share Posted September 29, 2019 What would be worse? The FAA finding that the inspections were never done or that the owner did the inspections? Quote Link to comment Share on other sites More sharing options...
PT20J Posted September 29, 2019 Report Share Posted September 29, 2019 1 minute ago, N201MKTurbo said: What would be worse? The FAA finding that the inspections were never done or that the owner did the inspections? Legally, it’s the same thing. Quote Link to comment Share on other sites More sharing options...
xcrmckenna Posted September 29, 2019 Report Share Posted September 29, 2019 I asked Mike Busch and he pointed out that the Part 1 definition of maintenance includes inspection whereas the definition of preventive maintenance does not. Therefore, an inspection required by regulation cannot be performed as preventive maintenance (unless, in the case of an AD, it is specifically allowed as [mention=15539]EricJ[/mention] and [mention=12030]M20Doc[/mention] have noted). Skip  What about brakes? Before I change them I need to inspect them and decide if they need to be changed. If I determine they need changed isn’t that due to an inspection? And changing my brakes is covered under preventative maintenance?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
PT20J Posted September 29, 2019 Report Share Posted September 29, 2019 3 minutes ago, xcrmckenna said: What about brakes? Before I change them I need to inspect them and decide if they need to be changed. If I determine they need changed isn’t that due to an inspection? And changing my brakes is covered under preventative maintenance? Sent from my iPhone using Tapatalk Yes, but you’re logging the preventive maintenance on the brakes, not the inspection. 2 Quote Link to comment Share on other sites More sharing options...
xcrmckenna Posted September 29, 2019 Report Share Posted September 29, 2019 Yes, but you’re logging the preventive maintenance on the brakes, not the inspection. Got ya. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Andy95W Posted September 29, 2019 Report Share Posted September 29, 2019 I’m not exactly sure what a nit is, but I do believe we’ve picked it. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted September 29, 2019 Report Share Posted September 29, 2019 29 minutes ago, PT20J said: Yes, but you’re logging the preventive maintenance on the brakes, not the inspection. Were there an AD on the brakes, you would need that signed off by an airframe mechanic. You can change the brakes, but he has to comply with the AD and sign it, unless the pilot is permitted to do it, such as the Bendix ignition switch. 1 Quote Link to comment Share on other sites More sharing options...
EricJ Posted September 29, 2019 Report Share Posted September 29, 2019 3 minutes ago, Andy95W said: I’m not exactly sure what a nit is, but I do believe we’ve picked it. A friend used to say, "An unpicked nit grows into a louse." A nit is a baby louse or louse egg.  1 Quote Link to comment Share on other sites More sharing options...
skykrawler Posted September 29, 2019 Report Share Posted September 29, 2019 On 9/28/2019 at 12:48 AM, N201MKTurbo said: Call the FSDO and ask them. They are both sticklers for the rules and know every loophole. It wouldn’t hurt to ask. Sending them a letter may be better because then you would have documentation either approving that you can do the inspection, or not. The worst you will be is where you are now. Never call a FSDO. Rarely does anything good result IMHO. 1 Quote Link to comment Share on other sites More sharing options...
Andy95W Posted September 29, 2019 Report Share Posted September 29, 2019 You have a very different relationship with your FSDO than I do with mine. 2 Quote Link to comment Share on other sites More sharing options...
Shadrach Posted September 29, 2019 Report Share Posted September 29, 2019 (edited) On 9/26/2019 at 7:02 PM, PT20J said: The nozzles are easily removed without loosening any clamps. The clamps are not near the nozzles, there is a lot off flex in the lines and you don't have to deform or stress them. Just loosen the nut and move the lines slightly to the side. Lycoming SI 1275C "Cleaning Fuel Injector Nozzles" says to "Remove the nozzle assembly from the individual fuel lines using a wrench." It does not mention any need to remove the clamps from the lines. I was going to say the same but thought I would be flamed. Edited September 29, 2019 by Shadrach Quote Link to comment Share on other sites More sharing options...
Austintatious Posted September 29, 2019 Author Report Share Posted September 29, 2019 5 hours ago, Shadrach said: I was going to say the same but thought I would be flamed. For what it is worth, I did not have to remove anythign but the fuel lines and the reference air when doing the change, no clamps were loosened. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2019 Report Share Posted September 30, 2019 Continental and Lycoming use different methods to secure fuel injection lines. Clarence Quote Link to comment Share on other sites More sharing options...
thinwing Posted October 2, 2019 Report Share Posted October 2, 2019 Hey guys Quote Link to comment Share on other sites More sharing options...
