Nav light lens and bulb
Chris newton
Welcome aboard Chris...
I think there May be some confusion of what exactly you have in your wing tip...
Do you have the nicely molded wing tips with a single white light pointing aft?
It really helps to post a pic in this case?
It might be a Whelen, Grimes or other brand...
One place you can go is called Lasar.com speak with Dan in parts... give him the same detail you gave here.
Link to comment
Share on other sites
Probably need a photo or a serial number. If it's the enclosed wingtip there are at least 3 different bulbs depending on if it's 12 or 24V and if it's been converted from the bi-pin to the wedge base, if it hasn't been converted it may be worth it. Luckily the cover(which is glass, since it's a tiny assembly and those stupid bulbs get HOT) only looks to be about $130. (68-4250066-30)
Link to comment
