How to replace carpet?
AlexLev
The carpet on the right side got unglued and the foam backing beneath deteriorated quite a bit. I am thinking of pulling both left & right carpets and replacing them with an SCS-interior carpet. Or should I just find a carpet store and have them custom cut something vs using SCS-Interior pre-cut? As long as the carpets have burn certificates, it's fine, right?
Few q's:
1) For those that have done this, what are some good supplies to use to clean up all the crap once the carpets are out? The spar is out in the back so I want to make sure I'm extra careful and clean it without promoting any corrosion.
2) Should I go with the ensolate foam backing again or will it just cause more problems down the road? Does it add extra protection?
3) Any other tips + tricks appreciated.
Link to comment
Share on other sites
Use denatured alcohol, xylene or MEK to remove the glue. Then put in either new carpet or your carpet with the foam removed and install snaps in the floor. The female in the carpet. Two at the rear of each carpet strip. One each between the  rude pedals. Two at the forward end of the center strip. And 4 under the front of the pass seat. 2 under the front of the pilot seat.  Sailrite has The snaps and the tool
Link to comment
Yep, that's how I did it.... Dampen a cloth shop towel with you favorite solvent, lay it over an area you want clean (8"x8" works good) to allow it to soften up the glue.... Kinda a slow process, so plan on a 4~5 hrs depending on how old and how much glue was used
Link to comment
Plastic scraper(s) and, it goes without saying, well fitting respirator. Also good if you can set up a fan to blow air into the plane (so no fumes go through it) while working in it. In the door and out the baggage door is what I did.
Link to comment
Actually paint stripper works very well also. Brush it on, cover with plastic from wallyworld bags and let it work Use a car body plastic bondo spreader to scrape it off Paper towels for the remainder. Clean up with rags and water. Gloves and eye protection are mandatory. So is a fan. Better than smelling MEK for hours, Works pretty fast, Same goes for the door and baggage door seals. Drape plastic to protect the paint, go slow 8" at a time and clean it up real clean.
Link to comment
3 minutes ago, carusoam said:
Aircraft Brand Paint Remover...  Do Not Use on Aircraft...
I’m going to shake my head for hours...
go figure, right? I called them 4 or 5 years ago to ask why you cant use aircraft paint remover on aircraft, and all he said was two words, Hydrogen Embrittlement, I thanked him for his time and that was the end of our conversation
Link to comment
"Hydrogen embrittles a variety of substances including steel,[11][12][13] aluminium (at high temperatures only[14]), and titanium.[15] Austempered iron is also susceptible, though austempered steel (and possibly other austempered metals) display increased resistance to hydrogen embrittlement.[16]
In tensile tests carried out on several structural metals under high-pressure molecular hydrogen environment, it has been shown that austenitic stainless steels, aluminium (including alloys), copper (including alloys, e.g. beryllium copper) are not susceptible to hydrogen embrittlement along with a few other metals.[17][18]"
In the current use on the floor boards that are not structural in any way embrittlment really may not be an issue, Just don't get sloppy and run it on the spar to be real safe. Likewise, it seems that aluminum is only susceptible at elevated temperatures.
HE on steel, especially 4130 aircraft steel, is a big factor when that steel is chrome plated and that is why steel needs to be baked after plating to remove the hydrogen from stressed steel parts.
Link to comment
17 hours ago, RLCarter said:
for 99% of my cleaning I use water and elbow grease, if it tougher a little WD-40 works well as a solvent ( @Piloto would be proud)
Mr Carter, is that a dispersing agent, or a displacement type you are describing? ;););) @carusoam
Edited by Mcstealth
Link to comment
