ragedracer1977
This can't be legal, can it?
*Members that donate $10 or more do not see advertisements*
7 hours ago, ragedracer1977 said:
Owner says it's signed off as IFR certified..
No thanks. Legal or otherwise.
Also, I don’t like the placement of the Nav indicator or the T&B.
Edited by Shadrach
Share this post
Link to post
Share on other sites
Shop accidentally put in a second g5 vs the g3x that was needed. Should be a quick swap to rectify the problem.
Share this post
Link to post
The G5 installation manual is very clear that that is not a legal installation.   The proper pages were quoted early on in the FB discussions on that.
Edited by EricJ
Share this post
Link to post
I was just looking for a Facebook sanity check
Share this post
Link to post
Even the STC says in the Limitations and Conditions section that the mechanical ASI, Alt, and VSI must be retained.    Hard to get around that.
Share this post
Link to post
I'll admit I dont know much about the new wiz bang avionics, but that panel makes my old "Shotgun panel" steam gauges look pretty good :)
Share this post
Link to post
The sad thing is this owner put a ton of money into this panel and is now being criticized.  Another $6k for a 10 in g3x and people would be drooling over the perfect Mooney panel.
Share this post
Link to post
There is no sanity on Facebook
Sent from my Pixel 3 using Tapatalk
Share this post
Link to post
Not being criticized.  No more than pointing out that putting dshannon tip tanks on your Mooney isnt legal after you did it.
Share this post
Link to post
And it would be legal!  ;)
As I've been watching this unfold that's kind of what I've been thinking...it's a small step to a G3X from there and it would have been okay.
Share this post
Link to post
Is this an actual owner of a regular certificated aircraft who had an install done by an avionics shop? Does anyone know the back story?
If this were an experimental category plane, say an avionics testbed, then this might be a very different conversation.
Share this post
Link to post
Did someone mention that there's a GFC500 autopilot installed as well? Even though it's not been STC'd for the short bodies? The owner says "it's not hooked up, just installed".
Share this post
Link to post
I think it's actually a J-model.   In the latest post he said he was using the autopilot.
Share this post
Link to post
Nobody mentioned what looks to be an iPad dock way over on the right side.  And there doesn't appear to be any right side panel installed   or am I missing something?
Share this post
Link to post
The iPad mount is the approved guardian avionics unit.  The right (angled) panel is blank on the left side because the primary EI gauges replace the tach/mp/etc.  As I mentioned before the panel is almost perfect. However, if the shop cannot follow the basic instillation limitations they might be over their head installing AP systems etc.
Not a FB user myself but did the owner twist the shops arm to get this layout or was it chosen for him?
Share this post
Link to post
He swears that 2 master avionics installers and a very experienced IA told him it's good to go.
Share this post
Link to post
I’d like to see the log book entry.
Tom
Share this post
Link to post
That was a different guy with his g3x in the short body.
Share this post
Link to post
My mention of the "right side panel" was not enough to clearly portray what I was thinking about. I was referring to the missing right side wall interior panel next to the copilot position legs not the instrument panel. It seems this picture was taken in the hangar at the end of the installation with part of the interior missing. Neither comment was intended to be derogatory to the installation. They were just observations of what was contained in the picture.
Share this post
Link to post
I think you’re right, probably the final picture taken by the installer...I’d personally have him take one more after he upgraded the g5.
Share this post
Link to post
That may not resolve the debate.
My current plane came with a G500 panel upgrade done by a reputable avionics shop. The log entries were detailed and correct.  Insofar as they went.
The logs did fail to mention that the “backup” instruments were not “legal”—the AI was electric with no backup power supply, and the altimeter was likewise electric (a KEA346) with no independent power source.
Swapping out that AI gyro with an L3 ESI500 (internal battery) resolved the problem.
Share this post
Link to post
Tom
It probably says it was a minor alteration using owner supplied parts.
Share this post
Link to post
Yea, as I commented over there it's not remotely legal, I think it's literally the first page of the install guide that says it's not.
Share this post
Link to post
