blakealbers Posted August 31, 2019 Report Share Posted August 31, 2019 Hello all was flying down to Memphis and cylinder 6 was all over the place for a few minutes on EGT but engine remained smoothed I leaned it aggressively and it stopped fluctuating. Cylinder head temp also remained smooth. Do you think I wasn't leaned aggressively enough? I was at 13,500 or is the probe likely going bad ? Or is this something I need to be worried about. Power settings 30.0 mp/ 2400 RPM 1560 TIT 13,500 altitude. After a few minutes EGT settled in at 1460 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 31, 2019 Report Share Posted August 31, 2019 Blake, got any data to share? JPI and saavy work really well together... EGT sensors can be a challenge, but don’t usually fix themselves by leaning more... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
blakealbers Posted August 31, 2019 Author Report Share Posted August 31, 2019 I’d love to, unfortunately I pulled the card on last flight and didn’t reinsert...of course, the only time it’s ever had any importance. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 31, 2019 Report Share Posted August 31, 2019 See if the JPI has the memory onboard... the card may be just a way to transfer the data... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted August 31, 2019 Report Share Posted August 31, 2019 (edited) You most likely had a fouled plug. It was intermittently misfiring. It is only one of two in the cylinder, so you didn't notice the difference. It may take care of itself, Cleaning is always a good idea. Edited August 31, 2019 by N201MKTurbo 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 31, 2019 Report Share Posted August 31, 2019 Blake, putting a few ideas together... 1) Ross mentioned a way to have raw fuel get to the EGT sensor... 2) Rich mentioned, if a spark plug stops working... raw fuel continues past the exhaust valve while burning... 3) If you have Champion spark plugs... you now want to measure their resistance... check the logs to see what plugs are in there... 4) have your mechanic measure the resistance, if unable. 5) You have enough data to check the #6 plugs... 6) doing a run-up May verify which plug it is that is misbehaving... 7) reviewing older flight’s data may also reveal the plug that may be going away... 8) plugs typically take a long time to get really bad.... 9) there are a couple of failure mechanisms for various plug types... worn or broken. 10) Even the good plugs have shown a quirky failure around here, a few times. PP thoughts only... not a mechanic... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
blakealbers Posted August 31, 2019 Author Report Share Posted August 31, 2019 You most likely had a fouled plug. It was intermittently misfiring. It is only one of two in the cylinder, so you didn't notice the difference. It may take care of itself, Cleaning is always a good idea. That was what my initial thought was as I tend to run a little rich. I just wanted to put this out there and make sure I wasn’t missing anything.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
blakealbers Posted August 31, 2019 Author Report Share Posted August 31, 2019 Blake, putting a few ideas together... 1) Ross mentioned a way to have raw fuel get to the EGT sensor... 2) Rich mentioned, if a spark plug stops working... raw fuel continues past the exhaust valve while burning... 3) If you have Champion spark plugs... you now want to measure their resistance... check the logs to see what plugs are in there... 4) have your mechanic measure the resistance, if unable. 5) You have enough data to check the #6 plugs... 6) doing a run-up May verify which plug it is that is misbehaving... 7) reviewing older flight’s data may also reveal the plug that may be going away... 8) plugs typically take a long time to get really bad.... 9) there are a couple of failure mechanisms for various plug types... worn or broken. 10) Even the good plugs have shown a quirky failure around here, a few times. PP thoughts only... not a mechanic... Best regards, -a- Awesome thank you very much. This site is unbelievably valuable even for small issues. Thank you all, I’ll lean hard and run a mag check and then have mechanic check plugs Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
David Lloyd Posted August 31, 2019 Report Share Posted August 31, 2019 Anything listed above or possibly a worn exhaust valve guide and the valve not seating consistently. If this is the case, it will get worse. Eventually the face of the valve will break and you will definitely notice rough running. 1 Quote Link to comment Share on other sites More sharing options...
blakealbers Posted August 31, 2019 Author Report Share Posted August 31, 2019 Anything listed above or possibly a worn exhaust valve guide and the valve not seating consistently. If this is the case, it will get worse. Eventually the face of the valve will break and you will definitely notice rough running. Ok thanks, annual is in 3 weeks. Get the plugs checked first and maybe have them take a closer look. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
alextstone Posted August 31, 2019 Report Share Posted August 31, 2019 8 minutes ago, blakealbers said: Ok thanks, annual is in 3 weeks. Get the plugs checked first and maybe have them take a closer look. Sent from my iPhone using Tapatalk Suggestion from a fellow PP / Bravo owner: Insist on a Borescope inspection of the valves and cylinder walls during the annual. Compression tests are not conclusive for all cylinder related issues. Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted September 1, 2019 Report Share Posted September 1, 2019 also needs to look at the valves for uneven heating... Quote Link to comment Share on other sites More sharing options...
Guest Posted September 1, 2019 Report Share Posted September 1, 2019 Start with the simple and work to the difficult. The fact that the engine ran smoothly suggests something simple like loose connections on the EGT probe or a failing probe. Then look at the other suggestions. Clarence Quote Link to comment Share on other sites More sharing options...
