Anyone knows where i can find the tie rods for a dog house baffle set up?
Share this post
Link to post
Share on other sites
*Members that donate $10 or more do not see advertisements*
+1 for pictures...
Next rough guess... Often, parts related to cylinders are made available by the engine manufacturer...
Share this post
Link to post
Item 64.. It ties the front and aft baffle together.
186810665b166f57eb918885fe56a69a.jpg8d42ff15ca8719b55d9464fed0e92df9.jpg300b7c1cc6d03c0233c9bd00400a113c.jpg
Share this post
Link to post
I ended up making mine, I threaded 3/16" (?) stainless rod, once installed be sure they cant come in contact with the oil return lines from the rocker boxes.
Share this post
Link to post
Il probably end up making them too.. You said you used 3/16 rods?
https://www.univair.com/piper/piper-pa-18/view-all/u14513-000-piper-intercylinder-tie-rod-front-and-rear-baffles/
Found those online but i’m not sure if they will work.
Share this post
Link to post
I think they were, you still have 1 pictured above just measure it. I was missing 1 when I purchased the plane 4 years ago, someone had run safety wire in its place that was rubbing on the oil return tube. I had SS rod so that is what I used and just fabricated all of them (4?). The bends need a radius or they will break either during the bending or while in use, not hard to do just very tight area to work
Share this post
Link to post
Took your advice and made 4 new ones. ACE (Aircraft Component Exchange) had 1/8 steel rod.. That what the old one are.. I forgot to take pictures.
Share this post
Link to post
That was quick :)
Share this post
Link to post
That was quick
I didn’t have much to do yesterday afternoon haha
Share this post
Link to post
I just took welding rod and ran the thread die down them. That's what the originals were made from :-) Soft enough not to crack when bent.
Share this post
Link to post
Share this post
Link to post
