Newowner Posted July 31, 2019 Report Share Posted July 31, 2019 Getting ready to install EDM and got conflicting information from avionics shop. One swears by CGR other by JPI. Any of you have experience with it and cons and pros. I have all stock M20F with steam engine gauges. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Clparker23 Posted July 31, 2019 Report Share Posted July 31, 2019 I put in a cgr30c, I love it compared to stock, my only complaint is flipping between pages to see everything. But I was limited on budget and it got me what I needed. Most everything I use is first page anyway. I was budgeting for avionics shop install when I was deciding between Cgr30 and Jpi 930, but ended up doing an owner assisted install which was actually easy.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Oldguy Posted July 31, 2019 Report Share Posted July 31, 2019 I have an EDM 900 waiting to go into my plane as soon as it is done with the interior work. If you already have the EDM 930, move forward and install it. If you are preparing to buy a monitor, does space or cost enter into your equation? I consider the EDM 930 the Cadillac of monitors with all of the space it has for showing you what is happening in your engine. What model Mooney do you have? That fact might also drive choice with consideration of the space the 930 takes. People like and use both the EI and JPI monitors as you can see from the response above mine. The best thing is to get one installed and learn how to use it. Whatever the price you pay for it, the amount it can save you in the long term is significant. Quote Link to comment Share on other sites More sharing options...
Oscar Avalle Posted July 31, 2019 Report Share Posted July 31, 2019 I have a EDM 900 installed and I like it. I was able to replace all my original gauges (including fuel) and beyond reliability I freed up a lot of panel space. 2 Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted July 31, 2019 Report Share Posted July 31, 2019 The engine monitor you want in your M20F is the EDM900. The 930 just takes up extra panel real estate. To get the same full Primary replacement of all engine gauges, you'd have to install two EI instruments, the CGR30P and CGR30C. But the EDM900 puts all that in a single Primary gauge. While it's true that EI has wonderful customer support, JPI is still acceptable. And I'd rather only have to buy, install, and maintain one instrument to replace ALL factory engine instruments rather than two. 1 Quote Link to comment Share on other sites More sharing options...
Newowner Posted July 31, 2019 Author Report Share Posted July 31, 2019 Thanks for all your replies. I meant JPI 900 . Coast is almost identical for 900 vs dual 930s. It’s just interesting how two shops totally against one or the other. I’m getting old and really like bigger display. Still deciding which one to put. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted July 31, 2019 Report Share Posted July 31, 2019 Love my 900. A 930 would be nice, but I didn't have space for it, nor did I want to pay the premium for the bigger screen.I like it well enough that whenever I upgrade to a G3X or Dynon I will very likely retain the 900 instead of going with an integrated EIS kit. If I still had OEM gauges, though, adding EIS to the upgrade PFD/MFD would be very tempting.Sent from my LG-US996 using Tapatalk Quote Link to comment Share on other sites More sharing options...
StevenL757 Posted July 31, 2019 Report Share Posted July 31, 2019 The EDM900 or the 930 (depending on panel real estate) is your better option. I've owned three models of EDM and flown behind several more, and swear by them. Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted July 31, 2019 Report Share Posted July 31, 2019 I like having my EDM900 on the left side within easy view. 1 Quote Link to comment Share on other sites More sharing options...
jetdriven Posted July 31, 2019 Report Share Posted July 31, 2019 This year I finally bought an engine monitir but I got the 830. I prefer the 900 but there’s physically no space on my airplane on the left side to put it without re-cutting the panel. Then it goes from a $2000 job to over 4 so there was that. Quote Link to comment Share on other sites More sharing options...
Brian E. Posted July 31, 2019 Report Share Posted July 31, 2019 I have the EDM 900 with digital fuel senders. Best AMUs Ive spent on the plane. Between the engine monitor and Mike Busch it's changed how I fly! You'll have no regrets... 2 Quote Link to comment Share on other sites More sharing options...
Newowner Posted July 31, 2019 Author Report Share Posted July 31, 2019 Anybody have any experience with MVP 50P. How that compares to JPI 900. Also one shop quoted me 10K out of the door for unit and install of dual CGR. Is it ok price?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ragsf15e Posted August 1, 2019 Report Share Posted August 1, 2019 Plenty of real estate for a 930, just depends on how much other stuff you want to keep. Large size is real nice. Data download is useful at times for troubleshooting. Leaning features are real nice. Overall, I’m very satisfied with previous owners purchase! 900 gives about the same info and would definitely be fine as well. Can’t go wrong with either. And yes, there’s not much fuel left in that picture. 12 gallons, burning 8.3/hr, 9 miles from destination. 11 gallons of fuel on one side to use for pattern/landing. I’m relatively comfortable with that. Anyone else not, Id like to know if I’m not being smart. Fuel Remaining estimate from the fuel flow was showing 13. Both are conservative when I top it off - they both show slightly less than actually in the tanks. 2 Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted August 1, 2019 Report Share Posted August 1, 2019 I prefer it on the left side, no way 930 would fit, most 930s end up on the far right.Tom Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted August 1, 2019 Report Share Posted August 1, 2019 I’m in full agreement with that fuel situation. Better to have it all in one tank rather than split between two tanks. 1 Quote Link to comment Share on other sites More sharing options...
jetdriven Posted August 1, 2019 Report Share Posted August 1, 2019 (edited) 56 minutes ago, Ragsf15e said: Plenty of real estate for a 930, just depends on how much other stuff you want to keep. Large size is real nice. Data download is useful at times for troubleshooting. Leaning features are real nice. Overall, I’m very satisfied with previous owners purchase! 900 gives about the same info and would definitely be fine as well. Can’t go wrong with either. And yes, there’s not much fuel left in that picture. 12 gallons, burning 8.3/hr, 9 miles from destination. 11 gallons of fuel on one side to use for pattern/landing. I’m relatively comfortable with that. Anyone else not, Id like to know if I’m not being smart. Fuel Remaining estimate from the fuel flow was showing 13. Both are conservative when I top it off - they both show slightly less than actually in the tanks. The 930 on the right side is basically like A 900 right in front of you. It’s larger, but further away. And more expensive. Edited August 1, 2019 by jetdriven 2 Quote Link to comment Share on other sites More sharing options...
Newowner Posted August 1, 2019 Author Report Share Posted August 1, 2019 Anybody have MVP 50P? What’s your thoughts on that?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ragsf15e Posted August 1, 2019 Report Share Posted August 1, 2019 47 minutes ago, jetdriven said: The 930 on the right side is basically like A 900 right in front of you. It’s larger, but further away. And more expensive. Yep, fair enough. I’m guessing if I did it, I’d be more cost conscious than the PO and would have the 900. However, Either I’m use to it there or I like it there. I really like just having my 6 pack in front of me and nothing else. In the G1000 airplane I fly at work, the PFD is directly in front and has all the 6 pack info. Engine instruments are on the mfd to the right. Maybe it’s just me, but it’s what I’m use to. Long winded way of saying that you’re not going to go wrong with a quality engine monitor. Get rid of the oem engine gages. Be happy. Quote Link to comment Share on other sites More sharing options...
kris_adams Posted August 1, 2019 Report Share Posted August 1, 2019 CGR30P and CGR30C here. Both on the left side of my radio panel without doing any panel mods. Very happy with them. Quote Link to comment Share on other sites More sharing options...
jamesm Posted August 1, 2019 Report Share Posted August 1, 2019 I went the difficult and painful route . I started out with the Insight G3 Graphic Engine Monitor then added CGR30C and Added Cies fuel senders , and recently added CGR30P. using the existing Insight G3 CHT/EGT probes, and fuel flow transducer. I was lazy and didn't want to pull out my existing my CHT/EGT probes and Transducers and plus Insight doesn't have way real way adding lat long position altitude to flight data being recorded. There is way with Insight but it would have been more expensive and more panel space need. The main reason that I upgraded was the old eyes were struggling a little bit reading the 2/14" display it was still readable. With the G3 can be a PITA having remove those PG /SEL caps on the G3 to remove the instrument. As gsxrpilot and others have pointed out in the two 3.125" instruments configuration is taking more panel space besides the two interments holes you have to make room for additional USB port (to retrieve data each CGR 30 unit has it separate USB port) and two sets of annunicators (one for CGR30C and one for CGR30P so 4 light in total). But the CGR30 setup isn't bad it is easy to read and great customer support. Sure be nice to make Engine monitor data collection was wireless access point !!!! Then you could consolidate displays not be limited to 2.25" or 3.125" hole or rectangular display shapes. I don't know much about JPI. . I guess the EI V JPI dissuasion sort of a mac vs pc argument to a degree each side has advantages and everyone seems to have an opinion. just my take. James '67C Quote Link to comment Share on other sites More sharing options...
Hank Posted August 1, 2019 Report Share Posted August 1, 2019 27 minutes ago, Kris_Adams said: CGR30P and CGR30C here. Both on the left side of my radio panel without doing any panel mods. Very happy with them. Pics, please, for those of us not committed to either install yet! Quote Link to comment Share on other sites More sharing options...
kris_adams Posted August 1, 2019 Report Share Posted August 1, 2019 Will run to the airport and take some tomorrow. Quote Link to comment Share on other sites More sharing options...
mark21m20c Posted August 1, 2019 Report Share Posted August 1, 2019 I put 930 to right of avionics stack with rad over G5. Its as close as you can come to a ecam system on a m20c. Quote Link to comment Share on other sites More sharing options...
Newowner Posted August 1, 2019 Author Report Share Posted August 1, 2019 Thank you everybody for all your inputs. My original plan was to get least expensive and efficient airplane to commute 100nm in vfr only. But I already want to start putting good stuff in it. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 1, 2019 Report Share Posted August 1, 2019 N.O. There are three manufacturers of engine monitors that have been used by MSers over the years... 1) First decide if you are going to use it for primary indication... 2) Then decide on panel location... 3) There are a few of the large format screens mounted on the co-pilot side... 4) Somebody mentioned the RAD, that delivers data to The pilot side... 5) Find the three manufacturers... look up their products on their sites... 6) Big discounts are in effect for a short period after KOSH.... time is running out already... 7) JPI 900 is most popular around here for primary... 8) Many 800 series being used, but not primary... 9) EI has great products and even better service... but know what is primary and what is not... 10) See Don Kaye’s panel... he is a proponent of the EI MVP... 11) A good engine monitor will be incredibly helpful the first day you have an engine question... people have learned to post their data for discussion... 12) plugs, fuel injectors, and changes in rpm seem to be the causes for many inquiries... all are much easier to cure with data... Your mechanic experience isn’t anything to worry much about... there are many opinions about what is best for the pilot... this one can only be decided by you... your mechanics and avionics people can help you with the decision... you still have to decide... PP thoughts only, not a mechanic... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
