Roll Servo / TKS Issue
2 hours ago, Northern Mooniac said:
They think it's coming from the access panel and getting sucked in, i'm just wondering if anyone else has run into an issue like this?
I would second the leak suggestion.  There isn’t that much that rolls back across the wing to really get it soaking.  Try poking around with A borescope.
This is a lot of bang for the buck if you don’t have one.   https://www.amazon.com/dp/B01MYTHWK4/ref=cm_sw_r_cp_api_i_Pe0pDb71Y19GX
Link to comment
Share on other sites
  • 2 weeks later...
J.Jennings,
is @CAV Ice Protection part of your group as well?
This is our usual TKS contact... wondering if we can add a second view point to our usual support structure...
We have many TKS users around here.  But, problems are few and far between... when they arise they seem to be pretty unique... like the afore mentioned one...
Reminder for @Northern Mooniac to post pics when / if able...
Link to comment
16 hours ago, carusoam said:
J.Jennings,
Bonanza guys are finding out that it corrodes the steel wire that fastens the skin to the spar. . The wire snaps off then they have to change the spar because of corrosion.
Edited by jetdriven
Link to comment
@jetdriven the FAA came out with an SAIB covering Bonanza, Baron, and Debonair series airplanes.  The reason corrosion is occuring is due to the high carbon steel hinge pin beech switched to.  The TKS doesn't corrode the pin itself, but TKS fluid will wash away any lubrication/oils/ect. that are on the pin.  Previous versions of the aircraft with the stainless steel pins are not being effected to our knowledge.
Link to comment
