hoot777 Posted July 27, 2019 Report Share Posted July 27, 2019 Does the FAR require this to be inspected on the annual . I read it does yet have seen sign off without it . thanks and fly safely Quote Link to comment Share on other sites More sharing options...
tigers2007 Posted July 27, 2019 Report Share Posted July 27, 2019 No clue but you’ll read anecdotes here alone on Mooneyspace where owners have found shocking items caught by the screen but had nothing remarkable when inspecting the oil filter. My A&P told me he doesn’t check it on mine; I can’t really argue that as he has big pan hands. In the next month or so when I hit 25hrs I’m going to pull mine using my tiny little hands with tiny wrists. Just make sure you buy the special (and cheap $$) crush washers. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted July 27, 2019 Report Share Posted July 27, 2019 I ask my mechanic to do it, don’t think FARs have that detail, but Lycoming surely does.Tom Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted July 27, 2019 Report Share Posted July 27, 2019 If you take off the oil filter you can reach down past the oil filter mount and (easily?) reach it and remove it. Nothing to it unless your turbo mount runs right behind it. Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted July 27, 2019 Report Share Posted July 27, 2019 If you take off the oil filter you can reach down past the oil filter mount and (easily?) reach it and remove it. Nothing to it unless your turbo mount runs right behind it. I’ve heard it’s the safety wire installation that’s the hardest part?Tom Quote Link to comment Share on other sites More sharing options...
kortopates Posted July 27, 2019 Report Share Posted July 27, 2019 Although IA's may use whatever list they like, part 43.D specifies the minimum an annual checklist should contain: D)... (3) Internal engine—for cylinder compression and for metal particles or foreign matter on screens and sump drain plugs. If there is weak cylinder compression, for improper internal condition and improper internal tolerances. I believe Mooney's 100 hr/annual checklist also includes it. Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted July 27, 2019 Report Share Posted July 27, 2019 2 hours ago, ArtVandelay said: I’ve heard it’s the safety wire installation that’s the hardest part? Tom You heard right! Quote Link to comment Share on other sites More sharing options...
