SantosDumont Posted July 21, 2019 Report Share Posted July 21, 2019 My LH baffle has a crack that I want to repair. It looks like someone had already tried to repair it with a doubler, and that cracked. Thinking it might be better to just buy the new part and install it, but I’m not sure how to figure out which part it is. Its the TCM IO-360-ES so I’m thinking it might match one of the baffles from the M20K IPC, since the M20K has a TSIO-IO-360 Looks like there are two different LH baffles in the IPC: 600380-029 and 600410-501. Googling those part numbers doesn’t seem to have any useful results, and not even a parts search on LASAR turns up anything. Am I just going to have to take it off, model it in Solidworks and get it laser cut out of aluminum? Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted July 21, 2019 Report Share Posted July 21, 2019 Sense when does an M20F have a 6 cylinder Continental? Quote Link to comment Share on other sites More sharing options...
SantosDumont Posted July 21, 2019 Author Report Share Posted July 21, 2019 Since ModWorks got their hands on it in 1998, made a STC that was installed on two M20Fs then went out of business. Having to reverse engineer a few things... Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted July 21, 2019 Report Share Posted July 21, 2019 Do you have the STC drawings? The FAA should have the drawings if you don't have a copy. They should have the baffle part numbers. There are companies out there that make aftermarket baffles. They would be a good resource. I would just fix it. Quote Link to comment Share on other sites More sharing options...
SantosDumont Posted July 21, 2019 Author Report Share Posted July 21, 2019 I dont have a complete set of the drawings. I ordered the FAA CD and was hoping they would be on there, but they are not... not sure who to contact to see if the FAA has the drawings. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted July 21, 2019 Report Share Posted July 21, 2019 3 minutes ago, SantosDumont said: I dont have a complete set of the drawings. I ordered the FAA CD and was hoping they would be on there, but they are not... not sure who to contact to see if the FAA has the drawings. Call the FSDO and ask to talk to a maintenance inspector. Ask them for advice. What is the STC number? Quote Link to comment Share on other sites More sharing options...
SantosDumont Posted July 21, 2019 Author Report Share Posted July 21, 2019 SA02204AThttp://rgl.faa.gov/Regulatory_and_Guidance_Library/rgstc.nsf/0/5A0B546A969B279385256CC1007F395A?OpenDocument Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted July 21, 2019 Report Share Posted July 21, 2019 22 minutes ago, SantosDumont said: SA02204AThttp://rgl.faa.gov/Regulatory_and_Guidance_Library/rgstc.nsf/0/5A0B546A969B279385256CC1007F395A?OpenDocument I would call the responsible office number listed on the STC and see what they can do for you. Quote Link to comment Share on other sites More sharing options...
cliffy Posted July 22, 2019 Report Share Posted July 22, 2019 There is nothing very difficult in repairing what I see there. Any good sheet metal A&P can disassemble the item, make a new piece that is cracked and rerivet it all together. Sheet metal wasn't my forte but even I can do that one. You might be going to a lot more trouble than needed by trying for the STC parts. Actually one might just try stop drilling the crack and see if it progresses over the next 100 hrs. Might just work out fine that way. In any event, it is a super simple sheet metal repair. 1 Quote Link to comment Share on other sites More sharing options...
kortopates Posted July 22, 2019 Report Share Posted July 22, 2019 That does look just like the M20K baffling.It's possible the part no's are different parts of the same assembly or one is the full assembly and another is the just the top part - flat section.The full assembly includes several parts - vertical portion that attaches to cylinders, horizontal portion that has cracks and felible baffling material. You just want to replace the horizontal portion. Call Dan at Lasar and he can order the piece from Mooney for you.Your rear silicone baffling looks totally ineffective - time to replace.Sent from my iPhone using Tapatalk 1 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 18, 2019 Report Share Posted August 18, 2019 Checking to see if Santos @SantosDumontgot the last messages in this thread... Air flow control is important for CHTs So chasing cracks in the baffling can be pretty important... So can the rubber seals that are important to the baffling process... Santos, it looks like part of the rubber seals may have left the building... There is some rubber that appears as if it is no longer there... @GEE-BEE is MS’s rubber seal and baffling guy... take a look at some of his pics... to see what seems to have departed your air cooling system... The modern silicone rubber seals that are orange-ish in color are high temp and long lasting... Sorry about being late on this thread... I fell behind in some reading during KOSH... Expect that the K might have very similar baffling and seals to match your Continental installation... with your K cowl... You might also see what Missile and Rocket owners have done... all mid body Mooneys with K cowls... that match the Continental six cylinder engine block... PP thoughts only, not a mechanic... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
SantosDumont Posted August 19, 2019 Author Report Share Posted August 19, 2019 The baffle on top is actually just bent over. When I look in with a flash light I can see it touching the top of the cowl. Need to put a flashlight in the bottom of the cowl to see if I can see any light coming through. The baffling is 20 years old though. Probably time to replace it. Quote Link to comment Share on other sites More sharing options...
