Welcome aboard JCP.
Since that part of the structure is identical...
Expect that you can find support documents to allow it to be done...
Lasar is a pretty good resource if you are buying the parts from them...
Do you have the parts already?
John, an MSer around here has put most of an O’s interior in an F...
Otherwise, your mechanic is the go to resource to get the parts installed and documented properly...
And... there are those fancy airbag seat belts for consideration...
