air cooled dad Posted July 8, 2019 Report Share Posted July 8, 2019 1975 F gns430w radio gma-340 audio panel Just finished a round trip from Georgia to Michigan and back. Last 30 minutes of the flight I couldn't transmit from my push to talk. Assumed it was just the pilots ptt so I snagged the headset from the right seater and used the right seat ptt. It worked but the sound feedback in my headset was scratchy. ATC assumed the scratchy sound was due to an issue on their end. I cancelled IFR before I couldn't transmit at all. Fast forward a couple days... I head down to the hangar to isolate the problem. With the engine OFF I can transmit. A few radio calls to the FBO using multiple headsets, both installed ptt switches and an old velcro ptt worked great. Fired up the engine to taxi out and tried a few more radio calls. Nothing...just crickets... Once again I tried multiple headsets, both pilot and copilot ptt switches and the old velcro ptt and nothing worked. FBO said the could only hear some clicking and no voice. Shut down the engine and voice over the comm worked again. Ugh... Any ideas before I head off to the avionics shop in the morning? Thanks, Jason Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted July 8, 2019 Report Share Posted July 8, 2019 Try pulling the alternator circuit breakers.Tom Quote Link to comment Share on other sites More sharing options...
M20F Posted July 8, 2019 Report Share Posted July 8, 2019 Make sure your jacks are tight on the panel. They loosen sometimes and will ground out (probably not it but easy to fix/check). Quote Link to comment Share on other sites More sharing options...
Guitarmaster Posted July 9, 2019 Report Share Posted July 9, 2019 What is running with the engine on that is not with the engine off....AlternatorMagsRegulatorI would definitely be looking to one of those three as the culprit.Sent from my Pixel 2 XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
Andy95W Posted July 9, 2019 Report Share Posted July 9, 2019 13 hours ago, ArtVandelay said: Try pulling the alternator circuit breakers. Tom Like Tom was getting at, you need to isolate the source of the noise/interference. The most likely sources are alternator/generator, magnetos, or vibration. Pulling the alternator/generator circuit breaker will basically turn it off. Turning your magneto switch to L or R will turn off the other magneto. Vibration is more difficult, but changing RPM might be able to point you in the right direction. 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted July 9, 2019 Report Share Posted July 9, 2019 The PTT completes a to ground to turn on the radios and such. So it is a problem with ground. floating ground 2 Quote Link to comment Share on other sites More sharing options...
air cooled dad Posted July 9, 2019 Author Report Share Posted July 9, 2019 Thanks everyone. Drove over to Aircraft Spruce and bought a handheld radio. Heading down to the hangar to chase this thing down. Bad news, we cancelled our trip to St. Augustine. Good news, we will spend a few days camping at the lake instead. The hangar is 10 minutes away from the lake! First world problems. Lol. Quote Link to comment Share on other sites More sharing options...
air cooled dad Posted July 13, 2019 Author Report Share Posted July 13, 2019 Problem solved. Turns out that the avionics shop that looked at my plane a couple months ago forgot to secure the 430. Over time, the vibration wiggled the radio out just a wee bit. Simple fix to reseat the radio. 3 2 Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 15, 2019 Report Share Posted July 15, 2019 Great follow-up ACD! Thanks for sharing the details. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
